Pnasonic tcp50ut50 Horizontal Screen Ratio adjustment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-06-2013, 10:55 AM - Thread Starter
FlyingDutch's Avatar
I have bought a bigger TV moving from an LCD to Plasma. Great picture but some of the stations have their screen displays way on the right or left edge and it is not showing up.
I have tried different screens and " Full " and " screen 2 " seems to be the closest but can't improve it enough.
Some of the threads seem to say that's a Vierra common problem and referring to the service mode to turn the overscan off but I have not found anything there that jumps out adjustment wise .
Any idea's before I mess up the TV settings?
FlyingDutch is offline
post #2 of 3 Old 04-06-2013, 11:02 AM
Ph8te's Avatar
Quoted: 4543 Post(s)
Liked: 3975
1st what is the source of your signal? Cable\ota\sattelie? You need to make sure that the aspect ratio is set up correctly there are well wink.gif
The "Full" setting is what you want....once that is complete make sure your settings on your signal source are set correctly as well
Ph8te is offline
post #3 of 3 Old 04-06-2013, 04:40 PM - Thread Starter
Its Satellite. setup for 1080 I and 16:9 ratio.
Panasonic Viera Tc P50ut50 50 Inch Plasma Tv
