Panasonic ST50 no sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-24-2013, 12:06 PM - Thread Starter
wizardofozz47's Avatar
I had to send my Pioneer in for repairs, so for the time being any audio must come directly from the TV speakers. The problem is that I cannot get any audio signal from the TV. I've made sure that the TV Speakers are set to ON in the Advanced audio menu, mute is off, volume is up high enough that it would be audible. I am using HDMI sources only, so the inputs are set to Digital sound. I've run out of ideas. Does anyone have a solution?
wizardofozz47 is offline
post #2 of 6 Old 03-24-2013, 12:38 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
When you were routing audio through your AVR did you have your ST50's Setup > Viera Link setting set to ON by any chance?
And if it was set to ON, did you have the Default Speaker setting set to Theater? If so, change them from Theater to TV and see if that enables the TV's onboard speakers.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 6 Old 03-24-2013, 01:14 PM - Thread Starter
I actually had not changed anything in that menu but I did check as you suggested. The settings had Viera link 'ON' and the Default speakers set to 'TV'. Perhaps I should mess with this stuff when I actually get my AVR back but for now I still can't get any sound out of the onboard speakers.
post #4 of 6 Old 03-24-2013, 03:52 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
Hmmm. You can test the speakers by selecting the Media Player and running a photo slideshow, then access the Slideshow settings and select one of the soundtrack Music selections in the menu - the music will play through the speakers.
Some other things to try . . . .
Do the speakers work if you use the TV's internal tuner (antenna or basic cable)?
Have you tried
Have you tried any non-HDMI sources Component or Composite Video input to see if you get any sound from the speakers?
Have you tried a different HDMI cable to rule out a bad cable?
Do your HDMI sources have their own audio output settings that need to be changed?
Randy
post #5 of 6 Old 03-25-2013, 09:14 AM - Thread Starter
I tried playing an Mp3 from a USB drive and the speakers work! Thanks for the suggestion. At least we know it's not broken. I've tried different sources (Cable box and PS3) with different cables and different inputs. I still cannot get sound from those HDMI sources. I would try your suggestion of the component video but I don't have anything on hand that uses it.
post #6 of 6 Old 03-25-2013, 06:45 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
Well at least you know the speakers are not broken. There still may be another failure in the TV. If you've "hot-swapping" the HDMI cables into the TV while it's turned on then that can sometimes damage the HDMI Input Board. The TV should be turned off or unplugged when you fiddle with the HDMI cables.
Do you have any analog devices (old VCR or DVD Player, digital or video camera, etc) with a red/white RCA audio output that you can connect and change your HDMI-In audio from Digital to Component/Composite Video so see if you get any analog audio through that input?
Doesn't your Cable Box have Component or Composite Video outputs with red/white audio outputs?
Do you have another TV with HDMI inputs that you can test your cable box and PS3 on to see if it gets audio from their HDMI outputs?
You could try unplugging the TV for a few minutes in the hope that it will somehow "reboot" it.
Randy
