F8500 Recommended Settings Thread..... - Page 147 - AVS Forum | Home Theater Discussions And Reviews
 352Likes
post #4381 of 4407 Old 03-26-2017, 07:33 AM
Quoted: 224 Post(s)
Liked: 39
Originally Posted by muffinmcfluffin View Post
Well, I tried the update through USB. I figured what the hell, if life is trying to tell me to get a new 4K set, bricking it via firmware would be the way to go.
All told though, the update went smoothly and I reset all of my settings. So it's safe to say this update is for this PDP.
To the naked eye, I see no difference. I always like to pretend that things are sharper and blacks are deeper than before, but that is likely just placebo kicking in. No visual change, for better or worse, that I can see from an immediate look at things. Of course, I should have really looked at some significant shots of a film before and after to make that official judgment. I don't have equipment to measure with, is all.
If I'm lucky, it helped with brightness pops in 3D and with input lag in Game/PC mode. Maybe it did, maybe it didn't. I don't play with apps so I couldn't tell you if they added/removed/changed anything on that front.
And maybe I'm high or something, but I noticed that when you change aspect ratios, you can move the screen in Screen Fit. Could you always do this? I thought this was only an option in Wide Fit. If Screen Fit always allowed this, then just ignore me heh.
MJC still kicks in if you turn off CS, by the way.
So... I think it's a safe update. I just don't know if it's a worthy one. Maybe other guinea pigs can test it now that you know it's okay to do.
How did you get the usb update to work? I have put both the zip and extracted update on two different fat32 formatted usb devices and the tv doesn't see the upgrade on either of them.
Michael Vincent Praino is online now
post #4382 of 4407 Old 03-26-2017, 09:36 AM
muffinmcfluffin's Avatar
Quoted: 248 Post(s)
Liked: 149
I used 7zip to extract the entire folder into a FAT32 USB stick, and inserted it into the bottommost port on the TV. Up popped a menu to search my drive for music, photos, or video.
I exited out of that menu, went to the television's main menu and to Support --> Software Update. When I press "Update Now," an prompt pops up that asks "Do you want to search the connected USB device for update files?"
The other day, when I selected "Yes," it would show me that I was able to update. Now when I try, it says: "No valid update files found., Please check your USB device and try again." This is because my TV is now as updated as possible.
My guess is if you are already on 1215, it won't be able to update for you. My current version says 1215, not 1215.2. I don't know if there is a difference between the two, but like I said, I came from 1209 to this one, so mine was definitely an update at the time. from 1215 to 1215.2 though, I can't guarantee that it will try and do the update.
Hope this helps.
Living Room: Samsung PN60F8500 PDP / Anthem MRX 720 / Klipsch RC-62 II / Klipsch RF-82 II (x2) / SVS PC13-Ultra / Sony MDR-7506 Professional / Sony PS3 / DirecTV HR44-500 / DarbeeVision DVP-5000 Darblet / Panamax M5400-PM / miniDSP UMIK‑1 USB
Bedroom: Samsung PN59D7000 PDP / Energy Power Bar Elite Soundbar & SW / Astro A50 / Sony PS4 / DirecTV C41W-500 / DarbeeVision DVP-5000 Darblet / Hauppauge HD PVR 2
Classroom: SMART Board X800 / Yamaha RX-V667 / Insignia NS-B2111 (x2) / SVS SB-2000
muffinmcfluffin is online now
post #4383 of 4407 Old 03-26-2017, 01:52 PM
9179mhb's Avatar
Quoted: 177 Post(s)
Liked: 120
Another participant ("p5brown?") said he was able to download/install firmware version: 1215.2 from the Internet, but I don't know what prior FW level he was using at the time. My PDP has FW ver. 1215 installed and reports no new updates are available when running the update utility against Samsung's web portal.
From what you're saying it appears for those of us @ ver. 1215 the USB image won't work to update, the PDP's firmware version, to 1215.2 either.
9179mhb is offline
post #4384 of 4407 Old 03-26-2017, 09:08 PM
p5browne's Avatar
Quoted: 3138 Post(s)
Liked: 2452
1212 (or was it 1213?) on the set, then when I checked for FW update, not really expecting to see one, it said there was a new FW update 1215, and down loaded. No USB drive involved. (The URL was only for those looking for it.)
UN65HU9000 with SEK-3500U in UJS9000 Mod Mode. SDR Input at 1080P 60HZ 444. 4K separate HDMI input - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN32EH5300 (On floor and up for sale) / 2 X LG 55LHXs / New addition UN40J5200AF - Wife's
PN64F8500 still up for sale
p5browne is offline
post #4385 of 4407 Old 03-27-2017, 07:05 AM
9179mhb's Avatar
Quoted: 177 Post(s)
Liked: 120
Thanks. The speculation is if already at 1215 then 1215.2 is not available. Not sure why? Either the difference is so small it's not needed or perhaps Samsung's firmware update utility does not compare prior/current versions past the least significant digit to the left of the decimal point.
9179mhb is offline
post #4386 of 4407 Old 03-27-2017, 07:16 AM
p5browne's Avatar
Liked: 2452
I used the whole numbers since I couldn't remember what came after the period. So, 1215.2 is probably what it is. Samsung does not firmware update anything except the next whole number up, or several whole numbers up.
p5browne is offline
post #4387 of 4407 Old 03-30-2017, 05:46 AM
asere's Avatar
Quoted: 1587 Post(s)
Liked: 340
When you use the f8500 stand that comes with it does it just snap into place when you remove the rear plastic tabs or do they need screws?
I've had mine on the wall and might place it now on a tv stand.
Sent from my SM-G900P using Tapatalk
asere is offline
post #4388 of 4407 Old 03-30-2017, 08:12 AM
fierce_gt's Avatar
Quoted: 1772 Post(s)
Liked: 1694
there are screws
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #4389 of 4407 Old 03-30-2017, 08:18 AM
asere's Avatar
Liked: 340
Originally Posted by fierce_gt View Post
there are screws
Are the screws already on or inside the plastic tabs on the tv when you remove it?
asere is offline
post #4390 of 4407 Old 04-23-2017, 11:47 PM
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
Is anyone using MadTPG as pattern generator for calibration of the 64" with good results?
Any recommendations for the settings (window size, background, APL, etc) for MadTPG?
rickardl is offline
post #4391 of 4407 Old 04-24-2017, 09:39 AM
p5browne's Avatar
Liked: 2452
Windows size 18% max. some are using 10% windows.
DO NOT LEAVE patterns of the upper IREs on for any period of time. Best to do a sweep, adjust, then sweep again.
rickardl likes this.
p5browne is offline
post #4392 of 4407 Old 07-31-2017, 07:53 AM
jayraysaiz's Avatar
Quoted: 197 Post(s)
Liked: 54
When calibrating (a little late to the game ha ha) there is a white balance and a 10 point. I am curious if the white balance is for the high end i.e. 100% white. Is this correct?
EDIT:
I totally missed there were gains and offsets in the menu. Gains 2pt high, offsets 2pt low.
LGOLED65B6P/77G7P
Onkyo Tx NR3030;HDBaseT
Klipsch 7.1.4
R-3800-W II Fronts ; R-5502-W II Center
RS-42 II Surrounds ; CDT-3800-C II Heights, R-112SW Sub
jayraysaiz is online now
post #4393 of 4407 Old 08-06-2017, 05:17 PM
p5browne's Avatar
Liked: 2452
EDIT:
Gains - 100% Offsets - 30%
jayraysaiz likes this.
p5browne is offline
post #4394 of 4407 Old 10-01-2017, 11:23 AM
p5browne's Avatar
Liked: 2452
FW # 1217.0 downloadable on the set. Not available on any Samsung website that I was able to find. All still showing 1215.2.
p5browne is offline
post #4395 of 4407 Old 10-03-2017, 07:52 AM
jayraysaiz's Avatar
Quoted: 197 Post(s)
Liked: 54
Did the update say what it is adding/modifying?
LGOLED65B6P/77G7P
Klipsch 7.1.4
post #4396 of 4407 Old 10-03-2017, 08:06 AM
asere's Avatar
Liked: 340
Anyone here using standard mode vs movie mode because movie move is too dark?
Movie move for me is too dark regardless of what setting I've used.
Sent from my SM-G935P using Tapatalk
asere is offline
post #4397 of 4407 Old 10-04-2017, 10:33 AM
fierce_gt's Avatar
Liked: 1694
no, but standard mode can still be calibrated to a good image. I did that with my 'game mode' settings. it will be brighter, but not by as much as you might want. I found most of the extra brightness in standard mode is achieved through boosting blue and incorrect gamma. once you 'calibrate' those things, my brightness was reduced from over 60ftl, to closer to 45ftl(my movie mode topped out around 40ftl, but i reduced it through voltage tweaks to around 32ish, which i find more comfortable)
sickkent likes this.
post #4398 of 4407 Old 10-05-2017, 08:04 AM
p5browne's Avatar
Liked: 2452
From extensive tests I've done - in just about all cases, Movie Mode is the best mode for precise calibrations. Standard, despite the limited calibrations, is not on the mark! Certain things seem to be augmented!
p5browne is offline
post #4399 of 4407 Old 10-06-2017, 10:30 PM
fierce_gt's Avatar
Liked: 1694
no doubt movie mode is more accurate, but i did not find standard mode 'offensive' in any way. i believe i was able to get dE's around 3 and under with all calibrations. i do not recall noticing anything 'artificial' looking like extra processing, but it was also game mode so maybe there's a difference between standard in game mode, and standard not in game mode.
this is actually in 'pc' mode which is even more limited...
certainly not the 'near perfect' results you can get in movie mode, but better than your average tv's 'out of the box' presets
post #4400 of 4407 Old 10-07-2017, 07:37 AM
p5browne's Avatar
Liked: 2452
Why the 10% drop off? Are you meaning .3, which I calibrate to, or 3 which is OK for the average joe, but not AVS Members
Appears many of the CMS markers are outside their respective boxes.
p5browne is offline
post #4401 of 4407 Old 10-07-2017, 01:43 PM
asere's Avatar
Liked: 340
Thx. What cell and contrast are you using for movie mode?
asere is offline
post #4402 of 4407 Old 10-07-2017, 07:03 PM
p5browne's Avatar
Liked: 2452
Only info I have.
It's re the amount of time set needs to be on before calibrating. (4 hours) Plus an earlier note.
Would turn set on and check current settings, but it's been put away until the next 3 to 4 month roll out.
File Type: txt F8500_Feb6_2015_Test.txt (766 Bytes, 3 views)
File Type: txt PN64F8500_May28_2014.txt (459 Bytes, 3 views)
p5browne is offline
post #4403 of 4407 Old 10-07-2017, 07:25 PM
fierce_gt's Avatar
Liked: 1694
have you seen the calibration options in pc mode? haha. you basically have contrast and brightness, there are zero CMS controls. the standard mode outside of 'pc' is much better, but even the results i got in pc mode look pretty darn good. i used this for my gaming mode, but when i forgot to switch it, i didn't always notice right away(kinda depended on the content, and it was usually the fact i had the brightness set a couple notches too high to help me see what was hiding in the shadows while gaming)
i did mean 3, which is what i was told it about the limit of average human perception. if i calibrated my 10pt controls that tight, then ran a 20pt measurement, it's WAY worse average dE's. that was how i tried at first, and it never looked right. when i loosened up, and accepted dE's more around 1-2, i was able to keep the average dE under 1 on a 20pt run
post #4404 of 4407 Old 10-07-2017, 07:52 PM
fierce_gt's Avatar
Liked: 1694
i was learning how to calibrate when i bought the f8500, so i went through a LOT of different settings before i ended up on my current ones. keep in mind, i did some voltage tweaks to lower my MLL, which also lowered peak brightness.
my current cell is 20 and contrast is 95. people who understand samsung tv's a lot more than me, seem to know that reducing cell light actually messes with ABL so you don't want to that, and lowering contrast shifts the 10pt controls making it difficult to calibrate(this i can confirm). before learning this, i had the cell at 12. after learning it, but before the voltage tweaks, i had cell at 20, contrast at 100 and turn eco mode to low(i actually swear this just turned the abl on permanently. i never noticed any abl behaviour when i did this, but since doing the voltage tweak, it's too dark to turn eco on now)
anyway, for kicks and giggles, here are some of the first measurements i got with movie mode(certainly better numbers, and noticeable improvements in practice, but not drastic)
after playing with CMS: red never tracked really well on my set
and i opted to try a 1886 gamma curve. I've stuck with it since, i like it.
i actually have no idea what this is from, but i'm guessing it's from my later efforts since it's a 20pt measurement
Stereodude and asere like this.
post #4405 of 4407 Old 10-10-2017, 09:43 AM
schwock5's Avatar
Certain picture settings carrying over
Not sure if this is because of any recent updates, but i used to have 2 modes calibrated...Movie and Standard. Movie was for 99% of viewing and i calibrated standard just for watching sports because on that i engaged the motion settings for smoothness. I did this because there's no remote control setting or easy way to simply turn on/off the motion settings, but by having 2 modes, you can easily switch between modes.
However, recently I noticed when engaging "standard" and going back to "movie" that it's keeping the motion settings in-tact, and not going to the settings i had on movie mode of "off". anyone else notice this?
schwock5 is offline
post #4406 of 4407 Old 10-17-2017, 06:41 PM
asere's Avatar
Liked: 340
Can someone please tell me what the green stripe that's across the tv at the bottom is?
I only see it on some channels that are non HD.http://cloud.tapatalk.com/s/59e6b153...017_203830.mp4
asere is offline
post #4407 of 4407 Old 10-17-2017, 07:49 PM
fierce_gt's Avatar
Liked: 1694
if this is with 'screen fit', it could be an issue with the provider. there are still some channels that think it's 1998 and include some kind of 'border'. back in the day, crt's overscanned(zoomed in) and stations hid extra info in the borders.
while not the best solution, if you switch to "16:9" it should zoom in enough to hide the stripe.
PS, i didn't download the video or watch it, so if i'm way off, my apologies.
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
