Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 262 - AVS Forum | Home Theater Discussions And Reviews
 263Likes
post #7831 of 16959 Old 12-08-2013, 06:39 AM
PINKTULIPS7's Avatar
Quoted: 106 Post(s)
Liked: 49
Originally Posted by merccrazy View Post
That will get better with more time but was still there on my set at 950 hrs. Chad B did my vt60 and I didn't want to do the last update because it might change something. Well yesturday I updated due to not being able to use the apps because of it. After the update the motion was much better, more like my vt50 was but the image seemed to be a little softer. Not as soft as my vt50 though. At times I felt that the image on the vt60 was over processed even with the darbie turned off. I use a darbie set at 25 on hd for a little extra detail. Still looks great just a little softer.
The update number is 2.873
so you are saying VT-50 motion is better than VT-60?I thought it was opposite!!!!!!eek.gifeek.gifeek.gifeek.gif
PANASONIC TC-P55VT50
HARMAN KARDON AVR 7300**PARASOUND HALO A21 250W**EMOTIVA UPA-1 200W
L & R :> POLK RTI A9 500W**POLK CSI A6 200W**POLK RTI A3 150W**POLK FXI A6 150W
PANASONIC DMP-BDT 500**SVS SB-16 ULTRA 1500W [DUAL]
PANAMAX M5400-EX
PINKTULIPS7 is offline
post #7832 of 16959 Old 12-08-2013, 06:43 AM
merccrazy's Avatar
Quoted: 13 Post(s)
I am just saying that I never noticed motion issues with my vt50 and before the last update on the vt60 I was not totally happy with the motion. It is a lot better now. Just my honest opinion. Remember sets vary.
merccrazy is offline
post #7833 of 16959 Old 12-08-2013, 06:46 AM
Quoted: 106 Post(s)
Liked: 49
Originally Posted by Sargon 1 View Post
Thanks for the reply. I also ended up returning my 60ST60 and kept my 60ST50. I did it for two reasons.
1. I realized that I wanted my next tv to be a 65 like yours.
2. I had trouble getting used to what reminded me of a slight soap opera look to the 60 series. You describe the 60 as a "more dimensional" look. (By the way, that is an outstanding, spot on description). For me though, I prefer the flatter-less dimensional, more film-like look of the ST50 (especially on old tv shows).
Someone else posted that it was more fluid in movement. I noticed this too. For me, this also was a minus. I know that a flat look and 24 fps slightly blurry/juddery film is about blu-ray movies, but I like my tv shows to have this film-like look too even though tv shows are 60hz which translates into 30 fps and not 24fps.
I associate the extra fluid look and the dimensional roundness to people and objects and the accompanying depth to something far from film and reminiscent of a slight soap opera look. Soap opera, I know has to do with motion interpolation, with the accompanying 3d look and overly fluid movement. But the ST60 for different reasons, had this look (to a much lesser degree of course).
The only way I could get my ST50 to even remotely approach that look of the ST60 was to turn motion smoothing interpolation on to the weak setting. But to my dismay, turning off all motion smoothing and NR on the ST60 still, to me, had the 60 looking like it had motion smoothing going on a weak setting. I sometimes wonder if Panasonic said, "Were going to make sure this tv is always super clear and super smooth - even with all enhancements turned off."
So for me, the ST50 looked "better" in a very different way I guess than most people want and I feel that it gives me more options as to how I want it to look. I can turn on motion smoothing and crank up the sharpness if I want, and even better, leave it all off and not get that look.
AS far I know VT-50 does not handle 24Fps properly!!Is it improve in VT-60?
PANAMAX M5400-EX
post #7834 of 16959 Old 12-08-2013, 07:00 AM
Quoted: 106 Post(s)
Liked: 49
Watch Planet Earth First Blu-ray Dvd, when Two Wolf appear at the scene and start chasing a Cubs,when 24P set to 96hz and Motion set to Medium you will see SOP!!when Motion set to Weak you will see judder!!!!
PANAMAX M5400-EX
post #7835 of 16959 Old 12-08-2013, 07:50 AM
Scott Oakley's Avatar
Quoted: 80 Post(s)
Liked: 95
A couple question on the Menu for the VT60, specifically the Picture area:
* In each of the preset Modes, there's an option to return settings to Factory Defaults. Is this ALL settings across ALL picture Modes or just for the Mode that you're in?
* The eHelp section for Picture alludes to a Pro Settings and says you can go Menu, Picture, Pro settings. Pro settings doesn't appear as a choice for me. Do you know why?
Thanks, Scott
Panasonic 2013 55VT60
Marantz SR-5012 AVR
B&W 805 Speakers
Velodyne 10" Sub
TiVO Premiere
Scott Oakley is offline
post #7836 of 16959 Old 12-08-2013, 08:04 AM
DavidHir's Avatar
Quoted: 2049 Post(s)
Liked: 1674
Originally Posted by Ace_of_Sevens View Post
How long should it take to get rid of IR? As I mentioned a few pages back, I bought a used VT60 with about 690 hours and an NFL network logo. I've since run screen wipe for about 280 hours and it's still visible on flat colored content, though probably less so and the down counter and the stuff on the left side of the screen have disappeared.
Try the Disney WOW disc using the pixel flipper with contrast at 100 - worked rather well for me.
DavidHir is online now
post #7837 of 16959 Old 12-08-2013, 08:14 AM
Quoted: 106 Post(s)
Liked: 49
Thanks, Scott
Its just the setting you are in
PANAMAX M5400-EX
post #7838 of 16959 Old 12-08-2013, 09:59 AM
p3Orion's Avatar
Quoted: 13 Post(s)
Liked: 42
When you guys are doing the firmware update are you connecting the TV directly to the internet via ethernet (or possibly wireless) or are you downloading the update from Panasonic onto a USB flash drive and connecting that to the TV?
http://panasonic.jp/support/global/cs/tv/download/fw/america_2013/down_na_03.html
p3Orion is offline
post #7839 of 16959 Old 12-08-2013, 10:09 AM
fairchild99's Avatar
Liked: 151
@p3orion I did it last night through the TV itself, it is connected to my router through ethernet.
Sony 32" EX400 calibrated settings
Panasonic 50" S60 calibrated settings
HTPC/Sony S5100 to Sony HT-CT660 to Panasonic 55" VT60, Sony 32" EX400, Panasonic 50" S60
fairchild99 is offline
post #7840 of 16959 Old 12-08-2013, 10:25 AM
eric3316's Avatar
Quoted: 842 Post(s)
Liked: 959
Wireless. Took a little while for the entire file to download.
eric3316 is offline
post #7841 of 16959 Old 12-08-2013, 10:26 AM
Chere's Avatar
Quoted: 358 Post(s)
Liked: 187
This is worrisome and my initial enthusiasm is now somewhat tempered as well after noticing a couple of issues after two days:
- The right side of the set has a pink tint on the screen running horizontally from top to bottom and mostly visible in the center. Now this is only visible on the dark grey slide right before the black one and never on any real tv content. I had a flashback to a couple of years ago when some of the samsung plasmas had the pink mist issue. Does anyone have anything like this on their set and should I be worried?
- Even though my 65VT60 is an October 2013 build- I can hear the fan noise people have been talking about. I never heard it the first day and only when I came home last night which by then the slides had been playing a little over 24 hours did I finally hear it. I sit about 9.5 feet back. Maybe it kicked on when the set started heating up since it had been left on for a while by then? I immediately turned the set to live tv content and started inching the tv volume up and right about when I got to +8 I couldn't hear it anymore. It really won't bother in the long run as long as it it doesn't get any louder. Since this isn't the normal buzzing that some people have with their sets my assumption is that the fan noise should stay consistent. Please correct me if otherwise. I know there are owners here that have lived with this issue since the early part of the year.
Chere is offline
post #7842 of 16959 Old 12-08-2013, 10:44 AM
nexusdoan's Avatar
Call Panasonic on the fan noise. I did. They brought out a licensed technician from their network and he fixed it. Panasonic has a specific part that they use and it works. I have no more noise and mine was "very" apparent.
nexusdoan is offline
post #7843 of 16959 Old 12-08-2013, 10:46 AM
p3Orion's Avatar
Quoted: 13 Post(s)
Liked: 42
I'm running the slides now and have a slight pink band on the right side from top to bottom on the gray and white ones. It's about 4-5 inches wide. I notice it more if the room is dark (nighttime). Overall the picture uniformity is better than the two ST50s I had briefly last year. Both of them had pink areas which were clearly visible on the gray and white slides. While visible on the slides I did not notice them during content - and I really looked. I watched Game of Thrones, Band of Brothers, and Star Wars: The Empire Strikes Back, all of which had snow scenes, and could not see any pink. I'm hoping for the same with the 60VT60.
p3Orion is offline
post #7844 of 16959 Old 12-08-2013, 10:46 AM
skro's Avatar
Chere's was built in October, so it should already have the fix you received.
Donat76 likes this.
skro is offline
post #7845 of 16959 Old 12-08-2013, 10:58 AM
eric3316's Avatar
Quoted: 842 Post(s)
Liked: 959
Mine is an October build and is has been on since Friday afternoon. I haven't heard any sounds from the fan yet.
Now when I put on my original PS3, that thing has a fan like jet airplane. Anyone here have an original PS3? Curious if that is like what you were hearing on your VT60's. If it was, that would have been terrible but can't imagine it would have been that bad.
eric3316 is offline
post #7846 of 16959 Old 12-08-2013, 11:54 AM
Chere's Avatar
Quoted: 358 Post(s)
Liked: 187
I had the same pink band on my old ST50 which never manifested in real content but this one is different. It isn't a band. It's just there on the right side of the screen and protrudes out more towards the center. Again no big deal if it stays like that as I can only clearly see it in the dark grey slide and not even very well on the white one. It' isn't even really deep- just a light pink shade. I'm hoping it's just a minor uneven screen coating and nothing more.
Chere is offline
post #7847 of 16959 Old 12-08-2013, 12:15 PM
Chere's Avatar
Quoted: 358 Post(s)
Liked: 187
I live in an apartment facing outside street traffic where the noise insulation isn't very good. Add that to the noise coming out of my heater/ ac, fridge and other ambient noise- this is at the bottom of the heap compared. I only heard it last night when I was in the living room knee deep in the latest Tom Wood novel when the stars aligned and everything went quiet all of a sudden. Again no big deal if it stays the same and that it doesn't get worse. I haven't seen or heard anyone complaining since I started following this thread that their fan noise level had changed for the worse so I'm not too worried.
I'll keep an eye out on both these issues (pink hue and the fan noise) for the next 2 weeks and as long as I don't notice any changes- I'll be okay. I'm actually more worried about the PQ softness observed by merccrazy on his ISF calibrated display after the latest firmware update. The number one reason I upgraded to the VT60 from the ST50 as I mentioned before was because of the soft PQ it put out on 720p and 1080i OTA tv content and I don't look forward to going back to that. I'll hold off on the update until I hear more feedback from other users.
Chere is offline
post #7848 of 16959 Old 12-08-2013, 12:34 PM
PubFiction's Avatar
Quoted: 17 Post(s)
Liked: 36
Originally Posted by jconjason View Post
Not everyone has the room for speakers. And not everyone can afford to go that route. Thankfully I've been able to.
Well in my anecdotal experience all the people who say they do not have space, do have space they just are not willing to allocate it to speakers. In the end it almost always comes down to someone not liking the aesthetics. And as for costs I think this is a rarer reason but its an odd combo if you are dropping thousands on top tier TV and your budget is that tight. In the end you can do whatever you want in your place but don't expect much out of speakers that are small enough to fit in 2 inch bezels, especially on a device that was produced for the high end experience where many are expected to bring their own speakers.
PubFiction is offline
post #7849 of 16959 Old 12-08-2013, 12:44 PM
dsg2003gt's Avatar
I have a very slight pink tint on the right side of the slide as well. It seems to be about 4-5 inches wide and runs from the top to bottom of the screen. I also have what appears to be dust nearly dead center in the screen that blocks about 1 pixel.
ETA: My ST30 had a pink and green blob in the beginning that was very noticeable, but after a few thousand hours of watching, it seems to have gone away. I confirmed last night with the slides.
dsg2003gt is offline
post #7850 of 16959 Old 12-08-2013, 12:49 PM
Quoted: 80 Post(s)
Liked: 95
Ethernet cable from TV to router. For me and based on my background, this is much preferred over wireless mostly in terms of a stable connection. With video, that's paramount.
Donat76 likes this.
Marantz SR-5012 AVR
B&W 805 Speakers
Velodyne 10" Sub
TiVO Premiere
post #7851 of 16959 Old 12-08-2013, 01:18 PM
jconjason's Avatar
Quoted: 756 Post(s)
Liked: 1362
So you dont see the pink band under normal content, and you don't hear the fans with normal listening volume.....what's to worry about?!?!
jeffpaul and Denniswrly like this.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
Klipsch B-20 Rears,PA 120 12" Sub,klipsch R-10SW
jconjason is offline
post #7852 of 16959 Old 12-08-2013, 02:45 PM
Bond 007's Avatar
Quoted: 2650 Post(s)
Liked: 2103
+1
Licence to Kill
Bond 007 is offline
post #7853 of 16959 Old 12-08-2013, 02:45 PM
Chere's Avatar
Quoted: 358 Post(s)
Liked: 187
@ jconjason:
^^^^^ Not really worried at this point but mostly wanting to make sure that both issues don't get any worse over time. I figure I have about 28 days to make sure I don't see any changes and as long as I don't- I should be good. I know there's no perfect set out there and going for an exchange for these two minor things isn't something I want to do at this point . At the same time I want to make sure that I don't ignore it completely less it gets worse over time and I'm out of my return window.
Do you have any issues with your set at all?
Donat76 likes this.
Chere is offline
post #7854 of 16959 Old 12-08-2013, 02:52 PM
Bond 007's Avatar
Liked: 2103
@ jconjason:
I completely understand. Sounds somewhat similar to the yellow blotches reported on the VT50. But those took many hours to show up and could be seen on regular content. Particularly on a mostly white screen. Many people think theyre heat related. I would definitely keep an eye on it but if its not too much trouble, if it was me, I would exchange it. Keep in mind though that you do have a factory warranty if nothing else so its up to you.
Licence to Kill
Bond 007 is offline
post #7855 of 16959 Old 12-08-2013, 02:56 PM
DavidHir's Avatar
Liked: 1674
Some minor uniformity is the norm on plasmas (and LED). I've had some very subtle pink areas on my ST30 and VT60. Proper (professional) grayscale calibration will help reduce it although may or may not eliminate it on test patterns or gray slides, but it should not be an issue with regular content. Keep in mind your set for the next few hundred hours will be drifting and changing. After that period of time, I would highly recommend a pro calibration. If you choose to play the panel return lottery game, good luck with that - you may end up with a worse panel or completely different panel. Don't expect 100% perfection on any consumer based display.
You may or may not hear fan noise when trying to listen to it, but if it's not heard under normal viewing conditions, it shouldn't be an issue. I sit about 8.5 feet back and if the room is completely silent, I can just barely here the fan noise if I really try and listen for it. So, who cares? I cannot even hear a hint of it at low volume.
Hughmc and Donat76 like this.
post #7856 of 16959 Old 12-08-2013, 02:59 PM
jconjason's Avatar
Quoted: 756 Post(s)
Liked: 1362
@ jconjason:
No. No issues with mine.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
post #7857 of 16959 Old 12-08-2013, 03:34 PM
flyinion's Avatar
Quoted: 42 Post(s)
Hoping someone can help me decipher the Sound & Vision settings for the vt60, their W/B Detail settings sections don't match up with what is in the menus and therefore don't make a lot of sense. I assume they want the panel brightness set to high for 3D if I read that right. Then below in the W/B Detail though there is no Mid and High there is only Low and High in the actual TV. So I'm thinking the first section maybe is the High settings for the 2D Mid panel brightness and the high column is for the high brightness in the 3D settings and then the 2nd section is for the Low settings. Except for the fact that the first section specifically says it's for 2D and the second seems to be a massive typo (32D).
Code:
Pro Settings: Panel Brightness (2D and 3D)
               Mid      High
AGC            0        0
Black Extension 0       0
Color Gamut     Rec.709 Rec.709
W/B Detail Adjust. (2D)
        Mid     High
Red     –7      10
Green   –1      4
Blue    14      –3
W/B Detail Adjust. (32D)
        Mid     High
Red     –15     11
Green   0       0
Blue    –6      –1
Pansonic TC-P60VT60 | Marantz NR-1606 | Velodyne CHT series satellites/center | Velodyne CHT-8 sub | Sony BDP-S550 | XBox 360 | Logitech Harmony Touch | Comcast (Pace) PX001ANM "X1 platform"
flyinion is offline
post #7858 of 16959 Old 12-08-2013, 04:11 PM
DasRetroKid's Avatar
Do you notice a softer image also?
No, I do not.
I saw that Panasonic states the newest FW stabilizes performance, but I would love if they would be a tad more detailed, like Onkyo for instance. smile.gif
If I had to reduce the delay in audio by 20ms, that can only lead me to believe the TV is processing video faster now (a good thing, so long as the PQ doesn't suffer).
My wish would be for Panny to give us a FW which allows us to disable / enable the Viera apps entirely. That would be sweet as I never even venture in there and it would free up a whole lot of processing power.
Panasonic Viera TC-P55VT60
Onkyo TX-NR609 7.1 | Speakers: (C) Infinity PC351, (FL/FR) Infinity P363's, Sony Surrounds
DasRetroKid is offline
post #7859 of 16959 Old 12-08-2013, 04:36 PM
Gov
Gov's Avatar
Quoted: 121 Post(s)
Liked: 185
Those with screen imperfections, how does it look with content on the screen? Also, I remember reading a forum member's signature who was a big wig with Sony years ago and it said, "Watch the content, not the screen." Like some others have said if it can't be seen with content displayed from your seated position, who cares! If you are looking for imperfections, you will be damn sure you will find one thing or another.
jeffpaul likes this.
Main HT Room: Panny TC-P65VT60 (calibrated by Chad B), Denon AVR-4311, Comcast X1 DVR, Apple TV3, Sony BDP-S5100, Speakers: Ascend Acoustics Sierra Towers, Sierra Horizon and HTM-200SE, Dual Power Sound Audio XV15 Subwoofers
Basement HT Room: Panny TC-P58V10 (Black Level Restored!), Denon AVR-E300, Comcast X1 STB, Sony BDP-S590, Speakers: Ascend Acoustics CBM-170SE (L/R), Ascend Acoustics CMT-340SE-C, Wave Crest HVL-1 (Surr) and Dual Power Sound Audio XV15 Subwoofers
Gov is offline
post #7860 of 16959 Old 12-08-2013, 04:36 PM
DavidHir's Avatar
Liked: 1674
Code:
       MidHigh
AGC       00
Black Extension00
Color GamutRec.709Rec.709
MidHigh
Red–710
Green–14
Blue14–3
MidHigh
Red–1511
Green00
Blue–6–1
White balance settings are highly dependent on the individual display and do not carry over well to another.
Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Panasonic , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv
