F8500 Recommended Settings Thread..... - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 328Likes
post #1261 of 4364 Old 09-09-2013, 02:04 PM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
Originally Posted by mattduke1 View Post
I don't see "expert" on mine. I see Option, Control, Debug, SVC and ADC/WB. I read where only NA models have this "expert" option and I am in the USA. I purchased mine from Amazon. Do I need to click on one those options first before I see the word "expert"?
Press enter on SVC.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #1262 of 4364 Old 09-13-2013, 11:28 PM
mattduke1's Avatar
Sir, thank you very much. I was able to get it to work using your advice.
mattduke1 is offline
post #1263 of 4364 Old 09-14-2013, 01:14 AM
Andrew Rothman's Avatar
Anyone getting image glitches on pc mode and game mode with Wii, XBOX 360 or PS3?
Andrew Rothman is offline
post #1264 of 4364 Old 09-14-2013, 12:03 PM
WantsNWarrants's Avatar
Quoted: 84 Post(s)
Liked: 50
Originally Posted by LarryInRI View Post
Using the up and down arrow keys highlight the "N/D ADJ" item and press Enter.
Use the right arrow to get the "ON" setting. (Not "Fix.")
Hit Return.
With the down arrow key, highlight the "Source" item and use the right or left arrow keys to get "ALL"
Click Return twice to get back to the main menu.
(Not really needed but do it anyway.)
Larry
Is the Bolded portion really necessary?
WantsNWarrants is offline
post #1265 of 4364 Old 09-14-2013, 12:41 PM
pieandchips's Avatar
Liked: 171
Nope. I don't use game mode, only rename input to PC.
pieandchips is offline
post #1266 of 4364 Old 09-14-2013, 03:28 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
1. If you want the additional modes available for all source inputs, yes it is necessary to set the Source to All.
2. I made it clear that it is not necessary to do this. You even quoted my statement about this.
Larry
LarryInRI is offline
post #1267 of 4364 Old 09-15-2013, 06:43 PM
Standtall29's Avatar
I really like your setting thank a lot.
Standtall29 is offline
post #1268 of 4364 Old 09-15-2013, 08:19 PM
I only get the glitch on the wii on game mode. I can't enable PC mode on the wii because it sends a 60p signal instead of 60hz and PC mode only kiks in with 60hz. I do use PC mode on the xbox 360 though. I was getting a glitch on the Xbox on pc mode as well (completely different, on the wii, the image sort of breakes up on the top of the screen, as if it were separated by a line and the xbox glitch was some distortion in the colors for brief moments with fast movement) but after I reconnected the HDMI, the glitch stopped, so it was probably due to a loose HDMI cable or something. I also got much beter PQ and faster response on the xbox by selecting the "source" option for the color space (so it changes the color space depending on the source).
post #1269 of 4364 Old 09-16-2013, 03:45 PM
Cg006's Avatar
For you guys already gaming on the panel...
How is the image retention situation?
I got my PN60F8500 about 2 weeks ago... have been doing nothing but watching tv shows/movies enjoying the awesome picture levels. Hoping before the next gen drops i can have on it at least over 300 hours.
I've never owned a plasma and i am kinda taking a leap of faith here and hope i wont get bit in the A$$ with burn in. Some of my buddies have had good experience with gaming on their plasmas. I am a big gamer. Cant wait for November. PS4/XboxOne on reserve!!!!!!!!!
Whats your experience so far?
Also... how can i check the hours on the panel? I have not had luck finding the steps for the 8500 series and i am also waiting for that non-touch remote (thanks for the tip guys) to arrive.***seems i HAVE to wait for that remote before i can do anything anyways****
Cg006 is offline
post #1270 of 4364 Old 09-16-2013, 04:11 PM
After 150 hours, image retention got much better for me. Gears of war 3 mp gave me some image retention after one hour of online mp and i got it off in 15 min (mp hud).
I playd 4:30 hours straight of Zelda TP today and got no IR at all. Im at 165 hours on my set. Don't worry about it smile.gif I felt the same way at first and I finally feel relaxed about gaming on it.
Cg006 likes this.
post #1271 of 4364 Old 09-16-2013, 07:50 PM
Cg006's Avatar
That's good to hear! Lucky for me I probably won't be gaming for another month so I can just watch a lot of tv. Can't wait to see those 1080p games. Wish I could drop my pc next to it but it's in my bedroom. Lol
Cg006 is offline
post #1272 of 4364 Old 09-17-2013, 03:59 AM
Yeah! biggrin.gif I forgot to mention that I always use pixel shift for gaming.
post #1273 of 4364 Old 09-17-2013, 07:04 AM
Cg006's Avatar
I have it on aggressive settings . Pixel Shift 4 pixels and frequency every 1 minute
Looks like i will have no choice but to select another HDMI besides HDMI-3 to be able to change to "PC" but i will be loosing my ARC functionality frown.gif
I wanted to just have it on hdmi3 for arc and as main video out from receiver...
Also...About input lag... have been reading since for current gen has to scale the image to 1080p it could introduce input lag.... with the next gen being true 1080p consoles, any chance input lag could decrease since everything should be at native resolutions?
I caved in and did a little bit of gaming like 30 minutes... colors look so amazing. have to get used to the black levels.
Cg006 is offline
post #1274 of 4364 Old 09-17-2013, 12:06 PM
You can't use PC mode on HDMI 3 (ARC) ?
post #1275 of 4364 Old 09-17-2013, 12:21 PM
Cg006's Avatar
I disconnected the HDMI cable on HDMI3 form my tv, changed source to HDMI 1 (didnt connect cable)
Then brought up the menu and highlighted HDMI3 from the list and went to tools.. it only lets me "rename it" with the onscreen keyboard. The other HDMI lets you select "PC" from a preset list of devices list; which I believe thats the way you need t "set it"
Cg006 is offline
post #1276 of 4364 Old 09-17-2013, 02:32 PM
Berat Blakaj's Avatar
What kind of settings are you guys using for gaming? Are you sticking with Calibrated Movie mode?
Berat Blakaj is offline
post #1277 of 4364 Old 09-17-2013, 02:32 PM
Liked: 171
^Optical cable time.
post #1278 of 4364 Old 09-17-2013, 03:38 PM
I get this glitch with the Wii on game mode http://www.youtube.com/watch?v=QrH_zB5TOgM&feature=youtu.be Any thoughts?
post #1279 of 4364 Old 09-18-2013, 12:31 PM
Liked: 171
^Wii is 720p IIRC?
Looks like tearing. Twiddle with both Wii output settings and TV settings.
Andrew Rothman likes this.
post #1280 of 4364 Old 09-18-2013, 12:34 PM
Liked: 171
HDMI renamed to PC / Standard mode / warm2 / Gamma 0. I will attempt a cal on it at some point.
No game mode turned on.
post #1281 of 4364 Old 09-18-2013, 01:57 PM
I just did my gaming mode by eye in Standard mode / warm2 / Gamma 0. I will attempt a cal on it at some point.
HDMI renamed to PC / no game mode turned on.
Thanks Pie. I ended up doing the same after I got GTA5 on PS3. Do you know any way around having to change the PC and back to BluRay to reenable movie mode? Or is it something I will just have to deal with.
post #1282 of 4364 Old 09-18-2013, 02:27 PM
mightymouseusf's Avatar
Quoted: 34 Post(s)
Liked: 33
^Wii is 720p IIRC?
Pie...did you just use the term "twiddle"?
mightymouseusf is offline
post #1283 of 4364 Old 09-18-2013, 03:36 PM
Liked: 171
Yup, you have to rename each game session then back again.
Berat Blakaj likes this.
post #1284 of 4364 Old 09-18-2013, 03:37 PM
Liked: 171
Examples of TWIDDLE
Just twiddle the dial on the radio a bit for better reception.
Twiddle the knob on the telescope until things are in focus.
She twiddled her pen while she talked on the phone.
She twiddled with her pen while she talked on the phone.
I lived in the UK a while lol.
post #1285 of 4364 Old 09-18-2013, 03:45 PM
^Wii is 720p IIRC?
480p. Yeah, I think it's tearing also. The wii outputs a 60p signal, could it have something to do with that?
post #1286 of 4364 Old 09-18-2013, 05:28 PM
I'm at a little over 300 hrs played GTA 5 on the PS3 last night for about an hour or more and had no issues whatsoever.
post #1287 of 4364 Old 09-19-2013, 05:37 PM
Cg006's Avatar
Wow. Standard move is very bright. I thought I would be able to keep all my movie settings when I changed to pc.
Cg006 is offline
post #1288 of 4364 Old 09-19-2013, 06:25 PM
Liked: 171
^ In PC mode (standard) Cell at 7 is nice
Contrast 94
Brightness 40
Warm 2
Gamma 0
White balance is the same as my movie cal with very little deviation.
Good to check your console is outputting full RGB and that the TV is set to HDMI normal, or choose RGB limited and HDMI low but do not inter-mix the settings or you'll clip.
post #1289 of 4364 Old 09-19-2013, 06:28 PM
Pieandchips, any thoughts on the tearing with the Wii on game mode?
post #1290 of 4364 Old 09-19-2013, 06:42 PM
Liked: 171
^ I really don't know sorry. Not having a Wii and not having the problem doesn't help frown.gif
Wii uses component?
/edit: What happens if you don't use game mode but rename input to PC?
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
