F8500 Recommended Settings Thread..... - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 334Likes
post #631 of 4389 Old 05-30-2013, 06:31 PM
ljmart's Avatar
Liked: 184
^HAH!!
Samsung PN51F8500 ~ Marantz SR5008 ~ Oppo BDP 103D ~ EMP Tek R55TiB LR, R56CiB, R55WiB ~ Sennheiser Momentum ~ Sennheiser 598
ljmart is offline
post #632 of 4389 Old 05-30-2013, 06:47 PM
pieandchips's Avatar
Liked: 171
Originally Posted by zoyd View Post
Given the nature of the display, dropping cell down to 16-17 appears appropriate. If you can still get ANSI whites above 30 ftL for your Day cal go for it.
Zoyd, bringing up one of your posts last night:
Are you referring to the checkerboard 16 ANSI white pattern?
pieandchips is offline
post #633 of 4389 Old 05-30-2013, 07:00 PM
Cupstid's Avatar
Originally Posted by airgas1998 View Post
Cupstid is offline
post #634 of 4389 Old 05-30-2013, 07:00 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
zoyd is offline
post #635 of 4389 Old 05-30-2013, 07:10 PM
Liked: 171
Okay I just grabbed some readings from my 45fL cal:
ANSI 16 (4x4)
All blacks read .01fL (pointless but fun).
Whites read in position order:
2: 40.67
4: 45.09
5: 41.50
7: 43.09
10: 42.37
12: 43.83
13: 43.39
15: 42.92
Is that helpful to you?
post #636 of 4389 Old 05-30-2013, 07:15 PM
zoyd's Avatar
Liked: 1055
zoyd is offline
post #637 of 4389 Old 05-30-2013, 07:17 PM
Liked: 171
It's certainly above 30fL and I think is showing what weird things ABL is doing to certain areas, if only very gently?
Does that show that the ABL works higher up the brightness scale compared to the D and E plasmas?
post #638 of 4389 Old 05-30-2013, 07:26 PM
zoyd's Avatar
Liked: 1055
The 30 ftL comment was meant for your reduced cell, night calibration. Basically if you target 30 ftL using a reduced cell can you still maintain that level in the ANSI pattern, showing that the reduced cell doesn't push you into ABL territory.
I don't know what would cause the non-uniformity, it's interesting.
zoyd is offline
post #639 of 4389 Old 05-30-2013, 07:32 PM
Liked: 171
I'm actually starting to like this 45fL for night time too with a couple of lights on in the den.
Because the TV wants to be bright, I'm letting it a little bit. It seems to show off better smile.gif
I'm trying to work out the benefits of muffling this down to 35fL.
I know that's the 'standard', but again, perhaps this TV will start to change that, and folks will go a little bit higher just because the screen will work a bit better.
/feel free to knock me down and burn my soul for saying this anyone reading.....eek.gif
post #640 of 4389 Old 05-30-2013, 07:33 PM
Liked: 171
...Basically if you target 30 ftL using a reduced cell can you still maintain that level in the ANSI pattern, showing that the reduced cell doesn't push you into ABL territory...
Understood. I shall try again...
post #641 of 4389 Old 05-30-2013, 07:53 PM
Liked: 171
Okay;
Strange stuff happening.
Reduced cell to 13
Everything else untouched.
An APL 100% white reads 36.2fL
The ANSI 16 reads as follows:
2: 37.25
4: 41.44
5: 38.23
7: 39.41
10: 38.68
12: 40.03
13: 39.58
15: 39.24
I think it's to do with the screens' lens 'coatings/prism type whatever' they created to help make it so bright. It seems to reflect light around in a way the meter is picking up.
What do you think is going on?
post #642 of 4389 Old 05-30-2013, 08:16 PM
Make73's Avatar
Originally Posted by pieandchips View Post
^ Motion.
It helps sew everything together and smooth out the picture especially in panning shots, but at the expense of blacks, which seems to be a quirk with it.
It can look too artificial on some material, and work well on other material.
I'd rather keep my blacks thank you very much so it's off unless I'm playing around wink.gif
Did you measure difference with CS and without it?
With D-series it affected but not with E, now with F it worsen mll again?
Make73 is offline
post #643 of 4389 Old 05-30-2013, 08:21 PM
Liked: 171
^ No I have not measured but you can see with the eye that blacks get lighter. I think buzz is going to do some quick CS tests on Saturday with his doozy meter wink.gif
post #644 of 4389 Old 05-30-2013, 08:30 PM
Make73's Avatar
Oh, then it really affect if you can see that by eyes.
Let´s wait some MLL vs. APL with and without CS measurings, interesting to see results.
I assume that also with new Panasonics APL don´t affect to MLL, seems that Samsung do things different in that category.
Make73 is offline
post #645 of 4389 Old 05-30-2013, 08:38 PM
Liked: 171
^ I haven't tested it with the new firmware, it's possible they have fixed it. I won't know until tomorrow when I will test.
post #646 of 4389 Old 05-30-2013, 08:42 PM
Ilovetightbass's Avatar
Ok the election is over. Obama won with a landslide victory. The shootout is over. Samsung won barely. Reading this I'm gonna have to find a support group. Lol. Go buy a plasma or LCD that suits your needs. Let go.
Ilovetightbass is offline
post #647 of 4389 Old 05-30-2013, 08:46 PM
Make73's Avatar
Was that for me?
Discussion about features is not choosing side for Panasonic or Samsung, it´s just discussion and making some discovery.
I suggest taking any Samsung, Panasonic or what ever brand glasses of from head and see things fairly.
Make73 is offline
post #648 of 4389 Old 05-30-2013, 08:51 PM
no. It's for all of us. Samsung rocks and Panasonic is pretty close. Win win situation for all
post #649 of 4389 Old 05-30-2013, 08:54 PM
Make73's Avatar
You can find some interesting discussion from here:
http://forums.hdtvtest.co.uk/index.php?topic=7749.msg33029#msg33029
Make73 is offline
post #650 of 4389 Old 05-30-2013, 09:04 PM
endlessender's Avatar
Originally Posted by ArbalestNL View Post
Just a small question,
What do you guys think of the Motion Judder Cancellation on this set? I have connected my pc, and use it to play movies on the Samsung, but I have some motion judder in some scenes, so I put MJC on the maximum setting.
This makes the image very nice and smooth to my eyes. It almost looks sharper as wel in some cases. Isn't this sort of processing usually bad for picture quality though?
Does anyone else use MJC?
MJC is essential for 3D IMO. It makes it much more realistic and fluid/easy to watch. Anything animated I like MJC and I also use it for reality type TV shows like Survivor. Not crazy about it on network sitcoms and some movies from DirecTV. I mostly use Standard but sometimes Smooth in 3D. I've asked Samsung about adding more granularity like their LCD sets have.
Samsung PN64F8500 (still within return policy window and open minded)
Oppo BDP-93
DirecTV HR-24
Denon AVR 2309-CI
Definitive Technology 5.1 system
Harmony One remote
endlessender is offline
post #651 of 4389 Old 05-31-2013, 03:45 AM
Ken Ross's Avatar
Quoted: 5801 Post(s)
Liked: 6177
Originally Posted by Cupstid View Post
I see it too. I noticed an improvement immediately when I turned on my set this morning.
Can't say I see any real change.
Ken Ross is offline
post #652 of 4389 Old 05-31-2013, 04:06 AM
zoyd's Avatar
Liked: 1055
Katzmaier measured a jump from 0.002 to 0.004 ftL
zoyd is offline
post #653 of 4389 Old 05-31-2013, 04:14 AM
zoyd's Avatar
Liked: 1055
Okay;
Reduced cell to 13
2: 37.25
4: 41.44
5: 38.23
7: 39.41
10: 38.68
12: 40.03
13: 39.58
15: 39.24
Patch 2 is ~10% lower than the other in both your tests, where is it? upper right corner? the other readings are close enough that I wouldn't worry about it and being a bit higher than the APL reading is not a problem. So running the lower cell is not an issue with peak whites.
zoyd is offline
post #654 of 4389 Old 05-31-2013, 05:33 AM
Liked: 171
^yep the second white patch top right. I was reading left to right. You can't tell that it's different. To the eye they all look the same brightness.
post #655 of 4389 Old 05-31-2013, 06:53 AM
DavidHir's Avatar
Quoted: 1768 Post(s)
Liked: 1376
Subjectively, that seems about right according what I saw. There is a significant rise with CS. In my opinion, CS is not needed as 60hz is fine on this display. I saw no issues with motion on content.
DavidHir is online now
post #656 of 4389 Old 05-31-2013, 07:13 AM
Liked: 171
Originally Posted by Elvamir View Post
Well it was fun working through the process to discover this! Like you said Pie, we're all here learning. Very interesting stuff, indeed! Good to know neither of us are crazy. :-)
So, I have to admit to a BIG rookie mistake. I had inadvertently left warm1 on viewing your cal. I mean of all the..... eek.gif
I must have seen 'warm1' so many times and just assumed it was warm2. Oh well.... No wonder I was seeing blue-white - it would have totally futzed up the 2p reading I did. When I get home later tonight I'll pull another for comparisons sake.
So now with the correct settings, all double checked, I do see a lot of red. Very pinkie flesh tones. I think this was reported by another member also who has a 64"
A good test I did was to visit CNN HD and check out their faces in the studio. They have their faces covered in foundation all theatrical style. Your cal is showing way too much red for me.
I also notice the whites are a bit too strong. The difference between light and dark is too contrasty. A quick view of TDK emphasizes this. Blacks are nice.
I'm still perplexed about the fL variation between our readings. I would expect a small difference, but not +/-14fL
Hopefully someone else with a meter and your size TV can do a quick measurement for us on your settings, that would be great.
The purpose of me saying this is to show the difference across the range. If we can somehow document this, it would be good for all. smile.gif
post #657 of 4389 Old 05-31-2013, 07:55 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Shouldn't that difference drop a little bit if you measure at "warm-2" instead of "warm-1"? Yeah, that would throw off ghe readings/coloring for sure. Oh well, at least you were able to catch that....I like to go to qvc or hsn networks to check my settings for flesh tones. Changing the color space from auto to your custom values drops the reds a little....it's noticeable.
DanF8500 is offline
post #658 of 4389 Old 05-31-2013, 08:21 AM
Liked: 171
^ maybe the fL will drop a click. I'll know tonight. Regards the red, I think that's due to the hard settings at 90 and 100% he did to flatten out gamma with a side effect of going too red.
post #659 of 4389 Old 05-31-2013, 08:27 AM
oddmania's Avatar
Quoted: 12 Post(s)
Any recommended setting's for game mode?
oddmania is offline
post #660 of 4389 Old 05-31-2013, 08:30 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
His 2-pt values for red gain/offset are up there too...highest I've seen yet for that cal setting (32/31).
DanF8500 is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
