Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 127 - AVS Forum | Home Theater Discussions And Reviews
 246Likes
post #3781 of 16778 Old 07-25-2013, 07:36 PM
fmalczewski's Avatar
Quoted: 101 Post(s)
Liked: 39
Originally Posted by loopaddiction View Post
Like HDMI cables, most name brand mounts are way overpriced with large profit margins from the companies/retailers. You can find equally rugged and reliable mounts for much cheaper than that Sanus, for instance.
I have the 65VT60 mounted on this $28 VideoSecu from Amazon: http://www.amazon.com/electronics/dp/B000NMFCIA
It's rated to hold up to 160 pounds (the 65VT60 is ~90 pounds) and it works perfectly fine. The only caveat is that the arms go to very the edges of the mount, so there's no room to slide the TV left or right. It's still very secure but you just need to make sure the mount is centered the way you want when installed on the wall. This can be a little tricky depending on the location of the wall studs. If this is an issue, there should be wider mounts available on Amazon for cheap.
For now my new set is going onto a small, very wide table where current set of similar size resides. Would like to do wall mount, but... is there any non-ugly way to do it without routing wires through the wall? (I.e., probably straight up from the floor, 3 hdmi cables and one power cable presumably, probably a(n audio) coax cable as well.)
(Maybe a winter project to do something more elaborate than the table option...)
Other option would be a less wide and perhaps taller table (current tv's "stand" is 3+ ft wide), maybe even a cube of some sort. How wide is the stand (spec says it's a bit over a foot deep)?
fmalczewski is offline
post #3782 of 16778 Old 07-25-2013, 07:58 PM
corporate's Avatar
Originally Posted by dmjung View Post
VT60 DNLA functionality - I'm using this to listen to music from a PC in the other room (because I want to.)
Unfortunately, it looks like there isn't any kind of screen blanking / window-saver type option so the song/album's displayed text just sits in the middle of the screen. Since this text doesn't change much over time I'm thinking this isn't a good thing for extended listening. Any ideas or anyone know of a way to automagically blank the display after a period of time (but still have everything running)?
After 5 minutes the screen should go black with just the track/album info box remaining and then that moves every few seconds around the screen.
corporate is offline
post #3783 of 16778 Old 07-25-2013, 08:47 PM
JordynGary's Avatar
JordynGary is offline
post #3784 of 16778 Old 07-25-2013, 08:57 PM
Rpezz50's Avatar
Originally Posted by JordynGary View Post
If you like floating blacks go with the F8500 lol. And between the VT and ZT both are the same PQ I can't see spending $500 because of the way the install the panel and there for you get less light output.
Rpezz50 is offline
post #3785 of 16778 Old 07-25-2013, 09:29 PM
KONICA TECH's Avatar
Quoted: 25 Post(s)
Liked: 54
Spent a lot of research time with the ZT60 and VT60. One thing I noticed is with both sets at a very close
settings, the ZT60 runs a lot hotter. And I mean a lot. The VT60 was cooler than even last years VT50 that
I sent back because it was to much heat in my room. Unfortunately I cannot comment on the ST60 as they do not have
the 65" on display anywhere near me. Going to see if they have it on display at PAUL's  TV next week.
Myself, I do not see enough differance in picture quality between the VT / ZT to justify the cost differance.
If I am as happy with the ST as some owners are, I may go that route.
KONICA TECH is offline
post #3786 of 16778 Old 07-25-2013, 10:19 PM
Denniswrly's Avatar
Liked: 38
VT60 Calibrated Hands Down no debate end of story.... Cost is a factor go st60...I own vt60 smile.gifsmile.gifsmile.gif Look in Calibration section and see my reports the best Blacks and detail etc.
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
Dual recliner lazyboy
xbox 360
Denniswrly is offline
post #3787 of 16778 Old 07-25-2013, 10:26 PM
SamOner's Avatar
How often does IR occur on the 60VT60? If I play 2 hours of COD will I get IR?
SamOner is offline
post #3788 of 16778 Old 07-25-2013, 10:46 PM
jconjason's Avatar
Quoted: 518 Post(s)
Liked: 812
Those of you posting the price difference isn't worth it, keep in mind, the filter on the ZT is better at handling light reflection than the VT, so if you're in a bright room, it may be worth the extra cash. Other than that, PQ is equal.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
Klipsch B-20 Rears,PA 120 12" Sub,klipsch R-10SW
jconjason is online now
post #3789 of 16778 Old 07-26-2013, 12:06 AM
seffys's Avatar
seffys is offline
post #3790 of 16778 Old 07-26-2013, 01:42 AM
Ace_BB6's Avatar
How much success have people gotten with returning thier vt60s for a new set and gotten a unit without fan noise?
Im approaching my thirty days and not sure what to do.
Advice? Live with it or try my luck?
Ace_BB6 is offline
post #3791 of 16778 Old 07-26-2013, 02:31 AM
Tony1's Avatar
Quoted: 31 Post(s)
Originally Posted by grsmith317 View Post
The CNet review had their settings. Many people use them and only need to tweak a bit.
I really hope someone comes out with better settings than Cnet's. I tried them, with minor tweaks and wasn't satisfied at all.
Panasonic GT50 55"
Pansaonic VT60 60"
Tony1 is offline
post #3792 of 16778 Old 07-26-2013, 02:36 AM
Tony1's Avatar
Quoted: 31 Post(s)
I thought they all had fan noise? I think some people just don't hear it as much do to that acoustical properties of the room the tvs going in.. My old VT50 and my current VT60 both do it..
I think you may be just better off going with the ST60 if it's going to bother you that much..
Panasonic GT50 55"
Pansaonic VT60 60"
Tony1 is offline
post #3793 of 16778 Old 07-26-2013, 03:42 AM
sillysally's Avatar
Quoted: 828 Post(s)
Liked: 848
Originally Posted by LarryInRI View Post
1. On the remote, hit the green HOME button. Up arrow to highlight Home Screen selection. Click OK. You'll see three different screen types to select from.
2. Can't help you with the THX mode setting. I haven't had time to put a meter on it yet.
Larry
THX is a locked mode.. There is no need for a meter.
You can try raising contrast a few ticks, set sharpness to 0, leave color at 50, brightness you could raise by maybe 1 or leave at 0, turn off all enhancements. :wink.gif
ss
seffys likes this.
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #3794 of 16778 Old 07-26-2013, 04:40 AM
seffys's Avatar
ss
I will try it soon, I think I love the THX more then custom...
Maybe some custom calibration settings?
Thx
seffys is offline
post #3795 of 16778 Old 07-26-2013, 08:48 AM
kimolaoha's Avatar
Thanks for this. I note that the Monoprice mount is also about a 32" frame, so the same centering issue would apply to them.
kimolaoha is offline
post #3796 of 16778 Old 07-26-2013, 08:55 AM
Darklonerdad's Avatar
Hi All,
Have a 65VT60 and I was wondering if anyone are having problems plugging an external HDD via the VT60 USB inputs.
On the few times I did try I always get an error message and instructions to turn off/on the TV. The HDD is a 320G WD passport unit with USB2.0.
Regards.
Darklonerdad is offline
post #3797 of 16778 Old 07-26-2013, 08:56 AM
kimolaoha's Avatar
Google "Wiremold CMK30". Probably your best bet if you REALLY don't want to go in-wall.
post #3798 of 16778 Old 07-26-2013, 08:59 AM
kimolaoha's Avatar
Originally Posted by soldoutmatinee View Post
Menu > Picture > Screen Settings > Screen Display > Off
And then how do you get it back?
post #3799 of 16778 Old 07-26-2013, 09:43 AM
Vanguard223's Avatar
Was there a revision done to the TC-P65VT60 at any point in it's production? tvsuperstores.com has this TV for $2349.00 but when I called, they said that this is for a discontinued model and that the new revision (with the same sku number) is a higher price. He also stated that since this TV is discontinued, I can still order it but Panasonic only provides a 6 month warranty on discontinued models. He mentioned that the new revision improved the brightness. I have been reading around the Panasonic site but can't find anything about this. Is all of this true? Was there a revision to this T.V.?
Edit: I called tvsuperstores back for clarification and he said it wasn't a revision but that a Faroudja chip was added. I don't know anything about this and everything I read about it leads me to believe this is a sales ploy. Are all of the excellent reviews for this T.V. for the one WITH the chip or without it?
Vanguard223 is offline
post #3800 of 16778 Old 07-26-2013, 09:45 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2000 Post(s)
Liked: 2161
It is true but its not like the filter is a night and day difference.......
Cleveland Plasma is offline
post #3801 of 16778 Old 07-26-2013, 10:09 AM
Jeff_DML's Avatar
Please update this thread, I have fan noise and the panel buzzing during light scenes seem kind of bad(I have owned plasmas before). I have a week or so left in my 30 day window. I doubt I will return it so more interested in whether panasonic will do anything during the warranty.
Jeff_DML is offline
post #3802 of 16778 Old 07-26-2013, 10:46 AM
Quoted: 101 Post(s)
Liked: 39
Okay, in the cart for future consideration. (Same for the tiltable wall mount.) Thanks.
post #3803 of 16778 Old 07-26-2013, 10:47 AM
Rpezz50's Avatar
Yea but the ZT can't put out the light output of the VT due to the Studio panel.
Rpezz50 is offline
post #3804 of 16778 Old 07-26-2013, 11:05 AM
ab2ab's Avatar
I hope this turns out not to be the case as the Faroudja chipset made visible the undesirable effect of Macroblocking in plasma displays.
ab2ab is offline
post #3805 of 16778 Old 07-26-2013, 11:07 AM
Denniswrly's Avatar
Liked: 38
My son plays on average 3 hrs of Black Ops and i see no IR i do have over 600+ Hours on my 65vt60..just my set i'm talking imo,Others may have i have nothing ..No fan noise no IR ..I am in California ..and my tv is on a stand not wall mountded..smile.gifsmile.gif
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
xbox 360
post #3806 of 16778 Old 07-26-2013, 11:23 AM
Ace_BB6's Avatar
Many people have reported that they do not hear fan noise when the set has sound off. Which led me to assume it may not be as widespread. Ill most likely keep the set because you can only really hear
it when the sound is off or slightly during scenes of movie where there is little sound. My ocd gets the best of me I guess, but we all want what we paid for and so that is my issue.
Ace_BB6 is offline
post #3807 of 16778 Old 07-26-2013, 11:57 AM
Denniswrly's Avatar
Liked: 38
Ace_BB6 likes this.
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
xbox 360
post #3808 of 16778 Old 07-26-2013, 12:02 PM
tbass2k's Avatar
Thanks, will look into that....anybody with vt60 gone directly to panasonic for their fan issue?
tbass2k is offline
post #3809 of 16778 Old 07-26-2013, 12:03 PM
Coyote Waits
htwaits's Avatar
Quoted: 923 Post(s)
Liked: 2033
My best guess is that none of what you were told is true. I wouldn't go near that store mainly because they sound stupid. eek.gif
The only sets that are discontinued are those from previous model years, If there was a mid model revision or change to the 2013 Panasonic VT60 models, it would be known here.
htwaits is offline
post #3810 of 16778 Old 07-26-2013, 12:16 PM
Coyote Waits
htwaits's Avatar
Quoted: 923 Post(s)
Liked: 2033
Yes. It's too soon to know how effective the Panasonic fix will be. There should be reports in the near future. There doesn't seem to be anything wrong with the fans themselves.
tbass2k likes this.
htwaits is offline
Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Panasonic , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv
