Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 493 - AVS Forum | Home Theater Discussions And Reviews
 246Likes
post #14761 of 16778 Old 07-15-2014, 09:29 PM
DavidHir's Avatar
Quoted: 1706 Post(s)
Liked: 1329
Originally Posted by ChrisFB View Post
THAT SAID - go ahead and mess with it. Try 0, 50, 100 on some different content.
htwaits likes this.
DavidHir is offline
post #14762 of 16778 Old 07-16-2014, 04:33 AM
chunon's Avatar
Quoted: 2024 Post(s)
Liked: 1779
Originally Posted by djsketchie View Post
My 60VT60 was calibrated by D-Nice, and sharpness is set at zero. It's only one data point, but a pretty good one, I would think.
Even calibrators disagree on the sharpness setting unfortunately mine is set at 16.
chunon is online now
post #14763 of 16778 Old 07-16-2014, 06:07 AM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
Use Ted's Disc and you might change it to zero. That will not affect the calibration.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #14764 of 16778 Old 07-16-2014, 08:31 AM
chunon's Avatar
Liked: 1779
I can see the reasoning behind the zero setting , I have found I need a little exta sharpness for my satellite feed
post #14765 of 16778 Old 07-16-2014, 08:33 AM
elito's Avatar
Originally Posted by whipit View Post
When I first got my VT I was able to get the speakers to turn off when using an HDMI source. The only time I hear the tv's speakers is when using the internal apps. I'ts been so long I forgot how. Something about the main apps screen and settings from there I think. At that point I could select home theater or internal, IIRC. I think there's a post in one of the ST/VT/ZT threads about that. Not sure you can change audio sources so I can't help there.
Originally Posted by Wurlitzer-1015 View Post
The quick reply is you need to turn on Viera Link (setup-->viera link setting-->viera link on) then go to the apps section and select the "Viera Link" app. The app will allow you set to audio source, TV or Home Theatre, select "Home Theatre" to turn off the TV speakers.
thanks for your replies - but unfortunately the solution posted by Wrulitzer - is a no go for me, I do have vlink enabled from settings, but I simply cannot access the Vlink app because i don't have anything that's vlink compatible. this is my current setup for my lowbudget home theatre system. tv optical out>DAC>RCA on T AMP>Speakers, am not using AVR's for my setup. wow. i can't believe they took out that option to select audio sources like it was availible couple years back with their older generation. that menu had almost anything you can think of.
elito is offline
post #14766 of 16778 Old 07-16-2014, 09:26 AM
Wurlitzer-1015's Avatar
Yep, that's correct, you'd need something on the other end of the HDMI cable that informs the TV that it can accept audio using ARC before the option will appear on the app.
Guess the only option is the mute button.
55VT60 | Yamaha RX-S600 | Mede8er X10003D | ATV1 running KODI | Wurlitzer OMT 1015 Vinyl | Harmony Ultimate | Miller & Kreisel 5.1 system speakers
Wurlitzer-1015 is offline
post #14767 of 16778 Old 07-16-2014, 12:01 PM
eaayoung's Avatar
Quoted: 208 Post(s)
Liked: 133
Not sure if it helps since unable to review your post, but you can turn off the speakers via the Hotel Menu if thats what you were trying to accomplish.
eaayoung is offline
post #14768 of 16778 Old 07-18-2014, 02:25 PM
vinnie123's Avatar
Quoted: 20 Post(s)
I'm coming from a VT25, and I love this TV, simply amazing! Even better now that it's been professionally calibrated. BTW, no fan noise, none, QUIET!!!
It's so nice, that it's now at the point when the director purposely adds grain as an effect, that I cringe. How dare they add artifacts making the picture less nice! (p.s I'm being a bit sarcastic but half serious too )
vinnie123 is offline
post #14769 of 16778 Old 07-18-2014, 03:06 PM
leiff's Avatar
Quoted: 83 Post(s)
looking for replacement batteries for my 3d glasses. Are these both the same product? The 5 pack sells for $3.18 and the four pack sells for $5.18?
http://www.amazon.com/Energizer-2032...S5F5S3KZ59SVRP
http://www.amazon.com/Energizer-Cr20...TXMY9VQ6G4HW6G
Anyone know if these are good $50 rechargeable 3d glasses?
http://www.amazon.com/SAMSUNG-Compat...pr_product_top
leiff is offline
post #14770 of 16778 Old 07-19-2014, 05:42 AM
Famouss's Avatar
Quoted: 22 Post(s)
Liked: 48
To those who have theirs sets calibrated in both mid and high panel brightness settings, is there a trade off when using high, like mll raised, color less accurate?
Panasonic TC-P65VT60
Sony BDP-S5100
Elite PRO-101FD
Famouss is offline
post #14771 of 16778 Old 07-19-2014, 06:14 AM
chunon's Avatar
Liked: 1779
No no disadvantages other than some increased dithering which I rarely notice.
post #14772 of 16778 Old 07-19-2014, 05:57 PM
mack7's Avatar
Need help with blue tooth connectivity
I am using the tv bluetooth to connect to my Phonak ComPilot hearing aid Streamer. Once connected everything works fine. The problem is establishing the connection. When I turn on the tv, I have to unpair the tv and streamer and start the pairing process from the beginning every time. 90% of the time the connection goes Ok. The other 10% I get an error message like "device not recognized" and have to restart the streamer and sometimes the tv before the connection is made. Do any of you know a simpler, quicker, more reliable process? Are there other hearing aid streamers that connect more easily?
mack7 is offline
post #14773 of 16778 Old 07-19-2014, 06:19 PM
chunon's Avatar
Liked: 1779
Do you have another Bluetooth device enabled like a cellphone ? I get that error if my phone Bluetooth is enabled
post #14774 of 16778 Old 07-19-2014, 06:37 PM
mack7's Avatar
I found one of my cell phones was also paired with the streamer. I deleted the pairing. I will see if the tv connectivity improves this evening and let you know. Thanks for your quick response.
mack7 is offline
post #14775 of 16778 Old 07-19-2014, 06:40 PM
chunon's Avatar
Liked: 1779
You are welcome. I think that will alleviate your issue
post #14776 of 16778 Old 07-21-2014, 06:27 AM
Liked: 0
Hey guys,
I was thinking about getting this set after reading about lip sync issues with the ST60.
Has the VT60 ever had the same problem or any audio delays? I'll be using a Denon AVR with it if that makes a difference.
f33t is offline
post #14777 of 16778 Old 07-21-2014, 06:59 AM
smurraybhm's Avatar
Quoted: 1475 Post(s)
Liked: 1770
I use a Denon 4311 with mine and no issues - bought in May 2013.
smurraybhm is online now
post #14778 of 16778 Old 07-21-2014, 08:03 AM
Stevetd's Avatar
Quoted: 110 Post(s)
Liked: 31
Were the discrete codes ever released for these? I have a TC-P55VT60 and I can't even find it on Panasonic's website anymore.
Stevetd is online now
post #14779 of 16778 Old 07-21-2014, 10:20 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Originally Posted by f33t View Post
Hey guys,
I saw it a couple times a while ago when it was newer. A quick reboot of the Denon (2310)fixed it. Haven't seen any problem in months.
whipit is offline
post #14780 of 16778 Old 07-21-2014, 10:23 AM
chunon's Avatar
Liked: 1779
I have not seen it on my VT60 but it is a regular issue on my ST60 using tv speakers, An avr might rectify that but it is a secondary set for me.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
post #14781 of 16778 Old 07-21-2014, 10:38 AM
Liked: 0
Cheers guys, thanks for the info.
f33t is offline
post #14782 of 16778 Old 07-21-2014, 10:42 AM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 333 Post(s)
Liked: 90
Is this a brand new VT60? Any leads would, or might, be appreciated.
B T C is online now
post #14783 of 16778 Old 07-21-2014, 09:53 PM
rickydenim's Avatar
Quoted: 17 Post(s)
I think I'm going crazy. On my VT60 I am seeing a greenish outline like drop shadow under white text. This is when sitting around 2m distance. As I walk closer to the set it disappears at about 60cm's away. I'm seeing this on my Oppo 103 when I'm selecting titles to stream from my media server but also noticed it last playing Destiny on my PS4. My wife is swearing she can't see it. I thought it may be my eyes, but even with my glasses (slight stigmatism) I see it. I don't have this issue on my Kuro at all!
I've tried all difference picture modes, resolutions, color options etc but nothing removes it. Am I seeing reflections perhaps? Anyone else see what I'm seeing?
rickydenim is offline
post #14784 of 16778 Old 07-22-2014, 12:12 PM
lionorion's Avatar
lionorion is offline
post #14785 of 16778 Old 07-22-2014, 09:16 PM
frankmar's Avatar
Quoted: 78 Post(s)
I have tried D-nice and another setting and this one seems to suit me fine. I have not yet done the 3d.
PRESENTLY:    TCP55VT60               PS3 SLIMIR 2 BT RE-BL DENON X2200W [B] FIBETV
MOTOROLA PVR VIP-2262
PARADIGM MONITOR 7 v6 front speakersKLIPSCH SUBWOOFER
KSW10
kLIPSCH SATELITE SS-1kLIPSCH CENTER SC-1HARMONY ONE
PARADIGM ATOMS V6 (front height) NOW SYSTEM IS 5.1.2
frankmar is offline
post #14786 of 16778 Old 07-24-2014, 10:39 PM
Dabois09's Avatar
Quoted: 270 Post(s)
Liked: 75
So there's no black crush on high panel brightness on this set? I know the ST60 suffered from quite a bit of crush under high?
Dabois09 is offline
post #14787 of 16778 Old 07-25-2014, 04:23 AM
chunon's Avatar
Liked: 1779
Not if the calibration is done correctly
post #14788 of 16778 Old 07-27-2014, 02:45 PM
SRussell's Avatar
Quoted: 14 Post(s)
I have changed both HDMI content type and HDMI/DVI RGB range to AUTO on my 65VT60. When changing sources (using AVR connected to HDMI 2) from a YCbCr source(blue ray player or Dish DVR) to an RGB source(Roku3) the TV does not change automatically and the black level on the RGB source is incorrect until the TV is turned off and then turned back on again. Is this behavior correct?
SRussell is offline
post #14789 of 16778 Old 07-27-2014, 03:13 PM
sillysally's Avatar
Quoted: 828 Post(s)
Liked: 848
Its probably a hand shake issue.
You could try and set your VT60 to 16-235, legal video range.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #14790 of 16778 Old 07-28-2014, 01:32 PM
BldyBg's Avatar
Quoted: 16 Post(s)
Like sillysally said, it very well does sound like a handshake issue. My only RGB source is my HTPC (full range) and it changes correctly with my AVR. Is there a reason your Roku is set to RGB? Do you use it for anything other than video like gaming apps? I dont think the issue is changing to an RGB source, it seems more like changing to the Roku. Many standalone media players I've tried don't necessarily shake hands when changing inputs on the AVR. I've had this problem a few times with Apple TV 3.
BldyBg is offline
Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Panasonic , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv
