Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 130 - AVS Forum | Home Theater Discussions And Reviews
 246Likes
post #3871 of 16778 Old 07-29-2013, 07:33 PM
Denniswrly's Avatar
Liked: 38
Originally Posted by DavidHir View Post
The VT60 is definitely not on target out-of-the box and every unit will drift over time requiring re-calibration. smile.gif
i watch thx cinema till i saw the drift between 300+ to 400+ then D-nice came and OMG amazeing calibration and tv PQ is just "Loss for words " $$$$$ well spent imo smile.gifsmile.gifsmile.gif
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
Dual recliner lazyboy
xbox 360
Denniswrly is offline
post #3872 of 16778 Old 07-29-2013, 07:39 PM
Denniswrly's Avatar
Liked: 38
I did not post that that many times omg sorry...
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
xbox 360
post #3873 of 16778 Old 07-29-2013, 08:22 PM
con219's Avatar
Quoted: 61 Post(s)
Liked: 51
Tried this on my set and no issue whatsoever. Mine is the Aussie model manufactured May 2013
con219 is offline
post #3874 of 16778 Old 07-29-2013, 08:23 PM
con219's Avatar
Quoted: 61 Post(s)
Liked: 51
Originally Posted by Nyloc View Post
Tony1
I have the same "problem" with the jump from +13 to +14 and thought it was just my set.
FWIW ...
See my experience above
con219 is offline
post #3875 of 16778 Old 07-29-2013, 08:36 PM
con219's Avatar
Quoted: 61 Post(s)
Liked: 51
Originally Posted by Cleveland Plasma View Post
Calibration is a choice, some units out there are very close to being on target right out of the box, however ever unit is different.........
Can someone please explain why this is so?
Or is this another urban myth? All components used in the sets are identical. all panels are made with the same materials and identical manufacturing process. Is it the environment the set is in rather than the set itself
that contributes to the variation in perceived picture.
With the exception of a faulty component/s causing variations is this notion that all sets look "different out of the box " just another urban myth.
con219 is offline
post #3876 of 16778 Old 07-29-2013, 08:40 PM
DavidHir's Avatar
Quoted: 1705 Post(s)
Liked: 1326
No set is ideal out of the box. Yes, sets are generally better out of the box compared to years ago, but every set needs a full calibration for optimization and accuracy; and every set drifts over time (especially phosphor based displays although LEDs are not immune either).
DavidHir is offline
post #3877 of 16778 Old 07-29-2013, 08:43 PM
Coyote Waits
htwaits's Avatar
Quoted: 921 Post(s)
Liked: 2030
No it's not a myth. Professional calibration results in different setting for each example of a particular model. It's probably impossible to build two sets with identical characteristics on purpose. All components, that make up a TV, are built to some given range of acceptable specifications. Even if it was possible, no one could afford such an item.
htwaits is offline
post #3878 of 16778 Old 07-29-2013, 08:46 PM
DavidHir's Avatar
Liked: 1326
I too used THX Cinema before Chad B came out and no question, huge difference afterward. smile.gif
DavidHir is offline
post #3879 of 16778 Old 07-29-2013, 09:09 PM
ttnuagmada's Avatar
Quoted: 116 Post(s)
Liked: 111
So, I'm looking at getting a VT60 to replace my ST30, and I was curious about screen uniformity on this years models. Has anyone seen any of the green/magenta or green blob uniformity problems that the 2011 models had?
ttnuagmada is online now
post #3880 of 16778 Old 07-29-2013, 09:39 PM
DavidHir's Avatar
Liked: 1326
My VT60 has better uniformity than my ST30.
DavidHir is offline
post #3881 of 16778 Old 07-29-2013, 10:07 PM
soldoutmatinee's Avatar
Originally Posted by kimolaoha View Post
Regarding temporarily turning the VT60's Display OFF . . .
Thanks. But I could never even get as far as turning the VT60's screen back ON, because oddly the system would not allow me to turn it OFF in the first place!
I tried the following sequence
Menu > Picture > Screen Settings > Screen Display > Off
last night in order to kill the screen while listening to one of Comcast's ad-supported music channels, and was able to get as far as the screen with On and Off selections,
but every time I got to the On or Off and arrowed down to OFF, the TV immediately bounced the selection back to ON!!
In other words, it would not let me select OFF . . .
What??!!
And this function definitely works for you?
Maybe I need to try it with a different feed -- this was a music channel recorded and played back via TiVo.
Any thoughts, as I'd really like to temporarily kill the screen in such situations (I don't need IR permanently advertising Bosley Hair Restoration Centers!).
hmmm this function definitely works for me as i use it all the time. the screen completely turns off and the only thing left on are the tv speakers or surround sound, depending on which i'm using. also the red indicator light also stays on when you use this feature.
i've used this feature while "watching" several over-the-air broadcasts connected by coax, streaming music via apple tv by hdmi, and streaming music using the dlna feature in the apps menu. i do not have a tivo connected to the tv so i can't say for sure if this feature is not working because it's something in the tivo. maybe someone else here can check for you that has a tivo if it works for them?
soldoutmatinee is offline
post #3882 of 16778 Old 07-29-2013, 11:08 PM
fmalczewski's Avatar
Quoted: 101 Post(s)
Liked: 39
Originally Posted by Rpezz50 View Post
Ok I understand so you are using 2 bd players? An Oppo and a Panasonic? Does the Panasonic have 2 HDMI port? Yea 24p will only work with a blu ray disk.
Aged, region locked, Panasonic BD35 for Region A blu-rays (it only has one hdmi output and pre-dates 3D), Oppo 93 for everything else (it has the two hdmi outputs). Oppo direct to the tv (for video), Panasonic thru the receiver (audio and video). Have a couple other players (dvd+sacd+dvd-audio+cd, hd-dvd) that I'm on the verge of retiring, but haven't quite managed to convince myself that I'm done with them yet, they too are routed solely through the receiver; the hd-dvd player supports 1080p/24 also.
My recent theory is that the tv is finding the receiver to be hdmi 1.1, and has decided that hdmi 1.1 did not support 1080p -- which of course is not correct since it's been running 1080p for several years -- and that's where the 1080i is coming from when the Panasonic bd player finally gets (automatically) set up. Maybe I'll try the Oppo's video (plus audio) thru the receiver to see what it does (maybe it will be luckier), since it is already hooked up to it...
But, I'm sort of okay enough with this for a while, I'll just play around with it occasionally to see if I can come up with a different solution or maybe a different theory. Or maybe I'll just end up going single Oppo only and heck with it. Want the receiver to be treated as 1080p by default however, not 1080i.
fmalczewski is offline
post #3883 of 16778 Old 07-30-2013, 02:04 AM
Duskstench's Avatar
How does the VT60 differ from the ZT60? apart from the air gapless design I get the feeling they are very similar picture wise
Duskstench is offline
post #3884 of 16778 Old 07-30-2013, 02:23 AM
Tony1's Avatar
Quoted: 31 Post(s)
Mine is not good at all with any of the presets..
Panasonic GT50 55"
Pansaonic VT60 60"
Tony1 is offline
post #3885 of 16778 Old 07-30-2013, 02:26 AM
Tony1's Avatar
Quoted: 31 Post(s)
From everything Ive heard, the ZT60 does better in a bright room, it cuts reflections and light better.. In a dim room, they are said to be the same, picture qualitywise. I believe the Zt60 has a bit less light output too..
Panasonic GT50 55"
Pansaonic VT60 60"
Tony1 is offline
post #3886 of 16778 Old 07-30-2013, 02:34 AM
Tony1's Avatar
Quoted: 31 Post(s)
Tony1
FWIW ...
I think that problem may lie in more sets than people here know about, but I think no one is bothering to check it out on their sets.eek.gif.
Panasonic GT50 55"
Pansaonic VT60 60"
Tony1 is offline
post #3887 of 16778 Old 07-30-2013, 06:55 AM
smurraybhm's Avatar
Quoted: 1474 Post(s)
Liked: 1765
An issue with sound when setting the treble at +14 may not be on the radar of most of us who own a VT. I don't see myself ever setting it that high and I can count the time I have used the tv's speakers on one hand in two months. Not something I will lose sleep over, but congrads on the discovery.
RIP Cricket - my pug and little buddy Jan. 10, 2017
Panasonic 60VT60 (cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 w/ 2500+ blu-rays and growing. Yes I still have HD-DVDs too.
smurraybhm is offline
post #3888 of 16778 Old 07-30-2013, 09:40 AM
kimolaoha's Avatar
Re. temporarily turning the VT60's Display OFF using Menu > Picture > Screen Settings > Screen Display > Off . . .
sold out matinee said . . .
Thanks for the response. I'll play with it using the Blu-Ray and the native Viera Apps, and see if the TiVo is somehow causing the set to disallow SCREEN OFF commands. Weird. Anyone else with a TiVo care to give it a go? For reference, I do not use Comcast's HD set top boxes, as the TiVo(s) instead use Comcast's Multi-stream Cable Cards.
kimolaoha is offline
post #3889 of 16778 Old 07-30-2013, 11:09 AM
grsmith317's Avatar
A total SWAG but do you have HEC turned on (Viera connect) and the TIVO box somehow signals the display stay on? Don't know if this is even possible. If you turn off Viera connect does the screen blank then work? Maybe this has been suggested earlier in the thread.
grsmith317 is offline
post #3890 of 16778 Old 07-30-2013, 11:12 AM
grsmith317's Avatar
I'll be getting my set delivered this Saturday. Although I will not be using the TV speakers, I'll check this out to see if it happens on mine also.
post #3891 of 16778 Old 07-30-2013, 11:16 AM
Esteban Medaglia's Avatar
Quoted: 27 Post(s)
Liked: 38
Just turned on my 65VT60 and it informed me that there's a new firmware update. Does anybody know what it includes?
Esteban Medaglia is offline
post #3892 of 16778 Old 07-30-2013, 11:19 AM
defjamz's Avatar
Quoted: 43 Post(s)
Liked: 113
There was a new firmware update this morning for my VT60. I was in a rush to get to work, so I didn't get the exact number (2.858?) of the version. Anyone happen to know what the firmware update addresses? Wishful thinking, but I thought maybe it might turn down the 'fan curve' slightly to addess some the fan noise. I put some magnetic fan filters on the back of my panel, and that helped out slightly. Or maybe I'm just getting used to the fans, and not noticing them anymore.
Rec Room: Sony 75X940C/Yamaha A1050/Oppo UDP203/Klipsch RP280F, RP450C, RP140 Atmos, Definitive SM350/SVS SB2000/PS4
Living Room: Sony 75X940D/Yamaha A730/Samsung K8500/Definitive BP8040, BP6/Martin Logan Dynamo1000/Xbox One S
Bedroom: Samsung 75HU8550
defjamz is offline
post #3893 of 16778 Old 07-30-2013, 01:40 PM
jconjason's Avatar
Quoted: 518 Post(s)
Liked: 812
Firmware update 2.858
"us13's peaks soft update"
Whatever that means. I looked online and couldn't find anything.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
Klipsch B-20 Rears,PA 120 12" Sub,klipsch R-10SW
jconjason is offline
post #3894 of 16778 Old 07-30-2013, 01:46 PM
Jeff_DML's Avatar
I am hoping they fixed the miracast support.
Jeff_DML is offline
post #3895 of 16778 Old 07-30-2013, 01:54 PM
jconjason's Avatar
Quoted: 518 Post(s)
Liked: 812
From an "insider" on another forum, its a Viera Connect update for VT and ZT models.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
post #3896 of 16778 Old 07-30-2013, 05:44 PM
cbragwel's Avatar
I saw the VT60 65" setup at Bestbuy and watched some content on the different picture options, I thought the THX picture was gorgeous. I guess I couldn't imagine what a professionally calibrated screen would look like.
cbragwel is offline
post #3897 of 16778 Old 07-30-2013, 05:49 PM
Coyote Waits
htwaits's Avatar
Quoted: 921 Post(s)
Liked: 2030
If you read customer reports using the link in the signature area at the bottom of my post, you'll find your statement repeated many many times. wink.gif
The flat panel reports are in the second post. I'm not saying that you would have the same experience, but it is a common one. For instance, almost everyone thinks their new display looks a lot better at home than the the floor model in a show room. There is always room for better. biggrin.gif
htwaits is offline
post #3898 of 16778 Old 07-30-2013, 06:46 PM
cbragwel's Avatar
Oh, sorry... and thanks.
cbragwel is offline
post #3899 of 16778 Old 07-30-2013, 06:51 PM
Denniswrly's Avatar
Liked: 38
Don't be sorry .I'm sure just pointing you to read more people talk..But i own 65vt60 and had it Pro Cal By D-nice and Was glad i did Looks amazeing.People look at and say WOW!! But to each his or her own....Good Luck smile.gifsmile.gifsmile.gifsmile.gif
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
xbox 360
post #3900 of 16778 Old 07-30-2013, 07:53 PM
mo949's Avatar
Liked: 1114
I've said these exact words about 6 months ago.
mo949 is offline
Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Panasonic , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv
