F8500 Recommended Settings Thread..... - Page 139 - AVS Forum | Home Theater Discussions And Reviews
 328Likes
post #4141 of 4364 Old 04-30-2015, 10:01 AM
solomon1's Avatar
Shadow detail and brightness issues
Hi all, i'm having an issue with shadow detail on my 51" samsung 8500. Long story short, overall my picture looks great: deep dark blacks, great contrast, bright picture. This is in comparison to my panasonic st-60. But i'm getting relatively poor shadow detail, much worse than my st-60, even in a dark room at night (though tv filter is so good it doesn't make an enormous difference). Where there should be detail, there is only blackness. So far I have only watched netflix and amazon prime via the tv's built-in apps, so i am somewhat limited in the picture adjustments i can make (though I think black optimizer is the only important setting grayed out). Also, i have probably only had the tv on for a total of 100 or so hours total. Finally, initially i was watching the tv with a panel light setting of 13 or 14, but i found it to be so bright that it was hurting my eyes over extended viewing, so i have it at a panel brightness of 3 now! I know that seems rediculously low, but it honestly seems plenty bright to me. Contrast is set to mid to high 90s and brightness is in the 50s. I discovered recently that Standard mode seems to have better shadow detail than movie mode with other settings being equal. I now have the most recent firmware installed (1207 or 1208 i think). So, my questions:
1. What is the best way to increase shadow detail? Brightness, contrast, gamma, or panel light (or a combination)?
2. Should lower panel light output increase or decrease shadow detail? I feel like it increases shadow detail but that could be because my other settings aren't right.
3. Will further panel burn in help my situation?
4. Is there something wrong with my eyes or my tv that i have it set to panel light setting of 3? At this setting i feel that it is roughly as bright as my panasonic st-60 (which is a great, modern plasma tv).
5. Would resetting my settings help?
6. Is it possible this problem is exclusive to the netflix and amazon prime apps? Or possibly a consequence of not watching content through an hdmi port?
Thanks in advance everyone!
solomon1 is offline
post #4142 of 4364 Old 04-30-2015, 12:15 PM
wxman's Avatar
Quoted: 3518 Post(s)
Liked: 2540
I think a professional calibration would help greatly. Otherwise, use movie mode, warm1 instead of warm 2. Lower brightness to around 45. I know you don't like a higher cell light, but with movie mode you should be able to raise it to 13 or 14 and it will look better. I tried a low cell light under 10, and detail is lost. Standard is very bright compared to movie mode. Movie mode is much closer to 65K out of the box, compared to Standard, which is way too cool. Plus gamma in Movie mode is better than Standard model. Choose a gamma of zero or +1.
wxman is offline
post #4143 of 4364 Old 04-30-2015, 12:55 PM
chupra's Avatar
Quoted: 16 Post(s)
I would think that your source material has a lot to do with your dissatisfaction. Try Blu Ray or at least HD cable or satellite.
chupra is offline
post #4144 of 4364 Old 04-30-2015, 05:13 PM
wxman's Avatar
Liked: 2540
Netflix via the tv app should not look like it lacks detail. If you are getting HD from Netflix it should look as good satellite or cable tv HD.
wxman is offline
post #4145 of 4364 Old 05-01-2015, 05:41 AM
Quoted: 215 Post(s)
Liked: 38
Cell light of 3 is pretty low. For dark room viewing, the lowest I ever go is around 8. If you feel like you are missing out on shadow detail, try changing your gamma to +1. Make sure you recheck your brightness/contrast setting so they are right/not clipping.
Michael Vincent Praino is offline
post #4146 of 4364 Old 05-01-2015, 06:17 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Make sure you properly set black level and contrast. Raise cell light somewhere around 17, the adjust gamma (0 or + 1 should be what you're looking for)
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #4147 of 4364 Old 06-17-2015, 11:16 AM
asere's Avatar
Quoted: 1373 Post(s)
Liked: 259
asere is offline
post #4148 of 4364 Old 06-23-2015, 08:44 AM
dusty123's Avatar
Did a new firmware update last night to 1208. Anybody know what it was for.
dusty123 is offline
post #4149 of 4364 Old 06-23-2015, 11:59 AM
WantsNWarrants's Avatar
Quoted: 84 Post(s)
Liked: 50
As always, since 1116 (or maybe 1117), app updates only.
WantsNWarrants is offline
post #4150 of 4364 Old 07-09-2015, 10:39 AM
bmcn's Avatar
Quoted: 1538 Post(s)
Liked: 2313
Try 1209; it reduced mll on my 2014 panel from 0.006 fl to 0.0033.
bmcn is online now
post #4151 of 4364 Old 07-09-2015, 11:04 AM
shadowspawn's Avatar
Quoted: 83 Post(s)
Liked: 61
I've got a gorgeous Chad B calibration applied to my 64F8500 (which took him many hours to do).
If 1209 really does reduce mll and improve black level as some people are saying, will I screw up my calibration if I apply the update?
shadowspawn is offline
post #4152 of 4364 Old 07-09-2015, 11:18 AM
bmcn's Avatar
Liked: 2313
My 8500 calibration is a work in progress that's taken 6 months thus far.
This morning I used a grayscale/gamma calibration from earlier in the week as a baseline for today's color cal session. Other than the mll improvement I didn't notice any significant changes. I attribute the inconsistent color dE's in the spreadsheet to my lack of experience and I fine tuned r&b in 10 pt this morning, so the two sessions aren't directly comparable. It's possible 1209 tinkered with the color; ask Chad or Zoyd.
bmcn is online now
post #4153 of 4364 Old 07-09-2015, 12:55 PM
Chad B's Avatar
Quoted: 492 Post(s)
Liked: 1179
I have a feeling if it does it is only tweaking the black optimizer, which would not change the calibration. However, I would welcome any insight Zoyd might have on the matter.
Sent from my SM-G900V using Tapatalk
dsskid, Keenan and bmcn like this.
Chad B is offline
post #4154 of 4364 Old 07-13-2015, 06:41 PM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
for what it's worth, i ran a quick pass(greyscale and color) on my fw 1204, ran the update, and then ran another quick pass. the fw update did not affect anything, i've had less consistent results running back to back sweeps without making any changes...
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #4155 of 4364 Old 07-23-2015, 11:24 AM
SteveWK's Avatar
Quoted: 30 Post(s)
Did you check the MLL?
SteveWK is offline
post #4156 of 4364 Old 07-23-2015, 12:06 PM
SteveWK's Avatar
Quoted: 30 Post(s)
Test Patterns Dimming During Calibration
While using a 25% APL and 10% window to calibrate, I've noticed that the luminance of test patterns 50 IRE and higher will slowly decline with time. For example, I'll measure a peak brightness of 41 ftL at the start of greyscale calibration and then measure 39.x ftL 15 mins later. This same problem also happens with 10% windows. This makes gamma calibration a PITA.
I read on another forum that this can be defeated by setting the picture size to 16:9 and turing on pixel shift, but that doesn't have any effect on my TV. Anybody have the same problem? Solution? All of the eco/energy stuff is off.
Steve
SteveWK is offline
post #4157 of 4364 Old 07-23-2015, 12:17 PM
Quoted: 215 Post(s)
Liked: 38
Steve
I don't have a meter but I have seen similar behavior on my set by eye. For example, with the ansi checkerboard pattern and cell light, I usually can see the first visual change in brightness going from 12->11 but at other times I see the shift going from 13-12, the rest of the settings being the same. I think it has something to do with menu popping up and changing APL but I'm not really sure.
post #4158 of 4364 Old 07-23-2015, 01:43 PM
SteveWK's Avatar
Quoted: 30 Post(s)
What I'm describing has nothing to do with changing the cell light. The screen dims on its own with a static test pattern displayed and you need a meter to measure it.
SteveWK is offline
post #4159 of 4364 Old 07-23-2015, 02:05 PM
fierce_gt's Avatar
Liked: 1570
no change. it actually went up from .009cd/m^2 to .010, but that's normal of my display and sensor. it tends to increase from around .008 to .011 as i run the patterns.
not sure if it matters, but i have done some voltage tweaking on the back panel as well
post #4160 of 4364 Old 07-23-2015, 02:14 PM
SteveWK's Avatar
Quoted: 30 Post(s)
Thanks. I have the voltage mod and measure 0.009 cd/m^2 to 0.01 too. I was hoping 1209 dropped it even further.
SteveWK is offline
post #4161 of 4364 Old 07-23-2015, 08:16 PM
fierce_gt's Avatar
Liked: 1570
i don't claim to know how these panels work, but it would only make sense to me if they could do what we did with the voltage 'pots' digitally. like if those controls were set through the service menu, then i could see how a fw update could MAYBE change them and improve MLL like doing the voltage tweak does.
post #4162 of 4364 Old 07-24-2015, 11:58 AM
Quoted: 215 Post(s)
Liked: 38
Originally Posted by zoyd View Post
I'm skeptical that such a thing exists but I'll have a more critical look at it tonight.
Here are my suggested settings for this display. They will produce something closer to a reference image than any of the presets and will be a good starting point for when y'all buy a meter.
Subdued room lighting
Brightness: adjust using test pattern 1 click below where level 16 shows green dithering, typically 48 or 49.
Contrast: 95
Cell light: set for comfortable long-term viewing (range for cell 12-15 will be approximately 30-35 ftL)
Sharpness: 0
Color: 55
Tint: default
Movie mode: warm 2 or warm 1. (warm 2 is closer to spec but may appear greenish at lower stimulus levels in which case use warm 1 instead)
Gamma: -1 (minimal lighting, bump up to 0 if you lose black detail or if material is not well-suited to this setting)
2 pt. White Balance if using warm 2
r offset 26
g offset 22
b offset 23
r gain 28
g gain 24
b gain 24
Color space: Custom
Red: 38 0 0
Green: 24 47 3
Blue: 0 0 45
Yellow: 47 46 5
Cyan: 27 49 51
Magenta: 41 0 49
10 pt control (leave this off if you want closer to pure power law gamma at 2.4):
Level 1: 4,4,4
Level 2: 2,2,2
Level 3: 1,1,1
others default.
Digital clear view: low is good for SD material and sub-par HD, otherwise off
Picture size: screen fit
Black optimizer: dark room
For 24p input turn cinema smooth on.
all other enhancements off
deltas for moderate room lighting:
Cell = 15-20 (set for comfortable long-term viewing, will be ~35-45 ftL)
Gamma = 0
Color = 53
deltas for bright room:
Cell = 15-20 (set for comfortable long-term viewing, will be ~45-55 ftL)
Gamma = +1
Color = 50
Black optimizer = Bright room or Auto
If you need even more light output then switch to standard mode:
Cell = 15-20 (17 on my display yields 75 ftL)
Contrast = 90 (above 90 standard mode begins clipping)
Gamma = +1
Color = 50
Color space: custom as above
@zoyd , are these recommendations still current (considering firmware upgrades, etc)?
post #4163 of 4364 Old 07-24-2015, 12:30 PM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
I don't have any reason to think otherwise except for the white balance settings which are problematic to begin with. The red output on my display has dropped ~10% since I got it. But general CMS and cell/contrast/gamma levels etc. are the same.
zoyd is offline
post #4164 of 4364 Old 07-25-2015, 03:18 PM
SteveWK's Avatar
Quoted: 30 Post(s)
That seems possible to me too. One thing I have tossed around in my mind is pulling the board out of the TV and adding a second adjustable POT so I could dial the MLL down even lower. I don't have any perceptible miss fires yet and it would be fun to experiment with it.
SteveWK is offline
post #4165 of 4364 Old 07-25-2015, 09:12 PM
fierce_gt's Avatar
Liked: 1570
yeah maybe. i have misfires on mine, but they are either less perceptible than the normal dithering, or only occur under extremely rare situations. if i have like a 98% solid back screen, and the 2% is bright white, i'll see tons of magenta sparkles in the white.
i tried doing the voltage tweaks on my older samsung b530, and i'm pretty sure i didn't get any better. at first i thought i did, but when i fired the tv up cold the next day, tons of issues until it warmed up about 30mins later. i left the back panel off for a couple days so i could keep tweaking if anything came up, and it continually did. sometimes when cold, sometimes when warm, sometimes with high contrast scenes, sometimes with low APL scenes, sometimes with high APL scenes. by the end of it i was just trying to get it back to where it was, haha. the MLL on that tv is super terrible, and after the voltage tweaks it's now just sorta terrible i guess, haha. wasn't worth the effort imo though.
after that experience, i'll probably leave my f8500 as is for as long as it's working fine. doing the voltage tweak on the f8500 was so rewarding, it's probably good i had that other experience to keep me down to earth on my expectations.
post #4166 of 4364 Old 07-29-2015, 05:28 PM
MattAlex151's Avatar
If this is the case then are there any other manual tests I can run to adjust my red (or other colors presumably) on my own w/out a meter, or if I were to get a meter, which would you recommend?
MattAlex151 is offline
post #4167 of 4364 Old 07-29-2015, 05:44 PM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1770
I would recommend the I1d3 aka I1Display Pro and HCFR for software.
bmcn likes this.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #4168 of 4364 Old 08-02-2015, 12:01 PM
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
I have HBO free for a couple months; I've been binging Game of Thrones on HBOGo. Lots of dark scenes, when the screen gets really dark, the detail shows as ghostly grey blobs. One scene where a figure slowly emerges from total darkness was particularly egregious. I ended up lowering brightness to 37, leaving contrast at 97 and cell light at 20, and now the figure emerges smoothly and naturally in that scene. However, moderately dark scenes in general (eg candle-light) get really dark, and detail seems to be lost.
Is this just artifacts from streaming, or are my settings messed up?
ermghoti is offline
post #4169 of 4364 Old 08-02-2015, 12:33 PM
Ph8te's Avatar
Quoted: 4543 Post(s)
Liked: 3972
HBOGO isn't the best quality. GoT deserves to breath. Do yourself a favor and pick up the Blu-Rays
Sent from nowhere
ermghoti likes this.
Ph8te is offline
post #4170 of 4364 Old 08-02-2015, 06:47 PM
Liked: 0
I want your guys take...
I have a display model 64f8500 that I recently purchased from a Magnolia Design Center for 1599.99, it has a tiny bit of burn in and when there is no signal present there is some unevenness in the panels lighting...which is odd for a plasma. Though when a signal is present it is as uniform as can be.
I can sell it and get a buddy of mine's that has no burn in or unevenness...though I am not sure it is even an upgrade at all since my PQ is outstanding. I have yet had a chance to view his set.
Also, there is a guy in my city wanting to get rid of his 65zt60 that is in prestine condition....choices choices.
hxcmike777 is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
