Panasonic UT50 3D bad? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-06-2013, 10:22 PM - Thread Starter
Dizzy714's Avatar
Quoted: 63 Post(s)
Liked: 27
Just trying to verify if this is my set specifically, but the 3D on this thing is just bad. There's hardly a difference between 2D to 3D conversion and a true 3D signal/movie. Bought Avatar to go with the set, and there's so many parts that you can tell are intended to jump out of the screen at you. How I would have to describe the 3D on this thing is just simply added depth, that's all really - nothing pops out an inch out of the screen, just depth in the picture. Is this normal for this set, or no?
Dizzy714 is offline
post #2 of 5 Old 04-06-2013, 10:35 PM
dabsac's Avatar
Quoted: 29 Post(s)
Liked: 24
I don't have the same tv as you, but most of the 3d movies I have seen are like that "added depth". The guardians and Madagascar 3 have a really good 3d effect maybe try renting those and see if it performs more to your liking.
dabsac is offline
post #3 of 5 Old 04-06-2013, 10:59 PM - Thread Starter
Dizzy714's Avatar
Quoted: 63 Post(s)
Liked: 27
Thanks for the reply, I'll try this as soon as possible. It's just some movies I have watched you can just tell in certain scenes you're supposed to be seeing out of screen-like 3D, but it just doesn't deliver like that.
Dizzy714 is offline
post #4 of 5 Old 04-07-2013, 05:30 PM - Thread Starter
Dizzy714's Avatar
Quoted: 63 Post(s)
Liked: 27
Bump on this thread, for second opinions.
Dizzy714 is offline
post #5 of 5 Old 04-07-2013, 10:35 PM
JSpectre88's Avatar
Liked: 54
Avatar is a great example of 3D depth, but not very intense pop out. With that said, there's a lot of instances where Avatar extends beyond the screen, but only a few inches, six inches to a foot at the very most. Maybe you were just expecting it to come right out of the screen toward you? There's maybe one or two exciting moments, but for the most part, that's not Avatar. Even when it's just subtle though, I can distinguish what's actually popping out of the screen from the depth inside the screen very easily.
JSpectre88 is offline
Madagascar 3 Europes Most Wanted Blu Ray
