My Samsung Plasma has light along the right edge, with black splotches. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-05-2013, 01:57 AM - Thread Starter
Bmvc1's Avatar
Don't know how else to describe it. Really don't know much about Plasmas. It's a Samsung PN51E530
It is only noticeable when the screen is black, and even then you have to really look. It's almost like there is a very light dark tint over the pixels in that spot, but they all work. I have no idea what it is though, if it is something that will stay exactly like it is, I can easily look past it. I'm not sure if it an issue that will get worse over time though.
Any ideas on what this could be?
The picture makes it look worse than it does to the human eye.
Bmvc1 is offline
post #2 of 5 Old 04-05-2013, 02:42 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Looks like panel gas leakage to me, very rare but can happen. If not, it could be a Ve/Vsc/Vset voltage problem but it was my understanding that this is rare on these panels as they are less dependent on such voltages being within close tolerances, unlike older PDPs. Get it fixed under warranty before it gets worse IMO.
tom669 is offline
post #3 of 5 Old 04-05-2013, 03:07 AM - Thread Starter
Bmvc1's Avatar
Is that a serious issue? Is it something that can be easily repaired.
Bmvc1 is offline
post #4 of 5 Old 04-05-2013, 04:49 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
If it is what I think it is (gas leakage) then no, you cannot fix it on your own. Does it affect white or bright images too? If it's only dark images it might be something you could fix if you took the back cover off -- but only if your warranty was up, as it should be fixed by Samsung otherwise.
tom669 is offline
post #5 of 5 Old 04-05-2013, 05:07 AM - Thread Starter
Bmvc1's Avatar
It's really only noticeable on solid black images. Color and white images it can be seen if you are extremely close and know exactly where to look. The splotches you see in the picture I posted seem to be a very VERY slight shade darker than the rest of the picture.
I bought it from Blinq.com. It was an open box item with a 90 day warranty. I have never had to use a warranty for an online purchase before, do you know if most places have you ship the item back, or do they use a local authorized repair service?
Bmvc1 is offline
