F8500 Recommended Settings Thread..... - Page 138 - AVS | Home Theater Discussions And Reviews
post #4111 of 4133 Old 03-27-2015, 04:50 PM
Trentaferd's Avatar
I just got my brand new 51" last night and I'm super impressed with it. Definitely the best tv I've ever owned, or even seen personally. I'm using the pieandchips settings now, which look outstanding, but I will probably try a few more and pick favorites.
Has anyone had any trouble accessing the cal day and night options from the service menu? I use my tv for movies and gaming in relatively bright and dim settings, so it would be extremely helpful for me to have a couple more calibrations saved on my tv. But if I bricked my tv, it would take me a long time to recover emotionally from such a blow. I've seen the instructions kindly posted by wxman earlier in the thread, but I'm wondering if even by following those instructions carefully I could still slip and mess something up permanently.
Trentaferd is offline
post #4112 of 4133 Old 03-27-2015, 05:05 PM
wxman's Avatar
Quoted: 359 Post(s)
Liked: 331
I reset my tv after every FW update. So I have to reactivate day/night cal every time. I never had a problem when following the instructions. Just do it slowly and you will be fine.
wxman is online now
post #4113 of 4133 Old 03-29-2015, 04:36 PM
Trentaferd's Avatar
Is the only difference between, say, movie mode and standard the ability to do the 10 pt calibration? It seems to my eye that when I've got the same numbers plugged in on both modes, with 10 pt set to auto on movie, that the picture is not identical between them, with standard being noticeably brighter. Perhaps I don't fully understand how 10 pt works, or there is something intangible to me that is operating to cause the pictures to be different.
post #4114 of 4133 Old 03-29-2015, 04:56 PM
DanF8500's Avatar
Quoted: 434 Post(s)
Liked: 241
^ Standard Mode is brighter than Movie Mode. It's not an optical illusion.
DanF8500 is online now
post #4115 of 4133 Old 03-29-2015, 08:01 PM
Trentaferd's Avatar
That's interesting. Do the other two modes, relaxed and, I forget what the other one is, have unique quirks as well? How do Cal day and Cal night compare to the other modes?
post #4116 of 4133 Old 03-29-2015, 09:33 PM
wxman's Avatar
Quoted: 359 Post(s)
Liked: 331
Cal Day and night are basically 2 more Movie modes. So in reality you get 3 movie modes which you can take your originally calibrated movie mode, plug into day and night and adjust cell brightness for each. Movie/Day/Night are the most accurate OOTB and closest to D65.
wxman is online now
post #4117 of 4133 Old 03-29-2015, 09:35 PM
wxman's Avatar
Quoted: 359 Post(s)
Liked: 331
Movie mode is the closest to D65 OOTB. Standard runs much cooler. White looks more blue and skin tones more pink on Standard mode vs Movie.
wxman is online now
post #4118 of 4133 Old 03-30-2015, 01:39 PM
Trentaferd's Avatar
Thanks again for the help, everyone. I feel a bit clueless with all of the questions I'm asking, but I do have one more if you'd indulge me. I've been looking online for the past hour or so and I can't find any recommended values for the 3d sub-menu, such as 3D Perspective and Depth. Is it just a matter of personal preference? Not sure what the L/R change means either.
post #4119 of 4133 Old 03-31-2015, 12:58 PM
abouttreefitty's Avatar
Liked: 3
I could be wrong, but I'm pretty sure those settings are only used when you are converting a 2D source to 3D. If you're watching a 3D blu ray or a 3D title on Netflix, those settings do nothing.
abouttreefitty is online now
post #4120 of 4133 Old 04-02-2015, 04:00 PM
alettiere's Avatar
Quoted: 50 Post(s)
For those of you who are/have calibrated your sets with a meter and are not just plugging in random settings, what have you found is the best gamma to target for dim viewing on my iDisplay Pro with Calman? I target 32ftL as my max output. Always have. But haven't quite figured out what would be an ideal gamma setting for my environment. It seems that a lot of people are just leaving their Gamma at 0, which I think translates to somewhere in the flat 2.3 range if I'm not mistaken? Without individual 10-point gamma controls, I'm sure I'd go insane trying to get a BT1886 curve.
Coming from my Panasonics, where most people end up with somewhere in the 2.20-2.25 range regardless, I was wondering what gamma target you think looks best on the 8500 in a dim viewing environment? And I guess while I'm at it, what about CMS? Are you guys mostly doing a traditional 100/75 or a 75/75 adjustment?
alettiere is offline
post #4121 of 4133 Old 04-02-2015, 07:52 PM
fierce_gt's Avatar
Quoted: 1242 Post(s)
Liked: 1245
BT1886 really isn't anymore difficult to do than a 'flat' curve. you make adjustments exactly the same way, so it's really the same difficulty imo. i'm not sure why you'd do either without using the 10pt controls though...
for CMS, it seems like you're better off looking at 75% saturations, and then do minor tweaks when you run the full sweep, if necessary.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1018AH, 5.1 audio
Sources: HTPC(Mediabrowser), PS3, XBOX360, Wii, Sony DVP-CX995V
Control: Harmony One
fierce_gt is offline
post #4122 of 4133 Old 04-03-2015, 06:22 AM
chunon's Avatar
Quoted: 414 Post(s)
Liked: 598
I'm making the same transition myself, I was always a fan of a modified 2.1 to 2.3 gamma for night viewing on my Vt60 will be trying the same thing on the 8500.
chunon is offline
post #4123 of 4133 Old 04-03-2015, 07:42 AM
AMartin56's Avatar
Quoted: 352 Post(s)
Liked: 126
I use HCFR rather than Calman and since it exposes more of the raw numbers to you it's more likely to drive you a bit crazy when trying to reach gamma targets. Having said that I ended up leaving Gamma at 0 because it seemed like the numbers lined up better through the grayscale. When I adjusted it to -1 I had to fight things a little bit more in ten point. In any case I've learned not to aim for the perfect chart and try to follow a less is more approach.
And I agree with those that say BT.1886 is pretty easy to do. You just end up throwing more gang adjustments into the lower ranges...no big deal. However I did find 'default BT.1886' to look a bit washed out since it evened out at around 2.2 gamma so I adjusted the calculation to get a similar curve out of black but even off around 2.3.
Living room: Sony 60NX720, Yamaha RX-V673, NHT Super One/Zero w/Ten Sub, Panasonic BDT230.
Current Man Cave: Samsung PN51F8500, Vizio S4251w-B4, Sony BDP-S5100, Darbee Darblet.
Future Man Cave: Sony VPL-HW40ES, Monoprice 106" Multi-Format Fixed Frame (Never again!).
Displays calibrated with HCFR, i1DisplayPro, and Colormunki Photo.
AMartin56 is online now
post #4124 of 4133 Old 04-03-2015, 09:24 AM
alettiere's Avatar
Quoted: 50 Post(s)
How do you think a flat 2.4 looks? I am trying to figure out what a good target is to start with. What are the pros using? I know that 2.4 on my VT only looks good on newer reference content. Anything older is unwatchable.
The reason why I would think it wouldbe harder is because there isn't a 10 point gamma control like the Panasonics have. Panasonics have the three RGB adjustments at each 10 point and one for each gamma point. How do you adjust it on the Samsungs? I thought there is just a single gamma control. Not multiple.
post #4125 of 4133 Old 04-03-2015, 09:38 AM
AMartin56's Avatar
Quoted: 352 Post(s)
Liked: 126
IMO 2. 4 looked fine in a dark room but I wanted to be able to turn the lights on occasionally without changing the settings so I brightened it up a bit. After a while it is just splitting hairs.
On the Samsung you raise or lower all three equally in ten point to make gamma adjustments. Some people call that a 'gang' adjustment. Pretty much does the same thing as ten point gamma controls on the Panny.
post #4126 of 4133 Old 04-03-2015, 10:01 AM
alettiere's Avatar
Quoted: 50 Post(s)
I understand now. Makes sense.
So what gamma is usually easiest to hit a 2.4? 0, -1, -2? I'm just trying to get a good baseline of where to start after I am done with break in.
post #4127 of 4133 Old 04-03-2015, 11:15 AM
chunon's Avatar
Quoted: 414 Post(s)
Liked: 598
-1 is closer to 2.4, pretty easy to verify for yourself
chunon is offline
post #4128 of 4133 Old 04-07-2015, 10:04 AM
AMartin56's Avatar
Quoted: 352 Post(s)
Liked: 126
Well I've come full circle and Cinema Smooth is back to On.
It's harder to calibrate and I see flicker from time to time in content (it is VERY apparent in 25% APL grayscale test patterns but not as bad with moving images) but it seems to be the best compromise for ME when watching 1080p/24 Blu-rays.
Motion Judder Canceller set to Standard provides pretty incredible motion resolution with 1080p/24 (The level of visible detail really IS amazing) but it's way too smooth most of the time.
Running at 60hz is too blurry for me due to the pulldown. And most of the motion resolution goes down the toilet. I really wish Samsung did this better. My old ST60 looked great in 60hz with their motion smoothing set to low but the F8500 can't hang in its available 60hz modes.
Cinema Smooth On seems to be about in the middle in all respects. Smooth but not too smooth with decent detail. Only downside other than the flicker is some oddness that looks like frame skipping from time to time.
So I guess I'll be living with some occasional flicker....at least until I change my mind again or go to recalibrate and get irritated with how jumpy the readings are.
muffinmcfluffin likes this.
post #4129 of 4133 Old 04-07-2015, 12:03 PM
chunon's Avatar
Quoted: 414 Post(s)
Liked: 598
You just like to calibrate
AMartin56 likes this.
64F8500
55ST60
Harmony 650
Sony XT1 Soundbase
OPPO 103d
Calman Enthusiast/I1Pro/I1D3
chunon is offline
post #4130 of 4133 Old 04-08-2015, 04:24 PM
zoyd's Avatar
Quoted: 717 Post(s)
Liked: 595
Originally Posted by WPWoodJr View Post
Every week I measure white balance and it goes down by 2-3% in red. So I bump up the red gain and the next week it happens again.
Is this continuing for you? I have also measured a small decrease in red luminance over the last couple of weeks, panel is at ~1100 hours.
zoyd is offline
post #4131 of 4133 Old 04-08-2015, 05:20 PM
WPWoodJr's Avatar
Quoted: 97 Post(s)
I haven't looked since posting. I will look this weekend. I have a theory that there is a limiter in the circuitry that is decreasing red when the brightness is too high. I run at 174cdm2. So I will try and decrease blue and green instead of bumping red and maybe that will work although with slightly less brightness.
Samsung PN60F8500, TiVo Roamio, ASRock Vision 3D HTPC, Chromecast
WPWoodJr is offline
post #4132 of 4133 Old Today, 05:30 PM
AVS Club Gold
Glenee's Avatar
Quoted: 59 Post(s)
Liked: 74
I don't reset my tv everytime after a firmware update. Is there something I am missing here ? I only do this when I have problems after a Firmware update, which was once since ownership.
Glen
Nothing's Perfect So Stop Expecting It ! Glenee
Glenee is offline
post #4133 of 4133 Old Today, 10:47 PM
wxman's Avatar
Quoted: 359 Post(s)
Liked: 331
Glen
I do it because I'm a bit OC with FW updates. No need to do it at all if you have no issues. I just like a fresh start after each update. However, I have stopped doing the updates since I don't use Smarthub, and that's basically all these FW updates do anymore.
wxman is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
