Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 445 - AVS Forum | Home Theater Discussions And Reviews
 250Likes
post #13321 of 16810 Old 03-04-2014, 06:02 PM
DaveNY's Avatar
When watching blu ray movies I have noticed some horizontal 'tearing' for lack of a better word during scenes where there is a slow pan from left to right or vice versa. Is this considered judder? My settings are as follows:
THX Cinema Mode
All enhancements turned off
Game mode off
24p direct in 96Hz
1080- pure direct on
HDMI content type auto
HDMI/DVI RBG range auto
Black level light
Oversan off
H size Size 1
Pixel orbiter auto
Blui ray player is a Sony S5100. Everything is connected via HDMI, Any suggestions would be greatly appreciated.
DaveNY is offline
post #13322 of 16810 Old 03-04-2014, 07:05 PM
smurraybhm's Avatar
Quoted: 1515 Post(s)
Liked: 1827
THX Cinema Mode
Game mode off
24p direct in 96Hz
Black level light
Oversan off
H size Size 1
Pixel orbiter auto
Try it with 24p off which disables 96Hz. Some owners prefer 60Hz to 96Hz due to what you are seeing.
RIP Cricket - my pug and little buddy Jan. 10, 2017
Panasonic 60VT60 (cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 w/ 2500+ blu-rays and growing. Yes I still have HD-DVDs too.
smurraybhm is online now
post #13323 of 16810 Old 03-05-2014, 04:19 AM
leiff's Avatar
Quoted: 83 Post(s)
when watching 3d channel with my TiVo Comcast, i find image very jittery and unpleasant to watch with motion smoothing off so i set it to weak and it looks much better. for Comcast 2d all content looks fine with motion smoother off. Was wondering if others have noticed this also. Does everyone use 100 or 120 3d refresh rate?
leiff is offline
post #13324 of 16810 Old 03-05-2014, 04:57 AM
wkearney99's Avatar
Quoted: 331 Post(s)
Liked: 129
3D? Someone uses the 3D stuff? I tried, once, using the 3D output from an Xbox One game. Meh, was about the best way to describe it. Typical 3D complaint though.
When you introduce Comcast into the mix I'd have to wonder how much would get attributed to their tendency to horribly compress (or otherwise bastardize) the signal.
What was the program? And might it also be good to check the 3D forums here? http://www.avsforum.com/f/193/3d-central
wkearney99 is offline
post #13325 of 16810 Old 03-05-2014, 05:51 AM
paulbike's Avatar
thanks.
paulbike is offline
post #13326 of 16810 Old 03-05-2014, 06:55 AM
paulbike's Avatar
Thanks for your reply.  Good question about the source:  They are different. While I can see a very small amount of motion distortion on the Fifth Element Blu-ray and also on Dish,  it is far more obvious on Netflix. and "motion smoothing" does not seem to help much.  Interesting.  My computer is connected to the TV via a very long ethernet cable (100 ft.). Usually wired is better, but I wonder if it might help to shorten the ethernet cable (to the needed 35 feet) or I can try to figure out how to use wi-fi instead from my AT&T modem?
I do hope Netflix figures out a way to allow the VT60 to use the THX modes.  Maybe that will help.
Geek Squad used an optical cable for one connection (not sure which one) and HDMI for others if that matters.
paulbike is offline
post #13327 of 16810 Old 03-05-2014, 07:33 AM
eric3316's Avatar
Quoted: 841 Post(s)
Liked: 959
3D through cable is no way to really judge 3D. Compress a 3D image is way worse then compressing a 2D image as their is much more involved relying out a good signal to produce the 3D effect and pq. Whatever you have to do to get your 3D picture to look decent through cable is normal. There really doesn't need to be any more trouble shooting past compressing of the picture.
eric3316 is offline
post #13328 of 16810 Old 03-05-2014, 11:40 AM
wkearney99's Avatar
Quoted: 331 Post(s)
Liked: 129
Ethernet supports up to 100 meters per connection. Shortening the cable will make no difference, not unless the cable you've got is causing network problems. Which would be hard to show unless the gear you've got on it supported showing raw network port stats. Most of the time you're only going to get this with some kind of PC attached (pc, mac, linux, whatever) or via a network switch that has monitoring and management features (most won't).
Going wireless will definitely not make it better, quite likely worse.
There's a ton of variables involved with playing video. The original source, the mastering to media, the compression of a cable or satellite transmission, player firmware, download throughput variability, the list is nearly endless. It's not impossible to pin down but making fair comparisons across different distribution systems is very difficult.
post #13329 of 16810 Old 03-05-2014, 11:52 AM
DaveNY's Avatar
Thanks for the advice, I will give that a try and report back.
DaveNY is offline
post #13330 of 16810 Old 03-05-2014, 12:02 PM
paulbike's Avatar
Sounds like I need someone capable to just check each possibility until the culprit shows itself.  One lesson so far - just because a problem is visible on the TV, doesn't mean the TV is at fault. Thanks for your reply.
paulbike is offline
post #13331 of 16810 Old 03-05-2014, 06:16 PM
sage11x's Avatar
Quoted: 783 Post(s)
Liked: 837
Interesting, my VT60 suffers the same green splotches that my S30 does. Was updating the firmware tonight and the grey box containing the progress bar is just the right shade of grey to show off the green. Did anyone ever figure out what causes this??
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is online now
post #13332 of 16810 Old 03-05-2014, 06:55 PM
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
so I'm heading home in a week for spring break and we have a Benq W-7000 3D projector. I do not have glasses for it, but I was wondering if I could somehow pair the panasonic glasses with it. is that even possible?
Ou8thisSN is offline
post #13333 of 16810 Old 03-05-2014, 10:16 PM
socci's Avatar
Quoted: 41 Post(s)
Hey, I was just curious if anyone knew the work required to replace a cracked screen on a VT60, if even possible?  I can get a almost new VT60 with a cracked screen, and another new VT60 with a blue stripe going down the screen both for really cheap.  Can I take the screen from the one with the blue stripe (assuming the screen isnt the cause of the stripe) and put it on the good TV with the cracked screen? I can pretty much fix anything with instructions and the right tools, but do not have any experience with TVs, so any help is appreciated.
socci is offline
post #13334 of 16810 Old 03-05-2014, 11:04 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
If the VT60 is anything like other plasmas, and I think it is, you would have to replace the panel which in the best of times would be expensive. Someone with the same set might want to use a set like this for spare parts.
htwaits is offline
post #13335 of 16810 Old 03-06-2014, 09:43 AM
neveralone777's Avatar
Quoted: 45 Post(s)
Has anyone had experience with getting their Panasonic Plasma serviced? I've had mine for less than 2 months and it is scheduled to be serviced for the second time next Friday. The first time I had a piece of dirt behind the screen which they removed. I had to fight to get this done. The first time I called they said there was nothing they could do. I called again and said that dirt behind the screen had to be a manufacturer defect and they agreed.
The day I got it back it would shut off by itself if I used the TV speakers. I hooked up my stereo to it and it worked fine. One week later it won't turn on at all and blinks the red light 12 times. I am a little disappointed in Panasonic's Limited Warranty. Both times they are having it serviced by a small local shop that repairs various electronics but doesn't specialize in any one area. Panasonic told me the warranty covers services but never covers a replacement. They said they will pay to have my TV serviced but will not replace the unit no matter what happens.
Even with all this trouble I ended up getting the 65VT60 new in box for around $1800 which is an amazing deal. So I feel like I need to keep fighting to get this thing working correctly because there just isn't any other TV I would rather have other than the ZT60. I hooked up my old entry-level Samsung plasma to keep me busy and wow! I didn't realize how great the picture was on the 65VT60 until I went back to my old set. My Samsung which I used to brag about looks like a 10 year old TV compared to the VT60.
So if anyone has had their TV serviced from Panasonic I would love to hear about your experience. Also does anyone know how soon you need to buy Squaretrade warranty after the initial purchase, because it is looking like I will need it?
neveralone777 is offline
post #13336 of 16810 Old 03-06-2014, 09:53 AM
smurraybhm's Avatar
Liked: 1827
They have to replace it if it can't be repaired. However, the replacement only needs to be of equal value, not quality or the same display. That means you could end up with one of their LEDs eek.gif
post #13337 of 16810 Old 03-06-2014, 11:08 AM
Chere's Avatar
Quoted: 352 Post(s)
Liked: 185
^^^^^ I have never even considered an extended warranty for any of my previous HDTVs but stories like these and the fact that it has been discontinued is seriously making me consider getting one for my 65VT60. Are there others here in the same predicament?
Chere is offline
post #13338 of 16810 Old 03-06-2014, 11:52 AM
mo949's Avatar
Liked: 1134
me. I consider(ed) EW taxes on the 'dumb' previously. As I now sometimes quip though, at 99$ for a ST 3 yr (+'x'mfr yrs) I am dumb enough to buy one on my 3k set. If you are within 60 days of your purchase, check out the link in my signature for that deal.
mo949 is offline
post #13339 of 16810 Old 03-06-2014, 11:54 AM
Mean Gene's Avatar
Just wanted to ask one more time if anyone wants a 65vt60 box? Going to be recycled next Friday. Pickup in Montgomery County, MD.
Mean Gene is offline
post #13340 of 16810 Old 03-06-2014, 12:24 PM
Scott Oakley's Avatar
Quoted: 37 Post(s)
Liked: 89
Can you post your source for this statement?
Donat76 likes this.
Panasonic 2013 55VT60
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
Scott Oakley is offline
post #13341 of 16810 Old 03-06-2014, 12:36 PM
smurraybhm's Avatar
Liked: 1827
Here you go - I have never heard of anyone getting their purchase price refunded.
post #13342 of 16810 Old 03-06-2014, 12:36 PM
mo949's Avatar
Liked: 1134
Many people with bad vt50's didn't get replacement vt50's, they got replacement vt60's of the same size screen. So replacing with different model is established already. If they don't have plasmas then of course you are looking at getting a 65 inch vt60 possibly getting replaced with a 65inch 4K LCD model of the year when you make that claim in the future. They may just be nice about it though and give you a cash out option anyway.
mo949 is offline
post #13343 of 16810 Old 03-06-2014, 02:24 PM
Quoted: 37 Post(s)
Liked: 89
Okay but you're not the person who posted what I was asking about.
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
post #13344 of 16810 Old 03-06-2014, 02:36 PM
starcat's Avatar
Guys, I've got a new 65" VT60 and just did the settings as of
http://www.soundandvision.com/content/panasonic-tc-p65vt60-3d-plasma-hdtv-settings
I noticed that when I start playing a movie (DVD or 1080p), about 1" of the left side of the screen is black, it looks like if the picture is off center. When I stop the player the graphic screen is perfectly centered. I fired up the service menu of the 65VT60 and looked at the built-in test patterns -- everything is really perfectly centered. As soon as start a movie, it looks like the pic is off-center by 1" to the right. Any help is highly appreciated. Thanks.
PS:
The player by itself is fine, I just hooked it to my other Panasonic 50" PF10 display and it just plays everything fine.
Edit:
This happens only with SD DVD movies, HD being BD or MKV are fine..
Wanted: M&K Sound MPS-2510P, S-150P, MPS-2525P, SS-250P
Stereo Integrity HT18 D4 subwoofer drivers
starcat is offline
post #13345 of 16810 Old 03-06-2014, 02:59 PM
eric3316's Avatar
Quoted: 841 Post(s)
Liked: 959
PS:
It is the pixel orbiter which will move the picture around. If you set it to auto it should fix that but I leave the orbiter on. It does not effect the picture enough to not have it on and would rather have it help with IR.
eric3316 is offline
post #13346 of 16810 Old 03-06-2014, 03:34 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
And?
htwaits is offline
post #13347 of 16810 Old 03-06-2014, 03:35 PM
Iron Mike's Avatar
Quoted: 66 Post(s)
Liked: 413
hi guys,
I posted an updated calibration workflow for a Panny VT60 & Lightspace in this tread:
http://www.avsforum.com/t/1521259/lightspace-custom-color-patch-set-gamma-calibration-workflow
Besides other things, it deals with the crazy Gamma spikes the Panny's have....
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
post #13348 of 16810 Old 03-06-2014, 04:18 PM
starcat's Avatar
Checked with the Orbiter, it is not. Also, this happens only with SD DVD signal, HD is fine. The off-center is for about 1", pretty thick black bar on the left...
starcat is offline
post #13349 of 16810 Old 03-06-2014, 04:27 PM
Jason626's Avatar
Quoted: 157 Post(s)
Liked: 154
Double check your vt screen setting. Use format full aspect ratio. H size 1. See if that's any help.
Jason626 is offline
post #13350 of 16810 Old 03-06-2014, 04:48 PM
eaayoung's Avatar
Quoted: 209 Post(s)
Liked: 135
Someone with a set that had the fan fix and which resulted in microfractures to the screen, got his set cashed out for the purchase price. I think they paid same amount he paid for his set but didn't include tax. Took several months for Panasonic to come through. He's is the only one that I'm aware of.
Donat76 likes this.
eaayoung is offline
Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Panasonic , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv
