Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 142 - AVS Forum | Home Theater Discussions And Reviews
 250Likes
Old 08-14-2013, 11:28 AM
DavidHir's Avatar
Quoted: 1774 Post(s)
Liked: 1386
Does anyone know if the MLL is any different between 60hz and 96hz?
I thought I heard somewhere it was a hair better at 96hz. However, I see flicker on brighter scenes and occasional weird motion artifacts with 96hz and these are not seen at 60hz.
DavidHir is online now
Old 08-14-2013, 12:59 PM
smurraybhm's Avatar
Quoted: 1533 Post(s)
Liked: 1874
Originally Posted by ab2ab View Post
For those of you who have 1,000 or more hours on your sets, have you noticed a greater susceptibility to IR? I'm asking because there are reports in the ST60 forum that highlight a developing pattern of the loss of IR resistance somewhere after the 500 hour mark.
Regarding the panel heat related topic (ST v. VT/ZT), I've read accounts where the ZT was noticeably hotter to the the touch than the ZT. Does anybody know the nominal operating temperature of each 60" model? Personally, I prefer passive heat dissipation over fans (moving parts) in electronics, but I may have to reconsider and opt for the VT (supposedly runs cooler than ZT) if I go with the 60" model.
Your thoughts and comments are appreciated. Thanks.
As for IR not seeing it as being that widespread on any display from Panasonic or Samsung this year. A few people who experience it will post and post about it here on AVS and make it seem like more of a widespread issue. I could probably find IR on my LED if I looked hard enough for it after a long session of the Discovery Channel and the damn channel logo. Remember we are a small community of AV junkies when compared to the market at large. Heat between the ZT and VT should be similar, same processor and design on the backside with only the front glass being different. The warmest part of the back is right below the top left fan when facing the backside. It is warm to the touch but not hot, etc. I would buy the display that best fits your needs (room environment) and budget (if a factor). Both are good choices. I don't own an ST but based on my visits to BB, I would say since it lacks fans it tends to put out an equal amount of heat front/back. I wouldn't let the lack of fans on the ST keep me from buying it. Some might see no fans as an advantage, no fan noise. My 5020 had fans and any time I checked over the 4 years I used it the fans where never running regardless of how long I had it on. Hope this helps.
RIP Cricket - my pug and little buddy Jan. 10, 2017
Panasonic 60VT60 (cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 w/ 2500+ blu-rays and growing. Yes I still have HD-DVDs too.
smurraybhm is online now
Old 08-14-2013, 02:05 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Originally Posted by con219 View Post
Hi Larry
My own experience with the Sammy 63 7000 was the Panel failed twice. It was wall mounted and was told by tech that this can be a killer given the unit did not have fans either
The back panel of my Sammy was very hot to touch. Not the case with my fan cooled 65vt20 and 60.
Also a story was run on our nightly current affairs program down here in Australia. It was about failure of plasma panels. The technician had a graveyard of Samsung and LG panels.
He pointed out that wall mounting the larger panels coupled with lack of fans exacerbates panel failure. Stating that "passive cooling" on the larger panels is ineffective especially when wall mounted.
So it is not as prevalent as you made it out to be. It's anecdotal. My 64D7000 is still going strong with over 6000 hours on it.
The Samsung engineers obviously decided to disperse the heat by radiating it through the panel and using normal convection through holes in the back cover. Panasonic engineers decided to use fans which, by the way, add another potential failure point to be regarded. What will happen if a fan fails?
Thanks for responding.
Larry
LarryInRI is offline
Old 08-14-2013, 02:10 PM
jconjason's Avatar
Quoted: 562 Post(s)
Liked: 946
Ain't that the truth! There should be a pop up warning when you join the forum saying....be careful, problems here are hugely exaggerated!
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
Klipsch B-20 Rears,PA 120 12" Sub,klipsch R-10SW
jconjason is offline
Old 08-14-2013, 02:14 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Concerning fan/air noise, the ZT60 is the loudest TV I've ever owned, and that's no hyperbole. biggrin.gif
vinnie97 is offline
Latinoheat's Avatar
Quoted: 1111 Post(s)
Liked: 876
Totally agree.
Very well put.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
Old 08-14-2013, 03:06 PM
Bond 007's Avatar
Quoted: 2487 Post(s)
Liked: 1969
Licence to Kill
Bond 007 is online now
Old 08-14-2013, 04:33 PM
sillysally's Avatar
Quoted: 856 Post(s)
Liked: 858
Should be the same, around 0.0012
I have had profiles showing a MLL of 0.0011 and as high (still very low) 0.0014.
Modes I use are Custom, Pro 1 and 2.
These measurements are using profile's of 4913 points. However that is a full range 0-255. When you do a video scale (legal video 16-235) you are only using a 10% window (like in AVSHD) to take that measurement so of-course your reading is going to be higher. So unless you take a 0% (like in AVSHD 21 point) reading your MLL is going to be higher.
ss
btw, I set my VT60 to native Gamut and 96hz.
"Don't worry be happy"
sillysally is offline
Old 08-14-2013, 05:36 PM
javeryh's Avatar
Quoted: 81 Post(s)
Liked: 30
Well, the 65" VT is on sale for $2,800 at Amazon so I think I'm pulling the trigger.  I'm a little nervous even though my current TV is a 42" 1080i Panasonic plasma from 2004 which I still have no regrets buying for a crazy amount of money back then.
I'm excited but still a little nervous about daylight viewing and input lag (for Rock Band).  I'm also not sure about active v. passive 3D glasses but I don't really care about 3D (the kids have been asking for it).  Anyway, I buy a TV like once a decade so this is kind of a big deal.  I hope I made the right decision!
javeryh is online now
Old 08-14-2013, 06:12 PM
Latinoheat's Avatar
Liked: 876
People still play rockband? JJ, once a decade would kill most AVS members here, the most we go is 4-5 years.
Old 08-14-2013, 08:06 PM
con219's Avatar
Quoted: 61 Post(s)
Liked: 51
Larry
One thing for sure Larry I will notice it smile.gif It's not that the fans are quiet. And I will replace it.
With regard to the Samsung Panel failure. I don't need "other experiences" to confirm what I actually experienced. My personal experience is all I really need.
I guess Samsung improved the ventilation on the 64" model.
con219 is offline
Old 08-14-2013, 08:17 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
You have the right to have personal experiences. But you really have no right to edit someone's post and then quote the edited version without indicating that you did, in fact, edit it.
Bye,
Larry
Old 08-14-2013, 10:02 PM
Bond 007's Avatar
Liked: 1969
Bye,
Larry
+10
Licence to Kill
Old 08-15-2013, 12:07 AM
dingo99's Avatar
Not sure if you were asking that rhetorically, but Panasonic does employ circuitry and logic to detect a fan failure. Unplugged or non-rotating fans should result in the TV powering down after about 10 minutes with an 11 blink code on the power LED.
dingo99 is offline
Old 08-15-2013, 07:05 AM
ajay711's Avatar
Hello fellow VTers! I am new to Plasma and recently purchased a VT60. I love the TV, but have one issue. Whenever the screen is black, I can see visible "snow" or static in the picture. I know it is not the picture source as it does this on the Viera menus as well. I believe there were some complaints about this earlier in the thread. I have toggled between many different picture settings and the black static is still there. Also, when I pause the screen, I can walk up to the TV and see the visible static in the freeze frame. Can someone give me some more insight into this? Thanks!
ajay711 is offline
Old 08-15-2013, 07:11 AM
kimolaoha's Avatar
While I am certainly a fan of Amazon, you may want to check out Best Buy before pulling the trigger. Last I checked, the price for the 65VT60 was 2699 which in itself is not a reason to purchase there over the price you quoted from Amazon -- but the BB purchase amount would make you a Silver Rewards member and you'll get another hundred or so (5%) back in store credit and some other bennies. If you establish a BB account it's another rebate, and you get the calibration (not sure if that's a benefit or not) and free shipping, extended returns period, etc. Might want to check it out.
kimolaoha is offline
Old 08-15-2013, 07:12 AM
Bond 007's Avatar
Liked: 1969
Try a different HDMI cable.
Licence to Kill
Old 08-15-2013, 07:53 AM
ajay711's Avatar
Thanks for the response. I've ruled out the HDMI cable being an issue as I was seeing this when I was running the break-in slides off of USB and off of the Viera TV home page menus, which are not getting their source from any HDMI cable.
ajay711 is offline
Old 08-15-2013, 08:57 AM
con219's Avatar
Quoted: 61 Post(s)
Liked: 51
Bye,
Larry
No need to get nasty. It was definitely not my intention to embarrass you so please chill.
con219 is offline
Old 08-15-2013, 09:12 AM
DavidHir's Avatar
Liked: 1386
It's normal on any plasma to see "snow" or noise in the image up close at the screen. This should not be visible from any normal seating distance - at least on the VT60. It's also possible your brightness level is too which can show more noise.
Old 08-15-2013, 09:55 AM
SamOner's Avatar
How would the VT60's brightness hold up in this room? Can anyone post up images of their ZT60 in a bright room? I plan to have people to watch football and don't want the PQ to be to dim with lights on.
Im in the process of moving in.. I need to tidy up.lol
SamOner is offline
Old 08-15-2013, 10:23 AM
Denniswrly's Avatar
Liked: 38
My Pro calibrated vt60 does fine vt60 at 36ftl does fine zt would do better as reflections but not as bright as my vt60..i would suggest getting it there see there is limted return policy make sure if not vt60 get there and sure u b fine ..i been watching preseason and looks great...that side window needs dark covering of some sort maybe and for sure go for zt otherwise my vt60 does fine imo:)smile.gifsmile.gif
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
Dual recliner lazyboy
xbox 360
Denniswrly is offline
Old 08-15-2013, 01:20 PM
javeryh's Avatar
Quoted: 81 Post(s)
Liked: 30
Thank you for the post. I will definitely go to Best Buy and see if they can price match and let me finance it over time (Amazon is doing 24 months no interest financing on that TV right now). I will need to pay someone to hang it on the wall so that 5% back may help with that.
Old 08-15-2013, 01:38 PM
kimolaoha's Avatar
I'm now seeing that Amazon is offering its own kickback on this set, i.e. 6% back in rewards (Amazon credit). Remember also that Amazon does't (yet) collect sales tax. I played Amazon against Best Buy against Sears against hhgregg . . . and Best Buy gave me a sweet deal (bundled other gear with it). YMMV, but it's worth looking into. I'm pretty sure BB had the option of 5% back OR No Interest financing. Either way, it's a fantastic set.
Old 08-15-2013, 03:10 PM
raisin's Avatar
a nice line conditioner on the power outlet wouldn't hurt?
raisin is offline
Old 08-15-2013, 04:47 PM
gene9p's Avatar
Quoted: 32 Post(s)
Liked: 31
I just called PC Richard and Son to inquire about a 60 inch VT 60 for a friend. The price is so low I almost fell off my chair. They gave me an employee price sale quote and since there is no longer employee price sales on tv's anymore you have ask them directly. My buddy went down to purchase the set and the price is verified. You can pm me and I assure you it is incredible but since we cannot post prices drop me a note
gene9p is offline
Old 08-15-2013, 05:16 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
You can post prizes in the deals subforum.
vinnie97 is offline
Old 08-16-2013, 05:50 AM
gene9p's Avatar
Quoted: 32 Post(s)
Liked: 31
just did..thanks Vinnie......
gene9p is offline
Old 08-16-2013, 11:24 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2233 Post(s)
Liked: 2422
The ZT is not available in Australia. If it was I would have got that one smile.gif . So VT is "premium" here
At least you have the VT available, I am sure some there are countries do not have any Panasonic's.......
Cleveland Plasma is offline
Old 08-16-2013, 12:17 PM
Alex Raposo's Avatar
Hey everyone,
Got my 60' VT60 in today...looking for advice.... I downloaded the D-nice slides put them on a flash drive and I plan on having them cycle through for the first 100 hours. What kind of settings do I run these slides on?.....
After the first 100 hours or so then what? I know some people put there own settings up here and there.... and I know there is a lot of variation between sets.... So barring getting the panel professionally calibrated... What kind of settings should I be putting this set on? Is there an average of the VT settings out there, etc.?
Please help!
Alex Raposo is offline
Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Panasonic , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv
