Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 301 - AVS Forum | Home Theater Discussions And Reviews
 246Likes
Old 12-22-2013, 11:00 PM
p3Orion's Avatar
Quoted: 13 Post(s)
Liked: 42
For those that are running the slides past the 100 hour mark, what Picture mode and settings are you using after the 100 hour panel prep? I already did the 100 hour panel prep and input the Professional 1 and 2 settings. I want to run the slides at times to put hours on my VT60, but don't want to use the 100 hour panel prep settings, especially 100 contrast.
Last year when I did the 100 hour panel prep on the ST50 I ran the slides at times afterward using the Custom Picture mode and D-Nice's Reference Setings. I don't know what to use for the VT60.
p3Orion is offline
Old 12-22-2013, 11:06 PM
davej3's Avatar
Some experimentation with the USB Port:
Ripped a Blu Ray into MKV (H.264 video + AC3 audio).
Copied it to a USB stick (formatted ExFat).
Plugged it into the VT60, and it played back perfectly with full Blu-Ray goodness:
1080p video and 7.1 lossless audio via optical to AVR.
Very nice.
May be possible to plug in an external hard drive (also formatted ExFat) for a DIY poor-man's Kaleidescape.
davej3 is offline
Old 12-22-2013, 11:59 PM
Sargon 1's Avatar
Liked: 32
Originally Posted by XBR11 View Post
Sargon 1 - Could you please detail your "glitch" method to get the panel brighter?
No problem my friend! But even though I am trying to help, this contrast-brightness glitch may still not create the level of brightness you require. Worth a try. Go to STANDARD and increase the CONTRAST to 100%. Within around 25 seconds it will go very bright. If you have it even at 99, it won't do it. Another method is scroll in and out of the standard mode (to Vivid to Standard to Home Theater and back to Standard, for example, until it pops in bright at once - with the contrast at 100.The good news is it will keep this constrast-bright look even after turning your tv off and on. You will only lose it sometimes when switching modes or if you ever drop your contrast down to 99 or less in the standard picture mode. Someone posted a while back that what I discovered here is not a glitch but a normal part of the energy star mode. (I must have missed that one in the instruction manual). While I agree that Standard is an energy saving worthless dark mode, how could this contrast pop be "normal"? When you increase the contrast of Standard, it brightens incrementally up to 99 to a contrast level about equal to Vivid with a contrast setting of 40. And it keeps this level of brightness no matter how long you wait and scrolling through the modes doesn't change a thing. But if you increase the contrast just one point, to 100, the contrast does what I outlined here with a contrast brightness about equal to Vivid set at 85. So how can a jump from 40-85 with a 1 point increase not be a glitch? Anyway, equal to Vivid at 85 isn't Vivid at 100, but it is brighter than any of the other modes at 100. Conversely, if Vivid were set at 85, it may create an equivalent contrast-brightness of Standard set at 100, but it sure doesn't have an an equivalent look. I honestly don't know why Panasonic didn't make Vivid mode look like this.
Matey's, If ye liek me posts, I pander,
for two thumbs up when ye take a gander! Aaarh! - Sargy
Sargon 1 is offline
Old 12-23-2013, 01:23 AM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2046
Originally Posted by Bond 007 View Post
Originally Posted by htwaits View Post
The Redmere cables are active (with a chip) and the chip (longer connector) has to be at the destination end. The passive (no chip) cables are not directional. Is Monoprice selling 36 AWG passive cables now?
Dont know. Not even sure exactly what hes getting. He just said slim HDMI cables. Just giving the guy a heads up so he doesnt get home and possibly hook them up wrong and wonder why they dont work as others have done.
I just checked Monoprice and couldn't find any passive 36 AWG cables so he must have gotten Redmere active cables.
htwaits is online now
Old 12-23-2013, 02:05 AM
IINEWBIEII's Avatar
I am also running a PS3 with my VT60. I have an older Onkyo HTIB I use for audio using digital optical toslink cables (one to PS3 to Receiver and one to Cable Box to receiver).
Everything has gone swimmingly viewing Cable and Bluray's so far.. I like the THX Cinema and bumping up the contrast just a bit.
Anyways, tonight I decided I was going to plug in a couple different picture settings (CNET/******************* were the ones I chose tonight), and see how they look. At first glance I thought they both looked pretty good (though completely different) so I wanted to test out a bluray (Man of Steel, which I watched the night before).
Anyway, the problem I noticed was not with the actual picture quality at all, but with how my PS3 was playing back the video differently. Really hard to explain, but the speeds seemed off and inconsistent... it gave it a very unrealistic and almost a very disturbing movement to the movie.... if XBR11 is experiencing the same thing he called it "stuttering" which is a good word.
I really did not notice this until I started messing with the advanced picture settings tonight (screen settings, advanced settings). I hope that this 'effect' hasn't been there the entire time and I'm just now noticing it... I've only watched a few blurays so far. I am hoping this is a setting I just changed on my VT60 and my PS3 settings are not syncing correctly with whatever I changed on my VT60. I will probably restore all the default factory settings and stick with my THX Cinema mode, as I was pretty happy with that.
If anyone has suggested PS3 settings with the VT60 as p3Orion was asking for, or just know a simple fix (like screen format Full to Just) or something like that, I would love to know! I wouldn't mind keeping these new picture settings for awhile but it's not even an option if I can't fix this weird speed jittery playback issue I'm experiencing with the PS3.
Originally Posted by p3Orion View Post
I have these PS3 settings from when I was researching the ST50.
Video Settings
BD Internet: "Allow"
BD/DVD Cinema Conversion: "Automatic"
BD/DVD Upscaler: "Normal"
BD/DVD Video Output Format (HDMI): "Y Pb/Cb Pr/Cr" for TVs, "RGB" for PC Monitors
BD 1080p 24Hz Output: "Automatic"
BD/DVD Dynamic Range Control: "Off"
BD/DVD Audio Output Format (HDMI): "Linear PCM"
BD/DVD Audio Output Format (Optical Digital): "Bitstream"
Display Settings
RGB Full Range (HDMI): "Limited"
Y Pb/Cb Pr/Cr Super-White (HDMI): "On"
Are these the correct/ideal/best settings for the VT60?
I will be setting BD 1080p 24Hz Output to "On" and selecting 96Hz mode on the VT60.
Should 1080p Pure Direct be on or off on the VT60?
I've searched this thread and googled it as well, but not sure if and when to turn on 1080p Pure Direct. Also, how 96Hz factors in. How 4:4:4 applies is confusing as well. I want to know what settings to use for blu-rays (PS3) and dish HD programming.
Moving action still has a funny look to it. Maybe it is my eyes.
When I am watching moving objects, there is a stuttering or screen door thingy going on, which hurts my eyes. See this like when watching football passes. Even saw this when watching slow panning opening titles of a movie.
IINEWBIEII is offline
Old 12-23-2013, 02:21 AM
Sargon 1's Avatar
Liked: 32
Originally Posted by robnormal View Post
I recently purchased the vt60, and I have this same problem. I have turned off the motion smoother, turned off 24fps output from my blu ray, aged the panel 100 hours, and used something like the d-nice settings. All of these helped, and the image has indisputable depth and richness - but it still looks like video to me, not film. This is a deal-breaker for me, and it's a big disappointment, as I really wanted to love this plasma. But to me, a movie should not look like a play, but like a moving painting - that is, two-dimensional.
Could you recommend a more "film-like" TV? I read a review of the st50 that said that, too, had a "slight SOE" that doesn't go away. Is Samsung 8500 the best option, then? Sorry if this is off-topic; I'm new to avsforum, so please excuse my ignorance. Thanks for any help folks can give me.
robnormal, I haven't forgotten about you. I just need a little more time putting together a list of settings I found that help with this. 300 pages of posts - your the first to notice the lack of film look on this tv. I agree with every WORD you wrote. Your descriptions are like an oasis in the desert. Back when I hated plasma and like LED tvs, I would ask, "Why are those tvs so dim looking? Why this and why that? I would be told that plasma people prefer the look of film. Not the retina searing brightness. Not the artificial motion. Not the inaccurate colors. Not the clouding & flashlighting. But I have yet to read a poster (on this thread) that has a problem with this lack of film-like look.(But they are rightly very concerned with film-like MOTION). Some don't see this look. Some don't care. In fact, many love the 3D look. To me, even with motion smoothing turned off, there is a roundness to every person and object and they don't blend into the same plane as the rest of the scene. Instead everything has a distinct and separate look - occupying their own separate space. Do you relate? For more, read my older posts about this. The Samsung 8500 scores a home run in regard to film look, but it completely lacks the as you say "indisputable depth and richness" of the VT60. My tv might be going back too if my settings don't help enough. This tv does everything the best, but if it cannot make a movie look like film, I'm no longer watching a movie; I'm watching the technology. Technology shows off the tv; Film takes me away from the tv and puts me into the story. Have ya seen 4K yet? Scaaary!
P.S: Off topic is our Spe-ci-al-ity here! No worries! U pick the topic. They will either like it, ignore it, or . . .  let you have it! (Ya mean a TV?) You'll see . . . Let's not scare him away just yet boys!
Sargon 1 is offline
Old 12-23-2013, 04:00 AM
Sargon 1's Avatar
Liked: 32
p3Orion, I had the following from an article about a Brit version of our tv. Other than the 50hz, I think these tvs are the same. See if this helps: A quick skim through forums reveals that the general consensus is always to choose the “YCbCr 4:2:2″ option because this is the closest match for what is actually stored on the Blu-ray/DVD disc. Actually, the best choice depends on the display and the player. So what about the 65″ VT65?The Panasonic TXP65VT65B’s chroma processing is never flawless. There are three main configuration possibilities for getting coloured pixel data from Blu-ray Disc (and other HDTV sources) into the television and out of the plasma panel device. The first is to send 4:2:2 video in. The second is to send 4:4:4 video in but to enable the Viera VT’s “1080p Pure Direct” mode, which claims to keep the pixel data as 4:4:4 internally (it actually doesn’t, but it’s close). The last is to send 4:4:4 video in but to leave “1080p Pure Direct” off, which will involve a conversion to something less than 4:4:4 (4:2:2 maybe?) inside the TV.
I'm not sure what you mean about 96Hz beyond the fact that it is the most film-like looking as opposed to 60hz which involves a 3:2 pulldown of 24fps source material. (24fps not dividing evenly into 60hz). Again, I assume your asking something beyond the obvious here. I have read others on this post saying that 96hz has better black levels as well as how smooth it looks. I don't know about that because I only use 96hz. I run from 60hz. It is the reason why I abandoned my ST50.
For those of you who are having problems with your PS3, I would suggest getting a different player. I own (due to trying out) different players. It is a small investment when it comes to finding what works best with these very expensive sets. No I don't own an Oppo, but I don't think my Panny and Samsung players are having the problems you speak of with your PS3. Studdering motion is the stuff of the Samsung 8500 plasma TV. Who needs those issues? It's hard enough to get any tv to look and move correctly.
Sargon 1 is offline
Old 12-23-2013, 05:25 AM
Dunday's Avatar
Anyone been into the service menu?
In previous years you can punch up the brightness with the ALL DRIVE / R DRIVE / G DRIVE / B DRIVE parameters in the Panel W/B Adjust menu (it makes adjustments directly to the white balance presets for example, cool, normal, warm etc so take note before you make any adjustment)
Dunday is offline
Old 12-23-2013, 05:40 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
I bought the RedMere ultra slim high performance HDMI cables (Product 9889 6ft black) - http://www.monoprice.com/Category?c_id=102&cp_id=10255&cs_id=1025503&ref=cj
Will these work?
Panasonic P60VT60 Calibrated by Chad B
Marantz NR-1504
GoldenEar SuperSat 50s
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
Old 12-23-2013, 05:42 AM
chunon's Avatar
Quoted: 2134 Post(s)
Liked: 1868
No reason to access the service menu all the controls you need are in the user menu, the only valid reason would be for adjusting the THX modes white balance but most folks use one or both of the pro modes to calibrate.
Dunday likes this.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
Old 12-23-2013, 06:41 AM
KnoellAlex's Avatar
Originally Posted by mbroadus View Post
Gotcha, thanks.
Regarding LCD/LEDs, I was seriously considering the Sony KDL55W900A which came in third in the HDTV shoot out.
Hmmm, great reviews on that one. You may have just sold a Sony! :)
KnoellAlex is offline
Old 12-23-2013, 07:16 AM
emerson1's Avatar
Quoted: 36 Post(s)
Mine is coming today! But then I head out of town tomorrow for Christmas frown.gif I am wayyyy to paranoid to run slides while I am not here so it will be an extended process.
emerson1 is offline
Old 12-23-2013, 07:26 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Agree, I was unsure whether to run overnight but no problems so far. About to hit 50 hours of continuous slides. My wife says she feels like she's in Vegas with the flashing colors.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
Old 12-23-2013, 08:18 AM
KnoellAlex's Avatar
For anyone dealing with the grainy, dim problem, I believe this helps dramatically. I did your instructions, but nothing happened and I walked in the other room. When I came back out I completely forgot that I tried it, and booted up Netflix. I was watching for awhile and started thinking "this picture looks really good!" then I remembered I did this, and it was still set on standard and it looked good. For anyone that has started up standard out of the box knows its unwatchable. THX looks even better. I still see some graininess but I could get over it.
Still going with the Sony LED though. For one I already canceled my squaretrade warranty, scheduled the return, and ordered the Sony. If anything I will enjoy not having to worry about IR on gaming/football/network tv marathons.
Old 12-23-2013, 08:25 AM
planecrazyf16's Avatar
My 65VT60 was delivered from BB/Magnolia in the weekend. Oct 2013 build - no significant fan noise. DNice slides have been running for around 40 hours. I do hear some panel buzzing with the lighter shades. How much buzzing is considered normal?
Another thing I noticed with lighter slides is sort of hazy vertical "streaks" in the display - nothing too obvious but definitely visible. It looks as if the screen has gentle "folds" in it - vertical areas of slightly darker shades. Is this expected? Will the aging process with DNice's slides make the pixels uniform?
planecrazyf16 is offline
Old 12-23-2013, 08:51 AM
emerson1's Avatar
Quoted: 36 Post(s)
How is the heat generation compared to older models? I am going to have this in a bedroom for about a month and my 2009 model 42" Panasonic plasma can easily raise the temperature in the room by 10 degrees. I had a 3 hour gaming session with GTA a couple months ago and I ended up sleeping in another room. I'm guessing any reduction in heat will be cancelled out by the new TV being 23 inches bigger.
emerson1 is offline
Old 12-23-2013, 08:55 AM
bern43's Avatar
Will these work?
I'm using three of those exact cables for my VT60 in the 10ft length and they work great.
bern43 is offline
Old 12-23-2013, 08:56 AM
mrfattbill's Avatar
Quoted: 96 Post(s)
Liked: 89
Not nearly as bad IMO. My 50G10 was a LOT warmer compared to my 65VT60 so much so that even my wife noticed a difference.
Bill
mrfattbill is offline
Old 12-23-2013, 09:50 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Thanks...with half price overnight shipping, I should have them tomorrow.
Anyone know how they perform when connected to a hdmi receiver? I heard there may be problems.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
Old 12-23-2013, 09:59 AM
bern43's Avatar
My understanding is that the problems come up when you run two of them in the same line. I'm running them from my receiver to the TV, but not from the sources to the receiver.
bern43 is offline
Old 12-23-2013, 10:17 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
That's what I heard too. Probably use the high speed fat cables from source to receiver and slims to display. The fat high speed cables are not very flexible.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
Old 12-23-2013, 10:21 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2110 Post(s)
Liked: 2261
Make sure you power it on and check it out before you leave, inspect your goods during delivery or just after depending how your vender works it.
Cleveland Plasma is offline
Old 12-23-2013, 10:41 AM
Sargon 1's Avatar
Liked: 32
When I first posted this a while back, I thought everyone would jump on this one or at least try it (I stopped charging smile.gif )but I actually had no response for a long time and even had someone tell me he "refused to even address" this. I guess it fell into the category of (think British accent here), "preposterous". So, even though your are returning your tv, it is gratifying to hear yet another person who likes this glitch I found.
I thought the Sony KDL55W900A was one of the best looking LEDS but don't they only come in a 55inch? Could you return me the favor KnoellAlex by letting me know if motion is smooth and normal enough with their motion smoothing turned off. I saw it with it on and it looked unnatural.
Have any of you guys noticed that the Samsung LED isn't only too bright but has too much light coming through the panel so it has a washed out look-over illuminated look? That Sony is about the best in this regard.-really rich looking. It makes that tv stand out at Best Buy over all the other sets on the wall. An LED that looks less LED. Now for my insane secret, I find that the cheapest brand LEDs like RCA look the very best in this regard. I'm just sayin.
Sargon 1 is offline
Old 12-23-2013, 10:47 AM
chunon's Avatar
Liked: 1868
65C6 OLED
chunon is offline
Old 12-23-2013, 10:48 AM
Rayjr's Avatar
Quoted: 175 Post(s)
Liked: 214
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
Originally Posted by FilmMixer View Post
On both my GT50 and VT60 I ran the slides for 4 days.
No issues.
If you read the instructions, follow them to the letter, start the show and watch two cycles of repeats to make sure it both repeats and changes there is not much that can go wrong.
Start the slideshow, hide the remote, and walk away.
@FilmMixer give me a call after the Holidays...so we can get that VT60 calibrated.
RayJr
Rayjr is offline
Old 12-23-2013, 11:19 AM
boca rat's Avatar
One benefit of the 65VT60 for me is the upgrade to Netflix vs my older Sony Bluray w/Netflix which has a lot of problems with buffering. The new TV/app seems to have eliminated that entirely.
However, I haven't yet compared quality, both video and audio.
Is there any objective comparison, for Netflix and Amazon (the only two streaming apps I use)?
I am about to buy a new Bluray for 3D, and Netflix/Amazon performance might be important if they offer advantages over the VT60.
Thx!
boca rat is offline
Old 12-23-2013, 11:21 AM
Sargon 1's Avatar
Liked: 32
Originally Posted by chunon View Post
Be NICE to o'l Sargy now! Wi boh no Pahn-nee-son-eek doh got nooooooo foo-cha! Do you see a woh-maan in me foo-cha tu? Co-mahn. . .dohn hole bak . . . Tell o'l Sargy whut cha see shoo-known!!!eek.gif
Sargon 1 is offline
Old 12-23-2013, 11:39 AM
freeride's Avatar
Originally Posted by bosng View Post
what the heck. wanted to use the amazon video app to stream amazon prime videos and was prompted for an update. when updated the app was gone? i can't find it anywhere. when i try to go online via the web app. all i get is "unsecure connection" i can't go anywhere but the panasonic page. frown.gif anyone know whats up with that?
"Unsecure connection" is all I get as well, whenever I try to use any of the apps or browser. I have LAN and wireless working, and the TV says it's setup correctly. I have no idea how to fix. Could find anything on Google search either.
My priorities? Each one of my speakers weighs more than my VT60.
freeride is offline
Old 12-23-2013, 11:53 AM
freeride's Avatar
robnormal,...your the first to notice the lack of film look on this tv. I agree with every WORD you wrote. Your descriptions are like an oasis in the desert. Back when I hated plasma and like LED tvs, I would ask, "Why are those tvs so dim looking? Why this and why that? I would be told that plasma people prefer the look of film. Not the retina searing brightness. Not the artificial motion. Not the inaccurate colors. Not the clouding & flashlighting. But I have yet to read a poster (on this thread) that has a problem with this lack of film-like look.(But they are rightly very concerned with film-like MOTION). Some don't see this look. Some don't care. In fact, many love the 3D look. To me, even with motion smoothing turned off, there is a roundness to every person and object and they don't blend into the same plane as the rest of the scene. Instead everything has a distinct and separate look - occupying their own separate space. Do you relate? For more, read my older posts about this. The Samsung 8500 scores a home run in regard to film look, but it completely lacks the as you say "indisputable depth and richness" of the VT60. My tv might be going back too if my settings don't help enough. This tv does everything the best, but if it cannot make a movie look like film, I'm no longer watching a movie; I'm watching the technology. Technology shows off the tv; Film takes me away from the tv and puts me into the story. Have ya seen 4K yet? Scaaary!
I understand this, or at least I think I do. I actually enjoy the effect, and I use it on cartoons and Pixar style films using the Home Theater selection. When I'm watch a regular Bluray movie, or cable TV or Netflix, I use one the THX settings, depending on the light level in the room. I find that the THX settings give me the film look I'm used to, while still showing off what the plasma panel is capable of.
freeride is offline
Old 12-23-2013, 12:01 PM
XBR11's Avatar
Quoted: 377 Post(s)
Liked: 213
Here are some photos of my old tv (left) and new tv (right). To me the new tv is not as white when the background is all white. To your expert eyes, what do you think?
ps - the left tv is p58s2 and the right is 65VT60. p58s2 is on an antenna. 65vt60 is on cable.
_______________________________________________
[Hey, what does that Acronym mean?! Click here to learn.]
XBR11 is offline
Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Panasonic , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv
