Samsung PN43E450 - Wide screen or not? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 57 Old 03-17-2013, 03:00 PM - Thread Starter
Aristide1's Avatar
This is a little confusing. On the one hand this set reportedly has a resolution of 1024 * 768 (in Cnet reviews and others). Simple math shows us this is a 4:3 resolution. Yet in every photo it seems to be a 16:9 set.
So which is it? Is this a 4:3 set or a 16:9 set?
Aris
Aristide1 is offline
post #2 of 57 Old 03-17-2013, 03:26 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
It's definitely a widescreen 16:9 TV. I think the pixels are rectangular.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 57 Old 03-17-2013, 03:35 PM - Thread Starter
Aristide1's Avatar
IE That would essentially be a forced picture stretch. Very unnatural.
It's physical aspect ratio (40 inches * 26.6 inches) = 1.50.
post #4 of 57 Old 03-17-2013, 06:47 PM - Thread Starter
Aristide1's Avatar
http://shop.panasonic.com/shop/model/TC-P42X5?t=specs
It appears this panasonic is another 1024 * 768 (4:3) set masquerading as a 16:9.
And again, the overall size of the unit has an aspect ratio of 1.5.
post #5 of 57 Old 03-17-2013, 07:42 PM
"Don't PM Me Bro"
Quoted: 501 Post(s)
Liked: 768
All modern Plasma TVs are16:9, which translates to a 1.78:1 screen ratio - regardless of the number and/or shape of the pixels. Nothing is being stretched.
Randy
post #6 of 57 Old 03-17-2013, 08:11 PM - Thread Starter
Aristide1's Avatar
1920 x 1080 Resolution is 16:9 or 1.78 aspect ratio. 1920 / 1080 = 1.78
To obtain the same aspect ration with 720 lines of resolution requires 1366 * 768, not 1024 * 768.
1024 / 768 = 1.3333 or 4:3 aspect ratio
1366 / 768 = 1.78, this is 16:9
Something doesn't add up here.
post #7 of 57 Old 03-17-2013, 08:42 PM
JSpectre88's Avatar
Liked: 54
Isn't your analysis going by a square pixel? If it's rectangular then it can cover more surface area.
JSpectre88 is offline
post #8 of 57 Old 03-17-2013, 10:54 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
I think you are right... something fishy. Perhaps the "spec sheet" is wrong.... you know how good some manufacturers are... these guys probably outsourced their web page to some low paid north american spec writers... :-) IF not, as the screen is a 16:9 aspect, that would mean that a "degree" of processing is going on to actually "compress" (ie. scale) a 720p signal to allow it to "stretch" logically back out on the display.
budwich is offline
post #9 of 57 Old 03-18-2013, 01:10 PM - Thread Starter
Aristide1's Avatar
You are right, others have told me the pixels are rectangles. It may be touted as widescreen, but not specifically touted as 16:9.
The easiest way there is to find out if they messed with people is to display a JPEG of a circle or a perfect square. If you see an oval or a rectangle then you know, but I tkink they only stretched it a little, so many may not notice. It's a convenient way to hold costs down, but I don't agree with it. The real mystery is why you don't read about this in professional reviews.
Thanks for the info, it made it easy to rule out this unit.
Aris
post #10 of 57 Old 03-18-2013, 01:26 PM - Thread Starter
Aristide1's Avatar
Rectangles would also further exaggerate the staircase effect of diagonal lines. Only company profits end up in better shape making rectangles.
post #11 of 57 Old 03-18-2013, 01:39 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
probably. I think what some people were trying to point out was that the TV's display aspect ratio was indeed widescreen (ie. "16:9" physical measurement) based kind of your title question... perhaps it would have been better to pose "is it really only a 1024X768 resolution screen?". But as you have "investigated", you do have to read thru specs carefully as some manufacturers are playing games with resolutions.
budwich is offline
post #12 of 57 Old 03-18-2013, 01:45 PM
sonyfan's Avatar
IMO, with the 43" E450 it's essential to turn the Sharpness down to 0.
It only adds artifacts including the staircase effect of diagonal lines.
Plus a tech who works for Samsung posted last year said the same thing
adding the 'cell light' is a holdover from the LCD line and should be set to it's max.
sonyfan is offline
post #13 of 57 Old 03-18-2013, 04:23 PM - Thread Starter
Aristide1's Avatar
It is, per manufacturers website, that must be right, they don't error on the low side, only on the high side. eek.gif
Sharpness - Even with CRTs "sharpness" is an add-on circuit to embellish what's there, So it's no surprise that a display that has good detail inherent in its design will only suffer from added sharpness.
It reminds me of spices, add some only to bland food, and only in small quantities less you ruin it.
post #14 of 57 Old 03-18-2013, 04:39 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
that was why I "jested" that they outsourced their web page to some "cheap north american spec writers".... it could be an error. There are plenty of errors out there. I have a samsung tablet (tab2 7) that samsung indicates everywhere (including their support group) that it connects to video devices via hdmi (plus something else)... it can't as it doesn't even output video via the particular output port provided.... probably a class action law suit but that another issue. Anyways, very observant owners of this set would be able to see whether the set a given native resolution..... hopefully, maybe. :-)
budwich is offline
post #15 of 57 Old 03-18-2013, 05:02 PM - Thread Starter
Aristide1's Avatar
The Samsung owner's manual is not clear. Panny's 720p set is also 1024 * 768.
post #16 of 57 Old 03-18-2013, 06:42 PM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Both the sammy and panny are 16:9 ratio wide screen with the same 4:3 resolution. This leads to stairstepping and screen door effect, the latter being the bigger offender.
Here's a webpage from panasonic that stated a 16:9 res in the specs, it's an older tv but you get the idea.
http://shop.panasonic.com/shop/model/TC-42PX34?t=specs
whipit is offline
post #17 of 57 Old 03-18-2013, 06:51 PM
"Don't PM Me Bro"
Quoted: 501 Post(s)
Liked: 768
I don't understand why you think that these "720p" TVs (which are actually 768p) will stretch the image, but they do not. That's why you don't see it in reviews - because it is not happening. Nothing is being automatically stretched.
If you send this TV a 720p, 1080i, or 1080p signal, put the TV's aspect setting to FULL, and display a circle or square you'll see a perfect circle or a perfect square. They will not be stretched - they will appear in their original aspect.
Randy
post #18 of 57 Old 03-19-2013, 10:17 AM
Steve S's Avatar
Liked: 46
^^^All one has to do is get out from behind the keyboard and go to any store that sells these sets and look for one's self--they have 16/9 screens with no geometric distortion.
Steve S.
Steve S is offline
post #19 of 57 Old 03-19-2013, 10:55 AM
dabsac's Avatar
Quoted: 29 Post(s)
Liked: 24
I have one of these and I can assure you there is no stretching what so ever with the picture. The picture is actually very good on this tv and better than the Phillips 1080p LCD it replaced in my bedroom.
dabsac is offline
post #20 of 57 Old 03-19-2013, 12:15 PM - Thread Starter
Aristide1's Avatar
The only way that can happen is if the picture itself is cropped on the ends. I don't buy widescreen TVs for this purpose.
post #21 of 57 Old 03-19-2013, 12:56 PM
JSpectre88's Avatar
Liked: 54
post #22 of 57 Old 03-19-2013, 01:00 PM
sonyfan's Avatar
I have the E450 and it's a fantastic tv for the price.
Nothing is cropped when it's set to 'screen fit' including 4:3.
Screen fit is the default setting and there is no extra picture processing.
I don't like black bars so I use 16:9, wide fit and wide fit 2 when needed.
I like old Hammar and Vincent Price films and with 16:9 or wide fit it's a perfect fit with no cropping.biggrin.gif
sonyfan is offline
post #23 of 57 Old 03-19-2013, 01:04 PM
"Don't PM Me Bro"
Quoted: 501 Post(s)
Liked: 768
I give up. You really don't know what you're talking about.
Are you in a foreign country by any chance?
Randy
post #24 of 57 Old 03-19-2013, 01:31 PM
8mile13's Avatar
Quoted: 1485 Post(s)
Liked: 832
Randy, according this chart 1024x768 is 4:3.
8mile13 is offline
post #25 of 57 Old 03-19-2013, 01:38 PM
"Don't PM Me Bro"
Quoted: 501 Post(s)
Liked: 768
The bottom line is that something the OP read is incorrect, and the PNE450 is definitely a widescreen 16X9 TV.
Randy
post #26 of 57 Old 03-19-2013, 02:01 PM
8mile13's Avatar
Liked: 832
ok. So what is the affect of rectangular pixels on pq?
8mile13 is offline
post #27 of 57 Old 03-19-2013, 02:34 PM - Thread Starter
Aristide1's Avatar
Originally Posted by JSpectre88 View Post
Sience? Mathematics?
post #28 of 57 Old 03-19-2013, 02:37 PM - Thread Starter
Aristide1's Avatar
And a "square" of 500 pixles * 500 pixels will look different on these 2 screens.
The stretch is small scale, the TV dimensions themselves are 1:5, not 1:78. Not even close.
Its understandable how a 10% stretch may not be noticeable.
post #29 of 57 Old 03-19-2013, 02:38 PM
JSpectre88's Avatar
Liked: 54
Edit:
post #30 of 57 Old 03-19-2013, 03:07 PM - Thread Starter
Aristide1's Avatar
You should care, people buy cars because of 40 mpg ratings, but in the real world they don't deliver.
Nothing in the specs suggests this model is 16:9, but here:
http://shop.panasonic.com/shop/model/TC-P50ST60?t=specs
The 16:9 spec is in clear view.
Does anyone really believe that's just an oversight?
It's physical screen dimensions are 40 inches by 26.7 inches.
The math speaks for itself.
Samsung Pn43e450 43 Inch Class Plasma 450 Series Hdtv
