F8500 Recommended Settings Thread..... - Page 146 - AVS Forum | Home Theater Discussions And Reviews
 328Likes
post #4351 of 4364 Old 01-20-2017, 06:44 AM
muffinmcfluffin's Avatar
Quoted: 223 Post(s)
Liked: 130
Originally Posted by PaulF View Post
Is this disc no good for setting up black on this plasma or am I simply doing it wrong?
I raise the brightness bar until I start to see dithering, then go one notch below that. In my case, that level is 48.
I own the 60" panel, though.
Living Room: Samsung PN60F8500 PDP / Anthem MRX 720 / Klipsch RC-62 II / Klipsch RF-82 II (x2) / SVS PC13-Ultra / Sony MDR-7506 Professional / Sony PS3 / DirecTV HR44-500 / DarbeeVision DVP-5000 Darblet / Panamax M5400-PM / miniDSP UMIK‑1 USB
Bedroom: Samsung PN59D7000 PDP / Energy Power Bar Elite Soundbar & SW / Astro A50 / Sony PS4 / DirecTV C41W-500 / DarbeeVision DVP-5000 Darblet / Hauppauge HD PVR 2
Classroom: SMART Board X800 / Yamaha RX-V667 / Insignia NS-B2111 (x2) / SVS SB-2000
muffinmcfluffin is offline
post #4352 of 4364 Old 01-20-2017, 04:32 PM
PaulF's Avatar
Where or what part of the patten are you evaluating for dithering?
I am almost certainly suffering black crush if I set it up using the S&M disc as described above. Right now I'm at 46 but I don't like ultra" bright spots (and lowered CL to 12), otherwise could also see 48 being the right number too. I bumped contrast up to 90 as well.
I have read the detailed description online for the S&M brightness test but it just doesn't line up with the F8500s behavior, at least for me.
PaulF is offline
post #4353 of 4364 Old 01-20-2017, 04:37 PM
Quoted: 223 Post(s)
Liked: 130
I'm sorry, I guess I didn't mention I'm not using the S&M disc. I am however looking for dithering in "pure black" places (black bars on a film, for instance).
I like to think that I have immense shadow detail with my setup. I'll even get that set of people who complain that "my set is too dark" given a Cell Light of 16 and Contrast at 92.
But again, every set is different, especially when you're talking about different screen sizes. I can't say that I know what your disc does.
Any brightness under 43 or so sounds too low, though.
post #4354 of 4364 Old 01-25-2017, 09:20 AM
PaulF's Avatar
Gotcha, thanks. I'm sticking with brightness around 46 for now and will evaluate combinations of CL vs contrast for the most pleasing top end.
PaulF is offline
post #4355 of 4364 Old 01-25-2017, 10:22 AM
asere's Avatar
Quoted: 1373 Post(s)
Liked: 259
You guys watch movies with cinema or standard mode?
Sent from my SM-G900P using Tapatalk
asere is offline
post #4356 of 4364 Old 01-27-2017, 08:55 AM
asere's Avatar
Liked: 259
I am confused with the below information that I copied and pasted here. Does this mean I should turn off the 24fps and leave Film mode OFF and Judder to STANDARD? I thought Film mode should be Auto 1 or 2 and Judder set to OFF.
Please read:
Also on tap in the F8500 is 96Hz processing for handling 24fps material from Blu-ray movie discs, which does not work very well. In fact, the Cinema Smooth feature is what engages the 96Hz processing in the Samsung, conjointly taking away the Judder Corrector feature in the process. The end result unfortunately is the introduction of so much judder that this feature is not useable. With that said, the Samsung F8500 running at 60Hz, still delivers smoother pans like the fly over scene in Chapter 7 of “I am Legend” than the Panasonic VT50 series in its 60Hz setting. The Panasonic’s 96Hz processing scheme appears to first take the signal to 60Hz inserting 2:3 pull-down, and then converting the signal to 96Hz. This process produces an unacceptable amount of judder in the picture and is best left at the 60Hz setting in the Panasonic. The same is true of the Samsung where 96Hz is best left off, but it delivers that same scene much more smoothly with no hint of 2:3 pull-down hitching. I looked at this scene repeatedly, and found the best results with Film Mode set to Off on the Samsung, and the Judder Canceller set to Standard. The Race Car clip in 24p from the Spears & Munsil Blu-ray test disc was also reproduced very smoothly and cleanly.
vavan likes this.
asere is offline
post #4357 of 4364 Old 01-27-2017, 01:42 PM
PaulF's Avatar
I use Cinema Mode and leave it turned on permanently. I have found no problems with judder or similar. More info in my response below.
The settings depend on your sources and how you want to treat them. I have three main sources - Tivo Roamio (which I also use to stream Netflix and Amazon Prime), Oppo blu-ray player and a Chromecast - all connected to the TV via the same HDMI output from my receiver.
On the Tivo, I have only two video output modes enabled - 1080/60p and 24p pass-through which enables 1080/24p output. If the Tivo is tuned to any signal other than 1080/60p, it will upconvert it so the TV always gets 1080/60p. Unless the Tivo receives 1080/24p, in which case it will pass that through (pass-through only, it does not convert anything to 1080/24p but Netflix Super HD is an example). Similarly, on the Oppo, I have it set up to output 1080/60p for DVD and 1080/24p for Blu-ray. The Oppo does support conversion of 60p to 24p but its success is dependent on how well the original DVD disc was authored so I don't use this feature. The Chromecast outputs 1080/60p.
So in my case, the TV is always receiving a progressive signal, so there is no need to deinterlace. In this case, the Film Mode option is greyed out. If instead you output 60i signals to the TV, you will be able to set the Film (deinterlacing) Mode. I believe mode 1 is for movies and mode 2 is more suited to TV programs with text and banners (like news channels), or you could leave it in auto for the TV to pick what it thinks is the best mode based on the content it sees.
I don't use Motion Judder Canceller (frame interpolation, or smoothing) as I don't like the soap-opera effect, so that's kept off.
For 1080/24p content, I have the Cinema Smooth option turned on which upscales to 96p, and I leave it on all the time. If you have MJD enabled, and your TV receives a 24p signal with Cinema Smooth on, it will disable MJD in favor of CS, but when the TV receives a 60i/60p signal again, it will revert to using MJD again (unless you turn it off). Video settings that are specific to a certain video format can only be turned on/off or selected while the TV is receiving the appropriate signal, and they will then be enabled/disabled automatically by the TV depending on the signal it receives.
vavan likes this.
PaulF is offline
post #4358 of 4364 Old 01-30-2017, 08:59 AM
asere's Avatar
Liked: 259
Thank you. Do you mind sharing the settings you use for Movie mode? I tried cell light of 17-20 and contrast like 89 and its too dark. That is why I am using standard for all content now.
asere is offline
post #4359 of 4364 Old 01-30-2017, 02:06 PM
PaulF's Avatar
I am currently at 46 for brightness, 12 for cell light and 89 for contrast in movie mode. This is a little dark and will not appeal to all, especially those coming from LCDs. I feel like my peak brightness is OK but the overall average is just a tad low. I may bump up CL a notch or two (and maybe compensate by offsetting contrast).
I was unlucky enough to suffer a bad panel. It was replaced for free under warranty but it has left me with concerns about driving the panel too hard. They get very hot at higher overall brightness levels.
PaulF is offline
post #4360 of 4364 Old 01-30-2017, 02:49 PM
asere's Avatar
Liked: 259
Cell at 12 wow that's dark lol. I'll have to play with the settings more.
asere is offline
post #4361 of 4364 Old 01-30-2017, 02:59 PM
Quoted: 215 Post(s)
Liked: 38
I have my CL at 10 with contrast at 100 lol
Michael Vincent Praino is online now
post #4362 of 4364 Old 01-30-2017, 03:14 PM
Liked: 6
Here is my 51" babe playing during the day with 12 Cell as well. Youtube video really does not dot do this set justice though. 2:29 for top picture settings
ziocomposite is offline
post #4363 of 4364 Old 02-02-2017, 08:52 PM
bhealy's Avatar
Quoted: 21 Post(s)
I got a question about a video issue I've lately noticed. Primarily during darker scenes there seems to be a 'smearing' effect to the dark ink parts of the screen. It's very hard to describe but, it looks almost fluid in how the darker parts move.
I was watching Blair witch and I really noticed it during the dark night scenes with the camera moving quickly. And last night I noticed it watching Star wars 7.
I don't notice it during light scenes. So I'm thinking maybe it's a black level issue? I use the Oppo 95 for blu-ray playback.
The dark doesnt seem solid, if that makes any sense. It's almost like motion blur but not quite.
Does anyone know what I'm trying to describe? I wish i could describe it better.
I'm wondering if the 103 or 105 oppo would produce better blacks? Not sure what to think right now.
bhealy is offline
post #4364 of 4364 Old Yesterday, 10:21 PM
Quoted: 223 Post(s)
Liked: 130
Make sure MPEG Noise Filter is turned Off (in Picture Options). Your description matches what that looks like when it's enabled.
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
