F8500 Recommended Settings Thread..... - Page 106 - AVS Forum
post #3151 of 3160 Old Yesterday, 02:26 PM
Quoted: 65 Post(s)
Liked: 6
Began calibrating in earnest last night, focusing on grayscale and gamma; posted results are from the 10th iteration.
Does anyone pay attention to the color temperature graph when taking basic measurements?
I used the AVS HD 709 ColorHCFR 10% Grayscale, next time I'll measure 21 points. Is there a better pattern for grayscale?
80% 2 point seemed to have a low dE with continuous measuring, but this didn't carry over to the 11 point measurement. Comments are appreciated.
ID:	389033   Click image for larger version
ID:	389041   Click image for larger version
ID:	389049   Click image for larger version
ID:	389057   Click image for larger version
bmcn is offline
post #3152 of 3160 Old Yesterday, 03:55 PM
fierce_gt's Avatar
Quoted: 857 Post(s)
Liked: 940
Originally Posted by HX_Guy View Post
Haha, what can I say, I like a bright picture. This is going to be my "everyday" mode, I don't typically go in and change from one to another...just set and forget, except for football games which I like even brighter and I set that up as Standard which gives me around 202 cd/m2.
EDIT: I will probably setup MOVIE mode as a night viewing mode since it's available. What is the recommended cd/m2 value for dark room movie viewing?
I'd say 30-35ftl, so maybe you should aim for 40
really though, the only reason to go darker is if it causes eye strain. I've never really had this issue before, but the f8500 is a bit different. I find anything over 32ish is a problem for me. though 37-40 looks really good, it's only doable for 30mins or so before I start getting headaches
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1018AH, 5.1 audio
Sources: HTPC(Mediabrowser), PS3, XBOX360, Wii, Sony DVP-CX995V
Control: Harmony One
fierce_gt is offline
post #3153 of 3160 Old Yesterday, 04:42 PM
rickardl's Avatar
Quoted: 37 Post(s)
Liked: 44
Originally Posted by zoyd View Post
Mine is set there but I have no idea if it would carry over to another 8500.
Ok, your CMS/Color settings worked quite well, especially the lower saturations for red, when I tried them but the greyscale was more off.
rickardl is offline
post #3154 of 3160 Old Yesterday, 05:25 PM
AMartin56's Avatar
Quoted: 136 Post(s)
Liked: 36
Good to hear that you're enjoying the TV HX!
AMartin56 is online now
post #3155 of 3160 Old Today, 12:24 AM
HX_Guy's Avatar
Quoted: 146 Post(s)
Liked: 33
Yes sir!
One of the huge differences I didn't realize before was how much deeper black the panel gets after the calibration and how crazy the contrast is now. Adjusted (with a disk) Standard mode got down to 0.014 ftL brightness and had a contrast ratio of 5879:1. Movie mode was better at 0.007 ftL and 7035:1.
Calibrated picture comes in at 0.003 ftL and 15482:1
HX_Guy is online now
post #3156 of 3160 Old Today, 12:27 AM
HX_Guy's Avatar
Quoted: 146 Post(s)
Liked: 33
Meh. I tried a cell light of 10 (didn't measure, but it was quite a bit dimmer) and didn't like it. Guess I'll use Mobie to try some different gamma settings and see how it compares to what I dialed in on CAL-N.
post #3157 of 3160 Old Today, 12:38 AM
fierce_gt's Avatar
Quoted: 857 Post(s)
Liked: 940
I got low 30's with cell light at 15. I'm sure 10 is much lower than that even
post #3158 of 3160 Old Today, 07:32 AM
Liked: 0
I just picked up a 60F8500 last weekend and I am hoping one of you guys can help me with a calibration question, there is clearly a wealth of knowledge here but I am a novice and feel a bit out of my league...
I don't care so much about a reference quality picture but I used the settings Kevin Miller's Movie calibration as a starting point.
Picture Mode: Movie
Color Temp: Warm 2
Gamma: 0
Backlight: 16
Brightness: 47
Contrast: 95
Color: 50
Tint: G50/R50
Sharpness: 0
With these settings I find that (at least to me) white/light colors seems a bit blown out and overpowering and that my blacks are too black and I am losing a lot of detail. I have tried to tweak it from here but I am not sure which setting(s) to adjust and in which order, I am having trouble understanding how the Cell brightness, Contrast, Brightness and Gamma interact as I try to correct the issue.
Can someone give me an idea of the order I should adjust these settings and to what degree?
Thank you.
Chris N. is online now
post #3159 of 3160 Old Today, 07:33 AM
HX_Guy's Avatar
Quoted: 146 Post(s)
Liked: 33
I tried 10 because anything higher there wasn't that much of a difference. I mean at 20 I'm at 49 ftL, so only 9 above what you were recommending. Is 9 considered a lot?
post #3160 of 3160 Old Today, 07:35 AM
HX_Guy's Avatar
Quoted: 146 Post(s)
Liked: 33
Picture Mode: Movie
Color Temp: Warm 2
Gamma: 0
Backlight: 16
Brightness: 47
Contrast: 95
Color: 50
Tint: G50/R50
Sharpness: 0
Thank you.
These look pretty ok and I'm surprised whites are blown out and blacks are too dark. Maybe try 49 for the brightness, that's what I have it at.
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
