Pioneer Kuro type 427XA, blink 6 times, what is the problem? - AVS Forum | Home Theater Discussions And Reviews
Old 04-04-2013, 09:43 AM - Thread Starter
Alex400's Avatar
I have a Pioneer Kuro type 427XA which is defect. I just installed a new Ysus since I got the 6 times red led error.
In the service manual it says:
Y DCDC PD Y DRIVE Assy:
Abnormality in the VOFS DC/DC converter
Abnormality in the VPRST DC/DC converter
Abnormality in VC_15V DC/DC converter
Where is the Y DCDC, located? Because it is on the Ysus right?
I downloaded the manual here:
http://elektrotanya.com/pioneer_pdp-427_4270_xa-xd_sm.pdf/do...nload.html
Who can help me further, maybe this is a known problem or there might be something else wrong. I can't see anything abnormal visually.
So no popped caps or something.
Alex400 is offline
Old 04-04-2013, 04:44 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Do you have the part # for the Y-Drive (AMV####?)
I think this is it:- http://www.shopjimmy.com/pioneer-awv2334-display-drive-assy.htm
It may be cheaper/easier to replace the entire Y-Drive assy for $60.
tom669 is offline
Old 04-04-2013, 11:11 PM - Thread Starter
Alex400's Avatar
I did buy a brand new Y drive but the problem is still there. Maybe some other members know this problem.
I heard also things about defect scan ic's. (lower and upper ic drives)
Alex400 is offline
Old 04-05-2013, 12:46 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
You may have a Y SCAN A or Y SCAN B failure. To test them remove the boards, then follow this video:
https://www.youtube.com/watch?v=51SZsfH60EY
tom669 is offline
Old 04-05-2013, 05:01 AM - Thread Starter
Alex400's Avatar
Yes I found the problem, it were one or more defect scan IC
This one is broken for sure.
Now the problem. It seems that the bands of the screen is glued to the bufferboards. I am used to bufferboards with connectors.
Can I replace the bufferboards on this screen?
Who can help me further?
Alex400 is offline
Old 04-05-2013, 06:25 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
I don't think you can replace the board.
However, the IC itself may be replaced for relatively little:
http://www.ebay.co.uk/sch/i.html?_odkw=sn75587&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0&_nkw=sn755870&_sacat=0
Good soldering skills will be necessary.
tom669 is offline
