Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 358 - AVS Forum | Home Theater Discussions And Reviews
 246Likes
Old 01-16-2014, 08:11 AM
SeLfMaDe111985's Avatar
Liked: 99
Originally Posted by eric3316 View Post
I look at it this way. In real life, if you were in a dark alley you would not be able to see everything in that alley as light as day. So of course a lot of the picture will be dark but this is where shadow detail comes in. On a good TV you will see all the little subtile things that one would probably see in that situation where another TV might make everything look brighter but everything will just get crushed and look like one big blob instead of seeing for example a little a garbage pail really dark in the background and even being up to pick up slight risges in it. Another TV might just show that garbage pail clearer just to brighten it up but remove all the fine detail that might actually be found on that garbage. Make sense?
Take a dark scene and throw your TV in vivid mode. Then throw it in one of the modes with the custom settings. This is when you will really see the shadow detail and how everything can be made brighter but you actual lose shadows within the picture.
I would like to see what you are seeing though. Do you have Netflix? If you do can you let me know a movie you have watched that looks bad in dark scenes and the time that scene takes place in the movie. I wan't to really try and compare apples to apples here and no better way then trying exactly what you are watching.
And yes, the F8500 is a great set as well but I can't imagine spending another $1,000 more then what I paid for the VT60 just to get some brightness out of it which I would most likely turn down anyway for a realistic picture. For sports it would not be as important to be accurate and can understand just wanting something bright. I also wouldn't worry about how ugly people say the stand is (yellowcanary), the picture on the TV should be the most important part of the decision.
Floating blacks on the 8500 just like Panny had a few years ago I believe on the 20 series. You don't see floating blacks in an alley way wink.gif
SeLfMaDe111985 is offline
Old 01-16-2014, 08:14 AM
Liked: 99
Originally Posted by p3Orion View Post
A few people on the ControlCAL forum have reported that their displays had ~120-150 hours logged prior to use. One of them was told by the dealer who sold him an October build 65ZT60 that Panasonic is now running their own "break-in" slides in factory prior to shipping.
This is news to me. I don't know if the info is legit, but I thought I'd pass it along. If it's true then those who intend on running D-Nice's slides and using his settings might have an issue.
I have an October 2013 build and it had Zero hours on it. I checked recently and there 15 hours on it from me running slides nothing from the factory. I'm saying that's false. Why would they do this if they are out of the biz? And once taken out of the box they must sell it as OB. It would no longer be NIB.
Speaking of break in. When setting the color gamut (this has always confused me) Dnice has his setting as "normal" but there is no "normal" setting. There is only "naive" which I'm guessing is normal and "REC 709" and a few others. I've seen someone mention for his calibrations he uses REC 709 which seems more natural where as Naive seems to over saturate the colors making them have a glowing effect like torch mode on LCDs. So my best educated guess is that REC 709 is recommended for calibration but is "naive" if that means normal better for break in? I'm not talking for slides cuz that's all default settings I mean for playing a BD or HD feeds.
Old 01-16-2014, 08:48 AM
fkenyon's Avatar
My set from Amazon arrived Monday from Pilot. It is a March build with 0000 hours, and the delivery guy and I removed it from the box, assembled the stand and put it on my tv stand.. I declined to power it up at that time due to temps.
fkenyon is offline
Old 01-16-2014, 08:54 AM
Gary218's Avatar
Wow...I thought Amazon would be shipping the newest build dates? Hope yours is ok with the fan noise.
Gary218 is offline
Old 01-16-2014, 08:57 AM
Liked: 99
Must be digging into stock that wasn't rotated. No biggie. I had a set from Pauls which was a May build bought in November and didn't really have any fan noise or buzz issues (just the normal noises for plasm). It's random IMO. Returned to Pauls do to screen defects and went with Amazon and got much newer build. I also believe that people with May-July builds may have some
Scratches on the left speaker and maybe some on the screen. QC must of been a little off at that time becasue most people I see report those issues like dirt or particles behind the screen which I had a July build with that issue, seem to have a may-July builds and some August builds. I received two October builds from Amazon with not a single
Flaw.
Old 01-16-2014, 09:20 AM
Mean Gene's Avatar
Only 35 65vt60's left on amazon from 300+ earlier in the week. Please TV gods let mine be ok tomorrow when delivered in case I need a replacement.
Mean Gene is offline
Old 01-16-2014, 09:29 AM
The Void's Avatar
Exactly. Mine will be delivered tomorrow as well. Good luck.
The Void is offline
Old 01-16-2014, 09:33 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2047 Post(s)
Liked: 2213
Cleveland Plasma is offline
fkenyon's Avatar
I was surprised with te build date as well. I would say fan and screen are normal. No defects or problems that I can see.
fkenyon is offline
Old 01-16-2014, 09:40 AM
Gary218's Avatar
that's good....enjoy your new tv!
Gary218 is offline
Old 01-16-2014, 09:59 AM
Cal1981's Avatar
Quoted: 238 Post(s)
Liked: 239
My set from Amazon, ordered a few weeks ago, was an October build. I can't see any signs that the foam fix for fan noise that Panasonic began to use has been applied in my set but from 9 feet away you can only hear the fans when there is no audio track or ambient background noise and even then its very light..
Cal1981 is offline
Old 01-16-2014, 10:17 AM
JPowers's Avatar
Liked: 29
I can see slightly darker edges on the blue slide, but nothing I would consider abnormal. On the gray slide the same edges appear a purplish hue.
No panel is perfectly uniform, as you probably know. On the white and gray slides my 60VT60 has a faint pinkish hue along the right side that's about as wide as on yours. Also much. much smaller areas around the edges. I ran the slides for 100 hours so had the opportunity to view it multiple times. I'm at ~350 hours now and if things haven't improved, they are the same.
I never see the uniformity "issues" that I notice when running the slides during normal content. Normal content is the true measuring stick.
Originally Posted by guvadc View Post
For what it's worth, my 65VT60 is exactly the same. I wouldn't worry about it.
Originally Posted by Scott Oakley View Post
Same here.
Thanks for the the feedback. Right now there are only 32 65" VT60s in stock at Amazon. If I needed to exchange this, it would have to be right away. Even then, I might get another set with worse screen uniformity. I just hope my eyes aren't drawn to it like clouding on an LCD. None of the online reviews mentioned screen uniformity variances. It's an August build, by the way. There is foam around the fan, indicating the fan fix was applied, and it's silent, unless I press my ear up against the back.
JPowers is offline
Old 01-16-2014, 10:29 AM
eric3316's Avatar
Quoted: 840 Post(s)
Liked: 959
It's not mentioned by reviews because you will never see it while watching content unlike clouding and flashlighting. No one reviews a TV watching colored slides.
Enjoy your TV and stop stressing. If you actually notice any of thisscreen uniformity issues while watching the TV, you will be the first one.
eric3316 is offline
Old 01-16-2014, 10:30 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Me too...received my 60VT60 October 2013 build last Saturday from Best Buy and it had 00000 hours on it.
Panasonic P60VT60 Calibrated by Chad B
Marantz NR-1504
GoldenEar SuperSat 50s
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
Old 01-16-2014, 10:32 AM
Cal1981's Avatar
Quoted: 238 Post(s)
Liked: 239
I'm looking at Amazon is now and it's showing only two new 55VT60s at US-Appliance and for pretty much the full retail price (unbelievable!). There are now only three used 60" sets, one from Amazon Warehouse Deals that sounds like it's a bit banged up and two new 65" sets directly from Amazon.
Cal1981 is offline
Old 01-16-2014, 10:42 AM
cpc
cpc's Avatar
Can you turn off the speakers on the VT60 when using your home theatre receiver and speakers? I know you can put the volume down to zero and/or mute the sound on the TV, but I was wondering if I could actually turn off the speakers completely.
cpc is offline
Old 01-16-2014, 10:52 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Yes, you need to go to Veira Link in the apps menu to make sure your avr is registered/communicates. If so, you can change the output from TV to Home Theater Speakers. Pg 143 in the eHelp book.
cpc likes this.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
Old 01-16-2014, 10:58 AM
ssc351's Avatar
Originally Posted by ssc351 View Post
Yup also a June build. I watched We are the Millers last night and the graininess is definitely WAY better on Blu-ray, but still a bit there. Not sure if I was just being sensitive to it when watching Avatar or what. So I guess it may be a content issue? But for the quality of the screen, either I really need to do a custom cal because Dnice and Larry's setting still give to much "greeness" or my set is screwy. Not sure what to think at this point.
My Post/problems from a couple weeks ago above...
So I returned the TV and got a new one from Amazon, just finished the slides. And oh man...it is SOOOOOOO much better. Now I get why everyone loves this TV. Before I didn't really get it and didn't think it was worth the money. But now I totally get it. I mean it is night and day. Even my wife noticed who doesn't really have an eye for these sorts of things.
I wound up with an October build date so no major fan noise and the buzzing is also a lot less than it was on the previous TV. Anyway, if any of you guys are having problems with June builds you may want to look into a return/exchange (if they are still available that is!)
ssc351 is offline
Old 01-16-2014, 11:04 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
I bought a 55VT60 (June build) just before Christmas but decided to exchange it for the 60VT60. When the 60 arrived (October build), I noticed a much brighter and cleaner/crisp picture. I thought I was imagining things until I saw several other people were having problems with the June build.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
Old 01-16-2014, 11:05 AM
Mean Gene's Avatar
Same to you.
Anybody in the dc metro area have Pilot deliver thiers recently? Just wondering what to expect...
Old 01-16-2014, 11:20 AM
Cal1981's Avatar
Quoted: 238 Post(s)
Liked: 239
Om my setup, when the TV gets an incoming HDMI audio signal from my Denon AVR, the speakers automatically cut off and that's even with HDMI control off on the Denon and Viera Link off on the TV. It doesn't seem to matter which of the TV's HDMI inputs the Denon runs to or which of its own inputs is active. I have not been able to get a clear explanation of this or to figure out if it's a problem or a feature. I suspect the latter and I like it because it saves having to turn the TV's volume down but it would be nice to know what the mechanics of this is. If somebody knows please post.
As long as I'm asking. When I got the Vt60 I think that I was able to completely turn off the top menu bar when the set powered on, but now I'm not sure and can't seem to do that. See the pic below and, again, any ideas would be appreciated.
cpc likes this.
Cal1981 is offline
Old 01-16-2014, 11:27 AM
MCF34's Avatar
Quoted: 63 Post(s)
Are my fans even running? My set is dead silent. My 65" does have the foam strip running top to bottom on the right fan (when facing front of tv) but I don't think they have ever turned on!!! Putting my hand on the back of the set, it is very warm, I would estimate between 110-120 deg F. How do you know if the fans are even kicking on?
Jutter is gone..zipadeedoodah zipadeeday!!!
MCF34 is offline
Old 01-16-2014, 11:32 AM
Liked: 99
I believe what they are noticing is the small black lines that come right off of where te bezel ends. Every plasma set I have owned had this. On one side you can see a faint green line and on the other a violet look line. This is where the pixels fire from I believe and it's all part of the picture. They lye a few centimeters off of te bezel before the actual picture starts. If this is what you are seeing do not stress this..it's all apart of how plasma is manufactured and completely normal. Now line bleed is also normal but I don't think that is what is being talked about. I posted a pic a few pages back about the line I was seeing but my new set has it as well (not the line I just explained that's apart of manufacturing) but since it was also on this set I'm pretty sure it's normal because you can't see it from normal viewing distance. Your not watching your TV with your nose to the screen, we all want perfection especially if you owned pioneer which were close to perfect but still had its cons, but reality is not every TV is going to be perfect it's just technology and the nature of it. That's what I've learned after 5 years on these found especially from this thread as well.
JPowers likes this.
Old 01-16-2014, 11:35 AM
MCF34's Avatar
Quoted: 63 Post(s)
Has anyone actually had Dnice calibrate their VT60 and if so, what do you think?
MCF34 is offline
Codeman00's Avatar
I would like to know this too. That menu at the top is worthless to me.
Codeman00 is offline
Old 01-16-2014, 11:37 AM
Sigfod's Avatar
Same to you.
I had mine delivered by them to Brambleton. They were very professional and did a good job. They are good for a delivery service.
Sigfod is offline
Old 01-16-2014, 11:40 AM
Liked: 99
Make sure that when you are setting your home screen you set it to the full screen home screen, I believe if you have it take your picture for that screen that's the one that will always come up. Overall when you go to the menu screens just select full screen as your home screen and that bar should no longer appear. Everytime I turn my set on there is nothing there but the HDMI box like your cable box in the left corner. Also if that does not work it could just be a slight glitch, make sure you are updated to the latest version update which can be checked via the TVs menu(can't remember which setting but do know its on the last two options I believe in the menu) not a big deal cuz you just have to click down on the remote and then "ok" (middle button between the scroller buttons) and it will rid of that banner. I'm not 100% on this but try it out.
Old 01-16-2014, 11:50 AM
kma100's Avatar
Quoted: 43 Post(s)
Liked: 27
Where can I download the eHelp book?
kma100 is offline
Old 01-16-2014, 11:51 AM
kma100's Avatar
Quoted: 43 Post(s)
Liked: 27
I am getting my VT60 delivered through Fedex freight. Any guidance on what they do/don't do?
kma100 is offline
Old 01-16-2014, 12:02 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Here...under owners manual - Panasonic Specs
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Panasonic , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv
