Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-06-2013, 02:29 PM - Thread Starter
jbrownster79's Avatar
Hi guys I have a Panasonic TX-P42S31B a few weeks ago we noticed it buzzing on light screens which it had never done before it was brought December 2011 new I came home tonight switched it on got two clicks the green led flashed 10 times then another click and nothing it had switched off I wouldn't mind if it got a lot of use but it gets used about two hours a day!! Any help would be appreciated many thanks justin
jbrownster79 is offline
post #2 of 7 Old 04-06-2013, 05:38 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
tom669 is offline
post #3 of 7 Old 04-06-2013, 11:13 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
He's got bigger problems than buzz.
Jbrownseter check this thread: http://www.avsforum.com/t/1001318/master-thread-for-panasonic-plasma-not-turning-on
sheshechic is offline
post #4 of 7 Old 04-06-2013, 11:33 PM - Thread Starter
Thanks guys I have checked again this morning and tried to count the led blinks I think it's actually 7 they blink really fast. I don't want to go and buy another TV if its an easy fix but it has put me off panasonic
post #5 of 7 Old 04-07-2013, 12:14 AM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Well 7 seems to indicate power supply. That could happen on any set, no matter the manufacturer. wink.gif
post #6 of 7 Old 04-07-2013, 12:55 AM - Thread Starter
Thanks sheshechic is there anywhere I can get a digram so I can test the power board to know what I should be expecting?
post #7 of 7 Old 04-07-2013, 05:13 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
7 blinks is SC, SU or SD. Very common with this model. NOT power supply, which would be none (no power), 2, 4 or 10 blinks.
You need to take the cover off and tell us the part #s of the boards, take pictures if you are not sure.
The buzzing is caused by the loose/dirty/bad screws, what I have heard though is that eventually if unchecked it can damage the board.
tom669 is offline
Panasonic
