F8500 Recommended Settings Thread..... - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 328Likes
post #541 of 4364 Old 05-29-2013, 05:28 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Originally Posted by zoyd View Post
hmmm...auto is certainly better than native but my TV requires lower luminance in all colors plus a good dollop of red in the green channel. If you look at this post the auto results fall almost exactly between the green (custom) and red (native) curves. I would expect copied custom settings to push the distribution a bit to the left.
For my D7000, there is not enough difference that a novice would notice.
max dE for Auto (not including the inherent green and cyan problem with the D7000 series) is about 5. max dE calibrated (again not including the inherent green and cyan problem with the D7000 series) is about 3.
AUTO
Calibrated
Larry
LarryInRI is offline
post #542 of 4364 Old 05-29-2013, 05:37 PM
pieandchips's Avatar
Liked: 171
your CMS numbers are similar to the D8000 in needing significant red in the green and cyan channels and some desaturation overall. The luminance levels are close to what auto gives you. thanks for taking the time to post your numbers. I am still amazed that not one person did any useful DIY work on the E series on this forum.
biggrin.gif Thank you Zoyd.
I'm sure a calibrated decent meter and a Pro could get way different results, but I have what I have.
pieandchips is offline
post #543 of 4364 Old 05-29-2013, 05:39 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Pie,
About your obsession smile.gif with the tiny peak in your gamma point curve -- the one that I've told you to ignore, zoyd just posted in the calibration thread:
"gamma at 80% and 90% is inherently noisy because you are taking ratios of two small numbers in log/log space, that's why you often see spikes there but they are meaningless."
Said much better than I did.
Larry
post #544 of 4364 Old 05-29-2013, 05:50 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1052
Larry
yes but that's for just 6 colors, most of the benefit is in the interior (flesh tones for example).
zoyd is offline
post #545 of 4364 Old 05-29-2013, 05:53 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
The examples I presented were taken well before the interior calibration sources were available.
Larry
post #546 of 4364 Old 05-29-2013, 05:57 PM
Liked: 171
Zoyd,
While you're here please I'd like your reasoning on why there is a big discrepancy on fL measured with the different sized F8500s. Same window slide. ABL shouldn't be playing a tune?
post #547 of 4364 Old 05-29-2013, 06:10 PM
zoyd's Avatar
Liked: 1052
Could be as simple as power supply limitations, for a given pattern size the larger panel will require more energy. But I'd like to see more statistics on what the actual differences are for various APL levels.
zoyd is offline
post #548 of 4364 Old 05-29-2013, 06:41 PM
Liked: 171
Pie,
Larry
Thanks Larry. The shootout cal had the same peak, so I was wondering why they hadn't addressed it.
post #549 of 4364 Old 05-29-2013, 06:48 PM
Liked: 171
How about cell 20 is still a requisite (dependent on panel size) for the F8500?
I found it impossible to do a cal for 35fL at cell 20 on my 51".
It may be true that the large panel requires 20 cell and a lower contrast to get the most out of it... If so it would be good to have that public knowledge.
post #550 of 4364 Old 05-29-2013, 06:53 PM
zoyd's Avatar
Liked: 1052
Given the nature of the display, dropping cell down to 16-17 appears appropriate. If you can still get ANSI whites above 30 ftL for your Day cal go for it.
zoyd is offline
post #551 of 4364 Old 05-29-2013, 06:58 PM
Liked: 171
I have what I measured as a 45fL calibration with 16 cell, gamma 0 and contrast at 94 (just before clip). Does that sound acceptable for a 51"?
post #552 of 4364 Old 05-29-2013, 07:03 PM
zoyd's Avatar
Liked: 1052
zoyd is offline
post #553 of 4364 Old 05-29-2013, 07:05 PM
Liked: 171
Yeah I mean 'can you get' 45fL from those settings. I'm sure you'd say yes. It doesn't seem to transpose across the F8500 sizes unfortunately.
I appreciate your time thanks so much, and to Larry and Buzz. Great advice from you folks that I really listen to and learn from smile.gif
post #554 of 4364 Old 05-29-2013, 07:09 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Pie,
When you say that you find it "impossible to do a cal for 35fL at cell 20 on my 51".", do you mean because of the 10 point shifting at low contrast setting or do you mean something else?
Larry
post #555 of 4364 Old 05-29-2013, 07:20 PM
Liked: 171
^ I had to put contrast in the 75-80 region, and gamma at -2 or lower to get dim room +/-30-35fL viewing at 20 cell.
It made the picture very unhealthy looking.
post #556 of 4364 Old 05-29-2013, 07:23 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Pie, define "contrast really low" please.
Larry
post #557 of 4364 Old 05-29-2013, 07:24 PM
Liked: 171
I have the 51". This seems to be a large factor and should not be compared to a larger set.
post #558 of 4364 Old 05-29-2013, 07:26 PM
zoyd's Avatar
Liked: 1052
It seems to me that the cell=20 rule is just not appropriate for this panel. If you need a dark room calibration of 30 ftL I think its more important to keep contrast up and if you have to drop cell down to 10 so what? If it still holds that 30 ftL for ANSI pattern I don't see a problem.
zoyd is offline
post #559 of 4364 Old 05-29-2013, 07:28 PM
DavidHir's Avatar
Quoted: 1725 Post(s)
Liked: 1335
So, on this set, ABL probably not an issue with high contrast and lower cell? (vs lower contrast and higher cell).
On my unit, I was keeping contrast around 90 with cell around 13 for dark room most of the time.
DavidHir is offline
post #560 of 4364 Old 05-29-2013, 07:30 PM
Liked: 171
I was just going to ask the same ANSI vs ABL vs panel size question wink.gif
post #561 of 4364 Old 05-29-2013, 07:31 PM
Liked: 171
On a full screen 100% white slide, my TV can do 22fL!! biggrin.gifbiggrin.gifbiggrin.gif
/sorry that made me lol.
post #562 of 4364 Old 05-29-2013, 07:33 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
I agree with zoyd. I calibrated one 8500 and didn't see any reason why it couldn't be done for a max output of about 30 ftL. As he said check the ANSI level.with the checkerboard pattern. Play with combinations of lower Cell and Contrast to find the best.
Larry
post #563 of 4364 Old 05-29-2013, 07:33 PM
zoyd's Avatar
Liked: 1052
zoyd is offline
post #564 of 4364 Old 05-29-2013, 07:35 PM
zoyd's Avatar
Liked: 1052
zoyd is offline
post #565 of 4364 Old 05-29-2013, 07:40 PM
Liked: 171
16, contrast 94, gamma 0. the white looks awful. Very gray.
post #566 of 4364 Old 05-29-2013, 07:40 PM
zoyd's Avatar
Liked: 1052
zoyd is offline
post #567 of 4364 Old 05-29-2013, 07:44 PM
Liked: 171
It was educational and fun for me to throw a full screen 100% white up. Wow, it really has to try and compensate and you end up with gray.
post #568 of 4364 Old 05-29-2013, 07:49 PM
zoyd's Avatar
Liked: 1052
zoyd is offline
post #569 of 4364 Old 05-29-2013, 07:52 PM
Liked: 171
What's ten foot Lamberts between friends?
post #570 of 4364 Old 05-29-2013, 08:12 PM
Liked: 171
^ Again theories abound, but mine is that if the panel has a greater overall brightness than any other PDP, they designed the circuitry, and PSU to cope and therefore it can let more fL out before more of the ABL algorithm has to kick in.
...so they set the bar (or curve) higher. It would make sense if the World viewed it as a brighter set, its not because ABL is cutting its' nards off down in the lower values like older sets. There would be no point, right?
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
