Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 397 - AVS Forum | Home Theater Discussions And Reviews
 246Likes
post #11881 of 16778 Old 01-28-2014, 12:58 PM
eric3316's Avatar
Quoted: 839 Post(s)
Liked: 959
Originally Posted by cpc View Post
What options do I have for additional / better 3D glasses? I previously bought PS3 glasses for my 60ST30 but I guess those don't work with the 65VT60 bc they are IR and the xx60 series TV's use bluetooth, correct?
Samsung makes like $20 glasses. I can't remember the model number. Something like 5100 or something like that. Just search Samsung 3D glasses and it is the cheap ones that come up. They are the most popular and affordable.
cpc likes this.
eric3316 is offline
post #11882 of 16778 Old 01-28-2014, 01:01 PM
5150zx's Avatar
Quoted: 36 Post(s)
Liked: 65
Originally Posted by eric3316 View Post
I am using SS's second list of settings (BT.1886) and find skin tones look even better then the first settings he posted but both of his settings have looked the best to my eye so far.
No need to touch a single setting anymore. If someone posts a new set of settings I might give it a try to to see how it looks, otherwise I just watch my TV like I used to watch it years ago, focusing and paying attention to the actual programming.
I noticed on Silly Sally's settings that I don't see settings for Color Detail Adjusting for R, G, B, Cyan, Magenta and Yellow. Do these simply stay at 0? Or did I overlook them? Thank you to anyone who knows the answer.
5150zx is offline
post #11883 of 16778 Old 01-28-2014, 01:07 PM
dpjb's Avatar
Originally Posted by Walking Beast View Post
Just got the tv. A replacement for my burned in gt50 as mentioned.
A few things ive noticed. At first the black level seemed like a crazy improvement. I use the tv only for gaming. So when I tried killer instinct after making some adjustments it was very impressive. So I see the tv is capable of some crazy contrast.
SNIP........
I don't think you're going to find much help in this thread. Most on here are trying to achieve realism, not the look you are going for. And I think most in this group would consider this a poor choice for a gaming only set due to IR issues.
The "darkness" of the panel has been discussed. I think it's safe to say if you set panel brightness to high and contrast to 100, that's the brightest you're going to get it.
I'm not sure, having already burnt one plasma, this was your best choice as a replacement. This sounds like an ideal situation for an led set.
dpjb is offline
post #11884 of 16778 Old 01-28-2014, 01:07 PM
eric3316's Avatar
Quoted: 839 Post(s)
Liked: 959
Leave at zero. He uses a different system to set those and they won't translate over to the settings within the VT60. So best to leave at zero.
5150zx likes this.
eric3316 is offline
post #11885 of 16778 Old 01-28-2014, 01:10 PM
cpc
cpc's Avatar
I will look into the Samsung 5100's.
What about the Xpand X105B glasses?
I notice the Panasonic TY-ER3D4MU can be switched to 2D which is nice. I don't imagine any other glasses allow that?
cpc is offline
post #11886 of 16778 Old 01-28-2014, 01:11 PM
Mean Gene's Avatar
These are the glasses I was recommended. I have not bought any yet so I cannot vouch for them. I wish the PS3 glasses worked for the vt60, they were the best all around glasses for the 30 series in my opinion.
http://www.amazon.com/gp/product/B00BIP816Q/ref=ox_sc_sfl_title_7?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Mean Gene is offline
post #11887 of 16778 Old 01-28-2014, 01:14 PM
lapino's Avatar
Quoted: 73 Post(s)
Since I found broadcast tv a bit darkish, I have been experimenting a little with my pro1 settings. Seems when I out gamma on 2.0 things look quite a bit better and bright. Am I destroying the picture in doing so? Or is gamma 2.0 not that unusual to use for normal tv viewing (like football now). For movies I use pro2 with warm colour and a 2.4 gamma.
Anyone doing the same? Also, what does 'adaptive gamma control' do?
lapino is offline
post #11888 of 16778 Old 01-28-2014, 01:19 PM
SeLfMaDe111985's Avatar
Liked: 99
If I wiggle my TV it has give. It won't shake because it is on a wooden floor on my first floor so there are no vibrations.
Again, there is a lot more involved then someone making a stand in their basement saying, hey you think this is strong enough. There are so many other things to stress over about your TV, the stand should not be one of them. It was built to hold the TV. It can hold the weight and probably much more.
That's the word I was looking for..like if I pop in my flash drive for the slides or an HDMI cord I can see the TV "wiggle" a little from left to right or front to back which seems like a feature so that if there are a lot of vibrations that the TV stand can absorb them better with its little give "wiggle". It is definitely not swaying, that was a bad word to use lol sorry.
But no one has answered my question yet about what the "V" is made of? Is it metal
Under hard plastic or just all solid plastic?
SeLfMaDe111985 is offline
post #11889 of 16778 Old 01-28-2014, 01:26 PM
lapino's Avatar
Quoted: 73 Post(s)
do these work with the gt60?
lapino is offline
post #11890 of 16778 Old 01-28-2014, 01:40 PM
eric3316's Avatar
Quoted: 839 Post(s)
Liked: 959
Does anyone actual use the voice commands on their TV. I had a Samsung TV that had voice commands and it worked much better since you were able to use them without having the remote in your hand. So I was able to walk but my Samsung TV and turn it on or off with my voice, no remote or button pushing needed. Change the volume from the other room just with my voice. It was great if you your hands were tied up or cooking and you didn't want to touch anything.
On the VT60, you have to active voice controls with the remote. if the remote is already in your hand what would be the point and changing the volume with your voice? At that point isn't it just quicker to hit the volume button. I can understand maybe for long search phrases but I am not even sure where I would use this or if I have ever been in a situation yet where I could have used it even.
eric3316 is offline
post #11891 of 16778 Old 01-28-2014, 01:54 PM
Liked: 99
Those with the fan fix..do you still hear a low pulsing noise cause if so that means that's as far as the fan fix can take this TV and there would be no point in calling Panny because Alls I hear is a low pulse noise.
post #11892 of 16778 Old 01-28-2014, 01:55 PM
turbe's Avatar
Liked: 95
Originally Posted by turbe View Post
I have great news for those interested in having D-Nice calibrate your display(s).
Effective immediately and going forward.
eek.gifonly $300 - $330 depending on Region (North of New York is $330, most other Regions $300). This is $100-$150 lower than before. eek.gif
Besides his Houston Tour, he has 2 (maybe 3) slots available for Los Angeles California on Sunday February 16 (the immediate L.A. area only).
Originally Posted by Toronto Guy View Post
Does he ever make his way up to Toronto, Canada?
I don't think D-Nice does but he may if there were 6 others... I doubt it would be in the $300-$330 range though...
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #11893 of 16778 Old 01-28-2014, 02:02 PM
Walking Beast's Avatar
Thanks guys. Its hard for me to describe my picture prefferance so I may not be doing it so well as I said. I would say that realism is something I want to see on my display but at the same time not the muted subdued "realism" that I find in alot of pre set modes. I love thx bright room for example, but with the contrast and color maxed. So maybe it is a mix of realism and hyper realism. Video game polygons dont tend to look as realistic as say a tree in a movie. The graphic look is always more colorful I find.
After spending some time tweaking the more basic settings I can say Ive gotten the set to look really good. The first few hours it always seems like the set will not be good enough. My eyes are also adjusting to the new set as well. My expectation was trying to match my previous gt50 at first, and this set is able to match it but it also has a different better , more high contrast look. The black levels are crazy. Reminds me of my Sony XBR CRT but with a much larger screen, no geometrical issues, and very sharp. I was coming from a sony XBR so thats why I was very particular and cannot stand LCD motion blur, or LCD tech in general as it really burns my eyes trying to see detail that isnt there. That and that motion smear ruins any immersion for me. I lover CRT and plasma. Im ok with some image retention. The reason I returned my GT50 was because i got these large YELLOW BLOTCHES on the screen. They did not fade after 4 months. If I thought that they would fade out like my other image retentions I would have ignored it.
It took about a year for that issue to surface. Im not sure exactly what caused it. I noticed it during long sessions of GTA. I expected HUDS to be in my screen for a month or several before fading out as that has been normal.
Anyway I am pretty damn pleased so far with how it is looking. I think I will end up keeping it for the years to come, unless I get blotches again. Hopefully not this time.
Here is an example of the type of image that I like. I finally got it looking up to my standard. Maybe some of you that are better with technical descriptions can describe this style, or maybe you will all hate it. But this is what I was tweaking to obtain
Walking Beast is offline
post #11894 of 16778 Old 01-28-2014, 02:04 PM
eric3316's Avatar
Quoted: 839 Post(s)
Liked: 959
You know you are going from OCD to crazy now, right? There is a difference between the two.
I am going to go out on a limb here but willing to take the risk and say there is absolutely nothing with your TV, your stand, your wires, your floors, your walls, your sound system, your alarm clock.....You are good. Watch the freakin TV and enjoy it already. You are almost at Scott Oakley level and once you hit there it gets even harder to talk you down from the ledge.
Let me tell you something. I am highly OCD. I won't touch my food with my hands. I eat potato chips with a fork, popcorn with a spoon, etc.....You guys actually make me feel normal. I need to find friends like you to hang out with. Then I might be considered the normal one. hahahaha
Donat76 likes this.
eric3316 is offline
post #11895 of 16778 Old 01-28-2014, 02:04 PM
Toronto Guy's Avatar
Too bad... Does he (or anyone else) know of a good calibrator in the Toronto, Canada area?
Toronto Guy is offline
post #11896 of 16778 Old 01-28-2014, 02:05 PM
CatchersDad's Avatar
Liked: 41
I'm sure it's been posted somewhere but I can't find the answer I'm looking for. Can someone explain to me why these plasmas shouldn't be transported laying down in or out of the box if carefully cushioned?
TIA
CatchersDad is offline
post #11897 of 16778 Old 01-28-2014, 02:08 PM
eric3316's Avatar
Quoted: 839 Post(s)
Liked: 959
TIA
Because the weight of the screen. A bump of any kind has the ability to damage it if it were to bounce around in that position.
eric3316 is offline
post #11898 of 16778 Old 01-28-2014, 02:08 PM
DvdJags's Avatar
Quoted: 24 Post(s)
Liked: 40
I just refused shipment of a P65VT60 from Amazon. The first thing I noticed was the power cord sticking out the bottom of the box. I as like oh my this cannot be good. We opened the box to find the Styrofoam that protects the top of the TV broken into several pieces. I knew that was not a good sign. There were three deep gashes cut into the silver metal at the top left of TV. In that area the screen was cracked in several places. So there goes my chance of owning this great TV. What is up with all these cracked screens coming from Amazon? mad.gifmad.gifmad.gifmad.gifmad.gif
DvdJags is offline
post #11899 of 16778 Old 01-28-2014, 02:09 PM
JPowers's Avatar
Liked: 29
You can peel the yellow sticker off, now. The energy police aren't going to come after you. smile.gif
eric3316 likes this.
JPowers is offline
post #11900 of 16778 Old 01-28-2014, 02:09 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Yes, selfmade, some do still hear noise after the fix.
vinnie97 is offline
post #11901 of 16778 Old 01-28-2014, 02:23 PM
JPowers's Avatar
Liked: 29
I tried it the other day to do some searches, and it worked fine. It's not something that's I'd use. I don't trust the Samsung voice command setup being on all the time. That's really creepy having a little voice recorder hooked up to the internet all the time. They warn you of that risk in the privacy agreement.
JPowers is offline
post #11902 of 16778 Old 01-28-2014, 02:36 PM
eric3316's Avatar
Quoted: 839 Post(s)
Liked: 959
I don't think you need to be online for Samsung's voice activation to work. I think it's built into the OS software. It just has an always listen mic on it.
eric3316 is offline
post #11903 of 16778 Old 01-28-2014, 02:42 PM
turbe's Avatar
Liked: 95
Check the 2nd post Here
ControlCAL™
turbe is offline
post #11904 of 16778 Old 01-28-2014, 03:11 PM
Great, thanks. Are these people professional calibrators?
post #11905 of 16778 Old 01-28-2014, 03:16 PM
turbe's Avatar
Liked: 95
Great, thanks. Are these professional people professional calibrators?
Yes.. you should also check out the Calibrator Reviews threads (one in my sig, another htwaits has)..
ControlCAL™
turbe is offline
post #11906 of 16778 Old 01-28-2014, 03:35 PM
evanescence0315's Avatar
does anybody know what the measured black level of the 55 inch vt60 is? i keep looking but I can't find it.
evanescence0315 is offline
post #11907 of 16778 Old 01-28-2014, 03:46 PM
Famouss's Avatar
Quoted: 22 Post(s)
Liked: 48
I thought I saw sometime ago that it was around .002, but don't take my word for it.
Panasonic TC-P65VT60
Sony BDP-S5100
Elite PRO-101FD
Famouss is offline
post #11908 of 16778 Old 01-28-2014, 04:41 PM
ok I believe it must be lower since thats what chad measured on the vt50 in 96 mode.im just wondering if there really is much difference with different sizes because I had 60inch vt60 and had to send it back and I could only get a 55 inch and the blacks look abit lighter.
post #11909 of 16778 Old 01-28-2014, 05:41 PM
Mean Gene's Avatar
I would assume so if they work with the vt60, but I cannot confirm.
post #11910 of 16778 Old 01-28-2014, 05:41 PM
Famouss's Avatar
Quoted: 22 Post(s)
Liked: 48
Yes the blacks are higher on the smaller panels but I don't have an exact number, maybe someone else here knows.
Sony BDP-S5100
Elite PRO-101FD
Famouss is offline
Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Panasonic , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv
