GT50 - Poor 3d qualitty and 'noise' on some of the HDMI inputs. Please help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 65 Old 03-21-2013, 07:17 AM - Thread Starter
swargolet's Avatar
Quoted: 58 Post(s)
Liked: 26
I've had my 55" GT50 for about 2 months now. Since day one I've noticed a couple issues. I ran the slides for 100+ hours the first week I got the TV and am using the settings found on the same site as the slides.
- The 3D looks awful. The colors all have a green/blue tint to them even with the glasses on and the contrast is abysmal. I understand making the picture brighter to offset the tint from the glasses, but the blacks end up looking way worse than my 5 year old LCD. The Samsung plasma I had before this didn't have this issue and I don't believe my parents VT50 has it either. Is this a common issue with the GT50? I don't see how anyone could watch 3D on this TV with it looking so bad.
- 2 out of the 4 HDMI inputs have a slight static / noise to them. HDMI 1 and 3 look fine. If I switch to that input with no video, then the screen is perfectly black. Input 2 and 4 has this noise which is red / green / blue that is all over the screen. This occurs with or without an HDMI cable plugged in and doesn't change by switching out cables. It isn't too noticeable when watching something unless it is a dark scene. Is this also a common issue with these TVs?
If these aren't normal, then would Panasonic repair / replace this under warranty or would they say it isn't enough to warrant that?
Denon X4000 | Paradigm Studio 60s | Paradigm Studio CC-590 | Dual SVS PB-2000s | Sony VPL-HW40es | 110" Seymour Ambient Visionnaire 1.3 | Intel NUC i5 HTPC
swargolet is offline
post #2 of 65 Old 03-21-2013, 10:32 AM
chunon's Avatar
Quoted: 2043 Post(s)
Liked: 1795
That doesnt sound normal at all I would get Panasonic out there, what is hooked up to HDMI 2 and 4. Sounds like your 3d settings are out of whack are you using DNice's settings there too ?
What are your setting for 2d and 3d ?
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 65 Old 03-21-2013, 05:30 PM - Thread Starter
swargolet's Avatar
Quoted: 58 Post(s)
Liked: 26
Just checked again and it looks like I was incorrect. Inputs 1,2, and 4 are all fine and 3 is the messed up one. Although I could have sworn that there were 2 messed up. Currently I have nothing plugged into it since it has this issue, but I'm worried about any future addition. I tried plugging something into it to see if it would change and it didn't
I included pictures below.
Inputs 1, 2, and 4 all look like this.
Here is input 3
I'm using his settings for 2d, but there were no 3d settings, so I just used the same ones from 2d. It looks like he now has 3d settings up for the VT50 so I may try those, but I doubt it will do much. The color temp is on warm2 yet it is still very very blue. Here are 2d vs 3d comparison shots. The camera makes the images a little brighter, but it is pretty accurate. You can see it mostly in the darker scenes how the colors have a very prominent blue tint and the blacks become washed out. I doubt I'll have to tell you which one is 2d and what's 3d, but I'll label them anyways.
2d Bright scene
3d bright scene
2d dark scene
3d dark scene
post #4 of 65 Old 03-21-2013, 05:56 PM
bullpuss's Avatar
Liked: 65
I have the 60 inch and its pure awesome..................i bought mine last year. I have heard that with many tv the earlier manufacture dates tend to be better than the later ones. Case in point the sharp elite and the sony hx850, both of which had defects on the later production dates. I am assuming its because they are planning to release the new model, so less focus is spent on quality control.........so whenever they make a new model i always try to get it early in production. Just my 2 cents.
bullpuss is offline
post #5 of 65 Old 03-22-2013, 05:34 AM - Thread Starter
swargolet's Avatar
Quoted: 58 Post(s)
Liked: 26
So this isn't common?
Others on this board must own the GT50 and can confirm if the 3d image looks correct or not.
post #6 of 65 Old 03-22-2013, 05:41 AM
adb
adb's Avatar
I have not encountered any problems with my GT50. Something is wrong, get in touch with Panasonic.
adb is offline
post #7 of 65 Old 03-22-2013, 06:18 AM
chunon's Avatar
Liked: 1795
You can't use 2d settings for 3d completely different settings, the glasses change the color and the greyscale, contrast and brightness will be completely different. That noise does not look normal to me, what is your source. Have you tried swapping out hdmi cables ?
65C6 OLED
post #8 of 65 Old 03-22-2013, 09:23 AM - Thread Starter
swargolet's Avatar
Quoted: 58 Post(s)
Liked: 26
The main issue I have with the 3d quality is the black levels as I can't seem to make them anywhere near the 2d levels. Like I said in my first post, the 3D black levels are on par with my 6 year old LCD. The blue tint just makes things worse. I'd expect the 3d quality through the glasses to look somewhat like the 2d quality without the glasses like all the other 3D tvs I've seen. But that just isn't the case. I'll try out D-Nice's VT50 3d settings this weekend to see if that helps.
At the time of the picture I had nothing plugged into it. It doesn't matter if I plug something in or use different cables though, that noise is always there. So that makes me believe it is the TV itself.
post #9 of 65 Old 03-22-2013, 09:27 AM
chunon's Avatar
Liked: 1795
The Gt50 is capable of producing an outstanding 3d picture so I suspect your settings. Have you tried THX 3d mode ?
65C6 OLED
post #10 of 65 Old 03-22-2013, 07:03 PM - Thread Starter
swargolet's Avatar
Quoted: 58 Post(s)
Liked: 26
Now that it is dark I tried some different settings. I don't seem to have a 3D THX setting, but Cinema seemed to produce the best picture out of the default ones. I also tried DNice's 3D settings that are for the VT50, but I dont have all the nice adjustments like the VT50, so there was very little to tweak. In the end it looked almost identical to Cinema.
So results... The blue's came down quite a bit, although it still has a blue tint but with the glasses on the colors are pretty close to 2d. Blacks are still bad though, especially compared to 2d. It the poor black level common for 3d on these TVs?
I took some pictures to show the differences between 2d, 3d without glasses and 3d with glasses. I was surprised out how accurate the 3d with glasses one turned out through the camera. The 2d looks incredible, but the 3d looks so washed out that the little benefit 3d provides is completely offset by the picture produced when using 3d.
2D
3D without glasses
3D with glasses
post #11 of 65 Old 03-22-2013, 07:06 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Can you post the settings for the hdmi that has the noise please? And you say that the noise is also apparent when you have something hooked up to that hdmi too? What modes were you using when you took the pictures? What are you using to play the movie?
sheshechic is offline
post #12 of 65 Old 03-22-2013, 07:36 PM
JSpectre88's Avatar
Liked: 54
Blacks aren't going to look as great as 2D, but they should still look pretty close. My blacks don't look like your 3D photo and I even use Vivid 3D settings. Your last picture almost looks even brighter than the one before it, so that can't possibly be accurate. Also, you should definitely have 3D THX Cinema, not sure what's up with that.
sheshechic likes this.
JSpectre88 is offline
post #13 of 65 Old 03-22-2013, 09:04 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
That's why I asked what he's using to play the 3D. Sumpin' ain't right.
post #14 of 65 Old 03-23-2013, 09:10 AM - Thread Starter
swargolet's Avatar
Quoted: 58 Post(s)
Liked: 26
You're right. That last picture does look a bit brighter. The camera must have automatically adjusted the exposure. Although the blacks are still pretty bad. I dont see why the TV has to make them that bad in the first place. I understand bringing up the brightness a bit to offset the tint from the glasses, but not by this much.
Figured out why I didn't have the 3D THX settings. They aren't available through DLNA and that is how I watch most of my movies. I popped in a blu-ray and that has the 3D THX settings. Can't tell really how it looks though as there is a lot of ambient light coming in since it's really sunny out. So this might solve the 3D issues. Not too sure what is going on with the noisy input though. I checked the cables again and now I remember that HDMI 1 for sure used to be noisy, as well as HDMI 3. I wanted to use the ARC feature since my receiver supports it, but that input looked really bad with the noise so I used HDMI 2. Now for some reason it looks fine and it is only HDMI 3 that has the noise.
I use DNice's settings for 3d and 2d except I have motion smoother on the lowest setting. I use the same settings on every input including the 'noisy' one
post #15 of 65 Old 03-23-2013, 09:56 AM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Thanks for posting your settings but since they are D-Nice's and he's asked that they not be posted, would you mind removing them? TIA
Hdmi 2 on the GT is arc, the rest are not. As for your streamed 3D... streaming is never as good. Most likely the noise you saw was related to not having anything attached, or is there noise when you attach an hd source to hdmi 3 and how far away do you have to be to see it?
post #16 of 65 Old 03-23-2013, 11:05 AM - Thread Starter
swargolet's Avatar
Quoted: 58 Post(s)
Liked: 26
The noise is always there. Doesn't matter what is plugged in (if anything) and different cables don't change it. From a distance, I can't see the individual dots, it more so looks like a haze and is really only noticeable in dark scenes. I feel like if the 3D concerns are common, then this noise alone isn't enough to have Panasonic check it out.
post #17 of 65 Old 03-23-2013, 11:11 AM
JSpectre88's Avatar
Liked: 54
That brightness is too high for Custom, it needs to be around 48. You're right though, even with the glasses the blacks are a bit brighter on 3D.
post #18 of 65 Old 03-23-2013, 11:42 AM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Can you see it with 1080 content too? It's more common with non HD sources. Try turning down brightness one click at a time checking to see if there's a change. Some people like brightness below 50 but if it's too low then you've got crushed blacks. Shadow detail is more important to me and IMO the GT can handle brightness slightly above 50 with 1080 sources just fine. SD is the worst offender, I hate that crap in my blacks/dark areas, but I've got Charter and some of our channels aren't even digital yet, let alone hd.
post #19 of 65 Old 03-23-2013, 12:09 PM
JSpectre88's Avatar
Liked: 54
IIRC, you need to have brightness below 50 to get a full black screen with no noise.
post #20 of 65 Old 03-23-2013, 12:15 PM
chunon's Avatar
Liked: 1795
That is of course if you're okay crushing blacks
65C6 OLED
post #21 of 65 Old 03-23-2013, 12:19 PM
JSpectre88's Avatar
Liked: 54
post #22 of 65 Old 03-23-2013, 12:22 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
You didn't really pay attention to what I said.
post #23 of 65 Old 03-23-2013, 12:23 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
be careful, you're showing a tad bit of ignorance and I tend to think you're not that dumb. wink.gif
post #24 of 65 Old 03-23-2013, 12:27 PM
JSpectre88's Avatar
Liked: 54
I was still talking about 3D. I suppose you weren't.
post #25 of 65 Old 03-23-2013, 12:28 PM
JSpectre88's Avatar
Liked: 54
Except that's what any calibrated settings give you, a full black screen w/ no noise. rolleyes.gif
Tell me I'm wrong?...
post #26 of 65 Old 03-23-2013, 12:34 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
If you're crushing blacks then your set is not properly calibrated.
You say you understand abl, if this is true then understanding the implication of crushed blacks shouldn't be too hard. What is the point of shades of grey if you're going to shut them all down and create a blob of black?
BTW: this is why you'll often see that I've written that shadow detail is very important to me.
post #27 of 65 Old 03-23-2013, 12:35 PM
JSpectre88's Avatar
Liked: 54
I'm talking about when displaying a full black screen. (Using a 0/0/0 colored slide, etc.)
What did you think I was talking about? lol
post #28 of 65 Old 03-23-2013, 12:54 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
What are you using a full black slide for?
post #29 of 65 Old 03-23-2013, 01:05 PM
JSpectre88's Avatar
Liked: 54
Just a point of reference. His 3D brightness was too high.
post #30 of 65 Old 03-23-2013, 01:29 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
That's what I was asking, reference for what?
I think I understand that you're saying that no dithering with a pure black slide but that has nothing to do with determining if you're crushing blacks. Not crushing blacks is important, more important.
Panasonic Viera Tc P65gt50 Plasma Tv
