Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 203Likes
post #181 of 13188 Old 03-23-2013, 10:30 AM
g12eyfox's Avatar
The 8g kuro measured at 0.004 fl...while 9g measured lower than 0.001 fl (depending on model and tweaks). Link for reference: http://www.avsforum.com/t/1250816/black-level-measurements-of-recent-lcds-and-plasmas-enjoy
g12eyfox is offline
post #182 of 13188 Old 03-23-2013, 10:41 AM
sonyfan's Avatar
Originally Posted by hungro View Post
With the one poster mentioning it looks blacker then his 8G Kuro could we be looking at triple zero's for MLL perhaps 0.0009 FTL ?
And this is only the 51" could it have the same MLL as the 60 and 64"?eek.gif
sonyfan is offline
post #183 of 13188 Old 03-23-2013, 10:41 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Too soon to say based on just eyeballing it, though from the first owner's satisfaction, my speculation is that it may be quite close. The 9G comparisons will be even more revealing/telling.
vinnie97 is offline
post #184 of 13188 Old 03-23-2013, 10:52 AM
Ph8te's Avatar
Quoted: 4543 Post(s)
Liked: 3972
Originally Posted by htwaits View Post
I understand, but for flat panels the answer is pretty much the same too. Expect poor audio quality. smile.gif
I dont think anyone expects "great audio" as long as it dosent sound like a tin can....Poor is a realative term as well all TV speakers sound "poor" when compared to an actual home theater set up, even some of the bad ones.....If they sound "normal" and voices are clear then thats the most you can ask for really...
Ph8te is offline
post #185 of 13188 Old 03-23-2013, 11:11 AM
Donloz's Avatar
Quoted: 50 Post(s)
Liked: 60
Has anyone tried 3D ?
Every day above ground is a good day.
Donloz is offline
post #186 of 13188 Old 03-23-2013, 11:15 AM
Watcher12's Avatar
Would also love to hear about the F8500's 3d performance, specifically how it stacks up versus their 2012 lcd 3d performance (which was excellent).
Watcher12 is offline
post #187 of 13188 Old 03-23-2013, 11:33 AM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
What's the rated power useage of the F8500 series? I don't see it listed in the manual available for download from samsung.
RWetmore is offline
post #188 of 13188 Old 03-23-2013, 11:35 AM
sonyfan's Avatar
Does anyone know when absolute black is required do 'reset control' algorithms limit current to the point
sonyfan is offline
post #189 of 13188 Old 03-23-2013, 12:35 PM
barth2k's Avatar
Quoted: 728 Post(s)
Liked: 526
I don't know, but I notice in the VE product guide the f8500s (all sizes) are not energy star compliant. The lower models are.
Smurfmlb: how is the sharpness? Do you watch nature / science / travel programs? I like the crystal clarity and sharpness that the good LCDs have with that kind of programming. Hope this set have a lot of that.
barth2k is offline
post #190 of 13188 Old 03-23-2013, 12:54 PM
sonyfan's Avatar
In 'Movie' mode the default cell light is 20, that would eliminate any chance of energy star compliance.biggrin.gif
The lower models are energy star compliant because the cell light is at 10 or lower.eek.gif
sonyfan is offline
post #191 of 13188 Old 03-23-2013, 01:08 PM
dr0z77's Avatar
Quoted: 53 Post(s)
Liked: 69
actually default for 'movie' mode is 18... dynamic is 20..
dr0z77 is offline
post #192 of 13188 Old 03-23-2013, 01:25 PM
Wizziwig's Avatar
Quoted: 954 Post(s)
Liked: 635
Originally Posted by surfmlb View Post
Got the engine started. Here a slight buzz about the same as my kuro. You really cant hear it until you put your head behind the set.
Originally Posted by sa View Post
surfmlb,
Do you hear any buzzing noise at all when you're in front of the tv, or only when you put your head behind it?
When testing for buzzing, sit directly in the center in front of the set and turn your head so your ear faces the screen. Try with both ears. Make sure audio is muted. Previous models of Samsung plasma had this directional buzz that could only be heard from this position. You could hear it even 15ft from the set. If you were sitting off to the sides it was much less noticeable. Thanks for all your feedback so far.
Wizziwig is offline
post #193 of 13188 Old 03-23-2013, 01:35 PM
HughScot's Avatar
From what I have read elsewhere the buzz is suppose to be gone. Considering the excellent picture quality this looks like a great display, and the price for the smallest one is definitely a plus. Will look forward to hearing how everyone likes it.
Hugh Campbell
HughScot is offline
post #194 of 13188 Old 03-23-2013, 02:48 PM
Ken Ross's Avatar
Quoted: 5700 Post(s)
Liked: 6062
Here are some more angle pictures. It really isnt as bad as it looks in the picture. I think my camera isnt doing justice
From the top
From the bottom
THESE IMAGES ARE FROM 3 FEET OR LESS. THIS DOES NOT OCCUR FURTHER AWAY 4 FEET OR MORE
That's really odd. I can't recall seeing that viewing angle limitation on plasmas. I guess if it's only up close, it's not too bad...except for kids that like to hang out close and low.
Ken Ross is offline
post #195 of 13188 Old 03-23-2013, 02:56 PM
opus123's Avatar
I'm almost afraid to ask, but... does the F8500 support Amazon Instant Video? Either out-of-box, or via app store download?
Otherwise AIV is limited to 2010 & 2012 models. I didn't use on my C8000 til recently, but now I use it all the time. Hope the Samsung/Amazon frenemies will do the right thing by consumers.
opus123 is offline
post #196 of 13188 Old 03-23-2013, 03:02 PM
Ken Ross's Avatar
Liked: 6062
Smurfmbl, Have you seen any brightness fluctuation?
How is the ABL? For example at end of commercials there is usually a title card showing the product logo on an all white background. Does the white background look pretty white or kind of gray?
Yup. That's what I'm waiting to hear about too. Hopefully the ABL on this unit is much less aggressive than it is on prior plasmas.
Ken Ross is offline
post #197 of 13188 Old 03-23-2013, 03:02 PM
opus123's Avatar
That's really odd. I can't recall seeing that viewing angle limitation on plasmas. I guess if it's only up close, it's not too bad...except for kids that like to hang out close and low.[/quote]
That looks like the top-bottom louver effect of the screens black filter. If so, I obsessed over this becoming a problem with my C8000 pre-purchase, but it was never an issue with any of my standing, sitting, lying-down viewing angles the past 2+ years.
opus123 is offline
post #198 of 13188 Old 03-23-2013, 03:07 PM
dr0z77's Avatar
Quoted: 53 Post(s)
Liked: 69
It has this right out of the box, plus the usual suspects (netflix, hulu, etc,etc..,)... just recently got into AIV, and I like it, has max and ruby, and little bill which my kids love and u can't find on netflix for kids..
dr0z77 is offline
post #199 of 13188 Old 03-23-2013, 03:15 PM
opus123's Avatar
Thanks dr0z77!! Glad to hear as my current C6900 BD player offers no AIV support, so would have to replace the player too.
opus123 is offline
post #200 of 13188 Old 03-23-2013, 03:36 PM
dr0z77's Avatar
Quoted: 53 Post(s)
Liked: 69
welcome.. and that is right ouf the box, no download needed.. the new smart hub is definitely pretty cool..
dr0z77 is offline
post #201 of 13188 Old 03-23-2013, 03:45 PM
frostylou's Avatar
Quoted: 12 Post(s)
Well color me utterly blown away.
I just saw one. The television is simply unreal. (I think beyond either the pioneer elites and sharp elites)
Amazing, with all the talk of 4k this year and oled, this masterpiece of a television completely slipped under the radar.
frostylou is offline
post #202 of 13188 Old 03-23-2013, 03:57 PM
dr0z77's Avatar
Quoted: 53 Post(s)
Liked: 69
She is definitely a beauty... I guess you really have to see it to believe it.. wink.gif
dr0z77 is offline
post #203 of 13188 Old 03-23-2013, 04:04 PM
sonyfan's Avatar
I wish CNN's Erin Burnett would mention it rather than endlessly talking about the Samsung Galaxy!rolleyes.gif
sonyfan is offline
post #204 of 13188 Old 03-23-2013, 04:53 PM
surfmlb's Avatar
Originally Posted by Ph8te View Post
This was asked in the other thread, but I figure it would be best asked here, how are the sets built in speakers?
Sound is really cheap sounding. My Pioneer VSX-30 just overheated and stopped working on me so I am now using the built in speakers. Compared to the speakers that came with my 8g Kuro these are horrible. Now I am on the hunt for a decent receiver. I was in the process of figuring out why my ARC wasn't working. It was because my receiver didn't have it. You would think an Elite receiver would have it. I didn't even think twice. The TV speakers work is all I can say about them but not worth having them If you ask me.
surfmlb is offline
post #205 of 13188 Old 03-23-2013, 04:54 PM
surfmlb's Avatar
very white
surfmlb is offline
post #206 of 13188 Old 03-23-2013, 04:57 PM
surfmlb's Avatar
Originally Posted by Halimali View Post
Thank you Surfmlb for the awesome pictures and for answering our questions. You have been really great help. You are our hero in this thread.
The last Samsung E8000 plasma suffered from brightness fluctuations. Do you notice anything like that on this model?
If this is on movie mode and it is that bright then how is it on standard mode. I guess if I will be buying a plasma it will be this TV.
It fixes one of Plasma's drawbacks which is brightness. I can live with IR , even though I heard that Samsung TVs are more resistant to it than others.
Very excited.
Thank you again for all your efforts and for sharing with us these pics and info.
Congratulations again for a truly awesome TV
No fluctuations that I saw
surfmlb is offline
post #207 of 13188 Old 03-23-2013, 05:00 PM
surfmlb's Avatar
Originally Posted by Watcher12 View Post
What are the de-judder/ smoothness controls like? Are they separate controls and with ten points of granularity like in the Samsung LCDs?
There is only a motion judder canceller that I see settings are off, standard, or smooth
surfmlb is offline
post #208 of 13188 Old 03-23-2013, 05:05 PM
surfmlb's Avatar
surfmlb,
If I put my ear practically to the screen I can barely hear it but its mostly coming from the back. My hearing is pretty sensitive too.
If you have this in a smaller bedroom you might here it more than I do in a living room.
Not sure how it would bounce of the wall If its mounted real close to it either Mine is off the wall like a foot or so.
surfmlb is offline
post #209 of 13188 Old 03-23-2013, 05:08 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
htwaits is offline
post #210 of 13188 Old 03-23-2013, 05:08 PM
surfmlb's Avatar
Yes, It looks excellent to me but I don't care much for 3d and haven't tried it on any other sets. Saw maybe 3 times in theaters.
surfmlb is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
