F8500 Recommended Settings Thread..... - Page 136 - AVS Forum | Home Theater Discussions And Reviews
 334Likes
post #4051 of 4391 Old 02-20-2015, 11:15 PM
Quoted: 1482 Post(s)
Liked: 609
Is 1206 the last one? I thought I read that the latest one is 1206.1 yet when I try to update, the display returns that I have the latest software?
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is online now
post #4052 of 4391 Old 02-21-2015, 12:23 AM
asere's Avatar
Quoted: 1424 Post(s)
Liked: 281
Originally Posted by wxman View Post
Originally Posted by asere View Post
My 8500 currently has the firmware 1204 and it's asking to update to 1206. Should I update or will I loose black levels in doing so?
You won't lose black levels. You won't lose anything. All it does is update the smart hub. The updates have been basically useless since the early updates in 2013. If you don't use smarthub, then don't bother.
Thank you
asere is online now
post #4053 of 4391 Old 02-21-2015, 12:25 AM
asere's Avatar
Liked: 281
Yes 1206 should be the latest that is what the firmware asked for.
asere is online now
post #4054 of 4391 Old 02-21-2015, 11:06 AM
WantsNWarrants's Avatar
Quoted: 84 Post(s)
Liked: 50
Originally Posted by William Kaufman View Post
Just curious--is Pie a professional electrical engineer and/or tv calibrator (same question for Glenee).
Also, I assume that after making these adjustments, if you press picture reset, everything reverts to the factory presets?
Both are DIYers who bought meters and calibrated with help from this thread. Pie's settings benefitted several; dunno about Glenee's settings except that he was pleased with the results.
Yes, selecting RESET puts that mode back to factory. But if you're using Standard, why would you reset Movie (or CalDay\Night)?
WantsNWarrants is offline
post #4055 of 4391 Old 02-22-2015, 08:34 AM
WPWoodJr's Avatar
Quoted: 97 Post(s)
Originally Posted by WPWoodJr View Post
I've hesitated to post this because I keep thinking that I've done something stupid to cause it. But I've checked and re-checked and I've definitely got an issue. The red in my white balance is decreasing over time. I've checked it with an iD3 and a ColorMunki Spectro.
Has anyone else had this issue where red decreases significantly?
Samsung PN60F8500, TiVo Roamio, ASRock Vision 3D HTPC, Chromecast
WPWoodJr is offline
post #4056 of 4391 Old 02-22-2015, 09:46 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Can you tell visually that you're losing "reds", or is this disparity showing up only in the software?
DanF8500 is offline
post #4057 of 4391 Old 02-22-2015, 10:17 AM
WPWoodJr's Avatar
Quoted: 97 Post(s)
Hard to say. I have no reference since its happening on all inputs.
WPWoodJr is offline
post #4058 of 4391 Old 02-22-2015, 10:25 AM
wxman's Avatar
Quoted: 3773 Post(s)
Liked: 2691
From what i have read, the red decays faster that the other colors over time. I do recall from the old Pioneer threads, that red would decay the quickest during initial break in period and then only decay slightly faster than the rest of the colors thereafter.
wxman is online now
post #4059 of 4391 Old 02-22-2015, 10:28 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
The first delta looks like you forgot to apply the plasma edr correction on the 2nd measurement. The 2nd delta could be repeatability, (warm-up, or slightly different offset corrections, or meter placement, ambient light pollution...). Occasionally my video card will also get into a funky state where it's got some default gains loaded so I make sure to clear it prior to calibration runs. Once you have a stable set-up you should see very little display drift over that sort of time period.
zoyd is offline
post #4060 of 4391 Old 02-22-2015, 10:29 AM
WPWoodJr's Avatar
Quoted: 97 Post(s)
I have over 600 hours on it now. How long is break in?
WPWoodJr is offline
post #4061 of 4391 Old 02-22-2015, 10:31 AM
WPWoodJr's Avatar
Quoted: 97 Post(s)
It does appear that the one input that I have left alone since this started happening is paler on skin tones than the one I have been bumping the red on. I think this is real since I am seeing it on two sensors.
WPWoodJr is offline
post #4062 of 4391 Old 02-22-2015, 11:08 AM
wxman's Avatar
Liked: 2691
Normally a good break in time is about 300 hours before first calibration. A re calibration should be done every 2 years, due to the faster decaying red color. With the Pioneer, the red decayed the fastest during the first 1000 hours. I have also noticed skin tones a little more pale, and I have over 2500 hours. You can bump up skin tone to +1 to see if that helps.
wxman is online now
post #4063 of 4391 Old 02-22-2015, 12:28 PM
WPWoodJr's Avatar
Quoted: 97 Post(s)
Actually I found one mistake... Resetting my Standard mode settings also cleared my CMS settings in Movie mode.
WPWoodJr is offline
post #4064 of 4391 Old 02-22-2015, 12:42 PM
WPWoodJr's Avatar
Quoted: 97 Post(s)
But the red is still down in WB.
WPWoodJr is offline
post #4065 of 4391 Old 02-22-2015, 12:49 PM
Liked: 609
Display a split grayscale. Does it look cyanish(blue green)?
JimP is online now
post #4066 of 4391 Old 02-22-2015, 01:55 PM
mhraracing's Avatar
I have a fairly basic question....I just picked up a 64f8500 new and am using settings that were posted earlier - but I bought the Disney WOW Bluray - can I use it in my PS3 for settings or should I buy a dedicated Bluray player ?
mhraracing is offline
post #4067 of 4391 Old 02-22-2015, 02:55 PM
WPWoodJr's Avatar
Quoted: 97 Post(s)
No, it looks OK...
WPWoodJr is offline
post #4068 of 4391 Old 02-22-2015, 06:27 PM
Ausnew's Avatar
Liked: 0
I bought this TV last November, and I am very happy with the picture but...
I am using the Plex app on Samsung TV Smart Hub to play stuff from my NAS. If I have the lights off at night and play a movie with black bars I get the ghosting or flickering of content into the bottom black bar
Doing a quick search on the forum I know this may be similar to previous discussions on the Black Optimizer setting, but when I try to turn this off, the option is greyed out and set to Auto.
Only when I come out of Smart Hub can I change the setting - It's so frustrating
Any ideas on how to solve this so I can actually watch movies at night ?
If I enabled the additional modes of CAL-NIGHT, CAL-DAY, would the black optimizer setting be set to off or auto ?
Ausnew is offline
post #4069 of 4391 Old 02-23-2015, 10:05 AM
Quoted: 84 Post(s)
Liked: 50
Yes, the PS3 does an excellent job with any BD.
I should probably remain silent here, but as I remember it, the BASIC method using WOW is good, while the "full boogie" method is oversaturated.
Perhaps s/o else will chime in.
post #4070 of 4391 Old 02-23-2015, 10:09 AM
wxman's Avatar
Liked: 2691
Unfortunately, when using apps via the smart hub, BO will always be set to Auto and can not be changed.
wxman is online now
post #4071 of 4391 Old 02-23-2015, 10:28 AM
WPWoodJr's Avatar
Quoted: 97 Post(s)
This is getting ridiculous. Yesterday afternoon I, yet again, re-calibrated to address low red in white balance. It had drifted off by 2% or so. After watching the Oscars, it had drifted low again!
Over the last week I have had to raise the red WB gain control on HDMI3 from 33 to 40 to address this issue. I haven't had to change the CMS red setting at all which is odd.
The only thing that has changed since this started happening that I can think of, is that I have been using an HDMI splitter between the PC and the TV so I could split the TiVo output to HDMI1 and HDMI3 on the TV. While removing the splitter doesn't help the red level, I'm wondering if somehow just using it has affected the reds (HDMI1 also has the issue - not sure about HDM12 and HDMI4)? Hard to see how, if bits is truly bits, but I'm at my wit's end!
WPWoodJr is offline
post #4072 of 4391 Old 02-23-2015, 12:36 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
This is getting ridiculous. ... Hard to see how, if bits is truly bits, but I'm at my wit's end!
Just wondering if you saw Zoyd's comment to you above. Didn't know if you read his reply.
DanF8500 is offline
post #4073 of 4391 Old 02-23-2015, 05:39 PM
mhraracing's Avatar
Ok - thanks - I will try the basic method this weekend.....if I don't like them - I will go back to the settings in this string....
post #4074 of 4391 Old 02-26-2015, 11:41 AM
molfious's Avatar
Quoted: 33 Post(s)
Hi there, I have a PN60F8500 and had an issue while trying to reload my calibration settings. It ended up causing some default WB settings in the service menu to be reset and a factory reset is not fixing the issue. I was wonderig if anyone would be willing to help me by sending me pictures of the default service menu settings through a private message. To me it looks like only the ADC/WB settings were effected. The red, green and blue offset and gains have all been reset to 128 and I require the default values.
molfious is offline
post #4075 of 4391 Old 02-26-2015, 05:40 PM
WPWoodJr's Avatar
Quoted: 97 Post(s)
Yes I checked his suggestions but no joy. I've been running without checking the calibration for a few days (enjoying my TV). Will check reds again this weekend.
WPWoodJr is offline
post #4076 of 4391 Old 02-27-2015, 03:54 PM
molfious's Avatar
Quoted: 33 Post(s)
Is anyone able the default values for Red, Green and Blue offset and gain from the ADC/WB section of the service menu for the North American PN60F8500?
molfious is offline
post #4077 of 4391 Old 03-04-2015, 06:38 AM
Quoted: 25 Post(s)
Liked: 3
I had my set calibrated for both Cal-Night and Cal-Day picture modes, and since these are activated Black Optimizer is greyed out at off when using SmartHub apps. I read that the Cal and Movie modes calibrate the same, and I never use my Cal-Day mode, so could I disable the Cal picture modes and just apply my Cal-Night settings to the Movie mode? Then I would get Black Optimizer to default to Auto with Smarthub apps? How do I disable the Cal modes in the service menu?
ebefspz is offline
post #4078 of 4391 Old 03-04-2015, 10:44 AM
Quoted: 84 Post(s)
Liked: 50
The issue is with the apps, not your Cal modes. Cal modes are just 2 additional "buckets" for saving settings. You undo them in the service menu, which you should avoid like the plague.
post #4079 of 4391 Old 03-04-2015, 06:32 PM
charles dodgen's Avatar
If your F8500 acts like mine, the black optimizer will stay greyed out to off even after you disable cal-day/night. You need to just do a reset from the normal menu, then the black optimizer should go back to auto for the apps.
Make sure to copy your settings first. The tv returns to the default settings after reset.
charles dodgen is online now
post #4080 of 4391 Old 03-10-2015, 01:02 PM
Quoted: 25 Post(s)
Liked: 3
I once reset the picture settings while in Cal-Night by mistake, and had to re-enter them all again (glad I had my calibration report). When that happened I didn't notice anything different except that my settings were gone. I've searched throughout the user menu for a higher level (more general) reset, but no dice...which is why I was thinking that I might have to do something in the service menu to 'reset' my set.
ebefspz is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
