Panasonic 55st50 Turns off mysteriously. Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-23-2013, 05:00 PM - Thread Starter
joecar's Avatar
My 55st50 is turning off then on randomly when there's a fluctuation in the signal, like between commercials or when switching picture modes, especially when trying to switch to game mode. Some times it happens when I exit out of a recording on my DVR. I've tried plugging the tv into different outlets and I've even reset the tv by doing the System Check power down thing. Anybody got any ideas?
joecar is offline
post #2 of 9 Old 03-23-2013, 06:32 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
What is your set up?
sheshechic is offline
post #3 of 9 Old 03-23-2013, 08:28 PM - Thread Starter
joecar's Avatar
Cable box to hdmi 1, ps3 to hdmi 2. Is that what you mean?
joecar is offline
post #4 of 9 Old 03-23-2013, 09:36 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Yes. I was hoping that you had an avr in between that might be causing a handshake issue. Does it do it with the PS3 too? If it doesn't then you might want to try swapping out your cable box.
post #5 of 9 Old 03-23-2013, 10:27 PM - Thread Starter
joecar's Avatar
Yeah, it's the same with the ps3. It seems that when there's a slight signal interruption it happens, which is why I specifically mentioned going to game mode, cause there's always been a slight pause, on every input, when game mode is selected.
joecar is offline
post #6 of 9 Old 03-23-2013, 10:32 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
post #7 of 9 Old 03-23-2013, 11:46 PM - Thread Starter
joecar's Avatar
Boom.
joecar is offline
post #8 of 9 Old 03-24-2013, 08:52 AM
Steve S's Avatar
Liked: 46
Is the tv actually shutting down (does the red "on" indicator light turn off and on) or is the screen just going blank for a few seconds)? Many sets go blank screen for a few seconds when the input resolution changes.
Steve S.
Steve S is offline
post #9 of 9 Old 03-24-2013, 10:00 AM - Thread Starter
joecar's Avatar
The red light turns off, and then the box that tells you which input your using comes up.
joecar is offline
Panasonic Viera Tc P55st50 55 Inch Plasma Tv
