Official Panasonic VT60/VT65 Series Discussion Thread [No Street Price Talk] - Page 566 - AVS Forum | Home Theater Discussions And Reviews
 263Likes
post #16951 of 16959 Old 08-20-2017, 02:52 PM
Originally Posted by Test Ickles View Post
I have a GT30 apart right now and see what you mean about stuff being in the way.
What stopped me on the VT60 was when I was trying to remove the right left side (viewed from rear) vertical rail, I encountered black tape on the rail which looked like it went down to the panel. At that point I was unsure what the purpose of the tape was and if I could effectively put it back once I got the rail off. (if they had just mounted the bottom rail on top of the side rails - it would have been a piece of cake)
Bob Irving is offline
post #16952 of 16959 Old 08-21-2017, 04:47 PM
Quoted: 269 Post(s)
Liked: 115
Originally Posted by DLCPhoto View Post
Interesting - are you trying to fix the same type of problem, or something different?
Pictures and outcome when they're available, please
SC board went out again. An easy fix once the board is repaired. I was just looking at the vertical ribbon cables and they are harder to get to than the horizontal.
Test Ickles is offline
post #16953 of 16959 Old 08-21-2017, 06:26 PM
DLCPhoto's Avatar
Quoted: 917 Post(s)
Liked: 270
Thanks for the reply.
I called a couple of local repair stores. One said it was 90% or more the panel, and therefore not cost-effective repair. The other said bring it in, $40 diagnostic charge, couldn't estimate chances of fixing it.
Not sure what I'll do; may just try to sell it as is, and see what I can get.
JVC RS400, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, each powered by a bridged Adcom GFA-555; Center JBL LSR-308
Dolby Bed (4): Wharfedale Diamond II's, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLC Photography
DLCPhoto is online now
post #16954 of 16959 Old 08-22-2017, 08:08 PM
jrob23's Avatar
Quoted: 21 Post(s)
Got one!
I just purchased a mint 60VT60 off craigslist for cheap. I am absolutely blown away by the PQ. It came with 3 pair of 3d glasses but I need batteries which should arrive by Thursday. Can't wait to scour this thread for advice on calibration settings.
sickkent likes this.
jrob23 is offline
post #16955 of 16959 Old 08-22-2017, 08:18 PM
Quoted: 81 Post(s)
Liked: 61
Congrats!
Envoyé de mon iPhone en utilisant Tapatalk
Samsung 64F8500| OPPO 93| Amazon Fire TV
Samsung 51F8500| OPPO 93| WiiU
Samsung 51F8500| Sony BDP-S360| Xbox One
sickkent is online now
post #16956 of 16959 Old 09-17-2017, 02:53 PM
JPowers's Avatar
Liked: 33
I just made a post in the plasma forum the other day about a pink area on white background, to which someone replied that I should adjust VSUS to high. I did this, and it's significantly better. However, I'm a bit confused about some selections under VSUS in the service menu and I want to make sure I did it 100% correctly.
After getting into the VSUS menu, I select "OK" to test VSUS, and then I'm given the option to switch back and forth between "high" and "low." After selecting "high," I see there's is another option "3,4 TEST/CONF SELECT." When I hit 3, it looks absolutely perfect, but when I hit 4, I can still see a bit of pink. So, I just hit 3, then select "OK" to write and then powered down the TV. However, when I go back into the VSUS menu, although it's still on "high," it looks the same way it did when selecting 4, instead of 3. Could someone please explain this to me? Thank you.
Also, while I was in there, I went into the menu to see how many hours I have on the TV, but I wasn't able to return to the previous menu without powering down the TV. The return or exit key didn't work and I didn't want to hit random buttons and screw something up. What is the proper way to return to the previous menu?
JPowers is offline
post #16957 of 16959 Old 09-19-2017, 06:55 AM
Sgooter's Avatar
Quoted: 130 Post(s)
Liked: 103
FWIW, I played with many picture settings over the first 3 weeks, and ultimately settled on THX Cinema. I haven't touched any settings in the past 4 yrs; always looks amazing.
Please enter password to view this signature.
Sgooter is offline
post #16958 of 16959 Old 09-19-2017, 08:20 AM
Scott Oakley's Avatar
Quoted: 81 Post(s)
Liked: 95
Cool
Congrats!
My advice after scouring calibration settings is that you'll find as many different combinations of settings as there are people on here; just go thru and configure what looks best TO YOU.
Good luck, Scott
Panasonic 2013 55VT60
Marantz SR-5012 AVR
B&W 805 Speakers
Velodyne 10" Sub
TiVO Premiere
Scott Oakley is offline
post #16959 of 16959 Old 10-03-2017, 02:59 PM
807recordings's Avatar
Quoted: 29 Post(s)
Liked: 69
Sparkles with Black Background or Scenes?
Just a question as I am not sure if I am seeing dither and now just noticing this or something else is showing up.
Basically what is happening is on my VT65 with menus like Netflix user profile the black background now is getting little white sparkles on some pixels. Seems sort of random. I also notice it in some movie sections where it gets black.
Now I am not 100% sure if it is just I am sitting closer than before and noticing this or really this is some issue that is coming forward?
Hopefully the description helps.
807recordings is offline
Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Panasonic , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv
