Panasonic Plasma Picture Issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-19-2013, 09:51 AM - Thread Starter
HazNY's Avatar
Hello Forum, I'm writing because I've been having issues with my Panasonic Plasma TH-50PX75U. For a few months now I've been getting sound and no picture, but when left alone for say 20-80 minutes the picture would turn on. But that's not the way to watch a TV, I need to get it fixed. I've done a visual inspection after taking the back panel off, I was hoping it was just a leaking capacitator but they all look fine. Now I'm stuck. Any advice or suggestions?
HazNY is offline
post #2 of 13 Old 03-19-2013, 11:17 AM
Latinoheat's Avatar
Quoted: 1159 Post(s)
Liked: 962
I see that your plasma is roughly 8 years old, I would take it to a TV repair shop and get an estimate, it could be something cheap but considering your tv is so old, the part might not be available anymore. Does it perform the same way with all your components? Or just your cable, if its just your cable it could be your box not the tv. If its with all your sources ,DVD etc than it's your tv. Otherwise it's a good excuse to get a new one, they are so affordable these days now anyways. Good luck.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, HTPC, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC,Klipsch Reference R-62II,Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #3 of 13 Old 03-19-2013, 12:00 PM - Thread Starter
HazNY's Avatar
You're right, it is roughly 6-8 years old. It does this with all components. I realize that I might need to get a new tv but I'd prefer to fix it because it'd be the more economical thing to do and I wouldn't have to waste a perfectly great tv for no reason. I was hoping to do the fix myself as well. I'm fairly versed but still somewhat of a novice if that makes any sense.
HazNY is offline
post #4 of 13 Old 03-27-2013, 05:35 AM
ddp3434's Avatar
I just purchased a TCP65-S60 50 inch and the picture looks "grain" around the outline of objects ESPECIALLY when watching sports or fast moving scenes. Is this just the way it is? I have not adjusted the factory settings for fear that I may make it worse. I would think with 600HZ I would not have any issue whatsoever with clarity and smoothness but currently I am very dissapointed in this tv clarity and smoothness. Perhaps someone out there can suggest something that is a common cure for this or perhaps I am better off taking the set back and getting something else? Any suggestions are appreciated.
ddp3434 is offline
post #5 of 13 Old 03-27-2013, 05:50 AM
RWetmore's Avatar
Quoted: 414 Post(s)
Liked: 220
Try reducing the sharpness to zero or even using Custom Mode with the sharpness set to zero.
RWetmore is offline
post #6 of 13 Old 03-27-2013, 06:38 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 527 Post(s)
Liked: 782
The S60 so far is getting excellent early reports so we need more info:
1. How far are you eyeballs from the screen? ___________
2. What is your source? (Time Warner, U-Verse, DirecTV, OTA Antenna, etc)? ___________
3. What picture mode do you have the TV in? ___________
4. What channels are you seeing this problem on? ___________
5. What kind/size/brand of TV did you have before getting the 65S60? ___________
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #7 of 13 Old 03-27-2013, 08:56 AM
JSpectre88's Avatar
Liked: 54
JSpectre88 is offline
post #8 of 13 Old 03-27-2013, 09:27 AM
chunon's Avatar
Quoted: 2504 Post(s)
Liked: 2233
Did you take it out of "standard" mode that mode typically has the most noise. Try Cinema much better, custom will probably be a good mode with a basic cal.
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #9 of 13 Old 03-28-2013, 12:29 PM
ddp3434's Avatar
Thank you very much for the responses. Randy, here are the answers to your questions...
1. How far are you eyeballs from the screen? ____10-12ft_______
2. What is your source? (Time Warner, U-Verse, DirecTV, OTA Antenna, etc)? _____dish network______
3. What picture mode do you have the TV in? ___standard________
4. What channels are you seeing this problem on? __all channels have this problem with fast movements particularly sports however I noticed that when the station switches cameras the picture improves signifcantly but ultimately goes back to the "grainy" camera. For example, when watching CBS basketball, they have a left to right.right to left camera angle that they stay on for the majority of games, each player has a fuzzy outline. then when they go to an upclose shot or a bench shot or something else, the picture looks wonderful, then back to the left to right camera, back to fuzzy outlines_________
5. What kind/size/brand of TV did you have before getting the 65S60? ___I had just a 480i westinghouse and the picture on sports in particular was just as good as this one thus far._______
Thanks for any advice. Hopefully I can get it resolved, I really don't want to take the tv back to the retailer.
ddp3434 is offline
post #10 of 13 Old 03-28-2013, 04:49 PM
JSpectre88's Avatar
Liked: 54
post #11 of 13 Old 03-29-2013, 01:35 PM
mailiang's Avatar
Quoted: 970 Post(s)
Liked: 641
Originally Posted by JSpectre88 View Post
Have you tried the cinema mode? On most of these sets it comes closest to ATSC standards.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #12 of 13 Old 03-29-2013, 02:06 PM
JSpectre88's Avatar
Liked: 54
Ian
If it's anything like the GT50, then it's dreadful.
post #13 of 13 Old 03-29-2013, 03:20 PM
mailiang's Avatar
Quoted: 970 Post(s)
Liked: 641
I could say that about the custom mode on my C2.
mailiang is offline
