F8500 Recommended Settings Thread..... - Page 73 - AVS Forum
post #2161 of 2171 Old 05-19-2014, 03:49 PM
Ice That Jaw's Avatar
Originally Posted by chunon View Post
The C6 is an enhanced I1d3 it a very good colorimeter. It can be more accurate if it is profiled off a spectro but your calibration looks solid. If you wanted to get into yourself I would recommend an I1d3 and Calman Control at a minimum about a $400 dollar investment. The i1d3 will be stable much longer because the optics are sealed. The software comes with a 1 year of support for upgrades and bug fixes. I have delved into DIY myself but hit a meter accuracy wall that wasn't sufficient for my expectations but there are many diyers that use the I1d3 and are very happy with their calibrations.
Cool, thanks for the tips.
Is this the spectro you are referring to -> http://www.amazon.com/X-Rite-EODIS3-i1Display-Pro/dp/B0055MBQOW/ref=cm_cr_pr_product_top
Is that compatible with the Calman 5 suite?
Looking at Calman's site, the tutorial version has the CMS, 2-point and 10-point calibrations tools and that's pretty much all I'll ever need right?
Also, how well would this combo hold up to let's say, an OLED I might purchase 4-6 years from now?
LNT-4665F
T-TULPAUS0-1036, Aug 24 2007
T-TULPAUS5-1011 CS[D652] [46(AMV)-inch]
PS3
XBOX 360
Crappy Sound Reciever
Ice That Jaw is offline
post #2162 of 2171 Old 05-19-2014, 03:58 PM
chunon's Avatar
Quoted: 55 Post(s)
Liked: 447
The i1d3 is a colorimeter, a spectro is a I1pro or I1pro2. The ideal combination is the i1d3 profiled off the spectro, that way you have the speed and low level performance of the i1d3 with the color accuracy of a spectro. Yes you should be able to use the meter to calibrate an oled in the future. Yes you could get by with the lower level of Calman but I think the Control version and up has valuable functionality.
65VT60
55ST60
Sony BDV-F7 3dbluray/soundbar
Calman Enthusiast
Dish Network with Hopper/Super Joey
chunon is offline
post #2163 of 2171 Old 05-19-2014, 04:16 PM
OK, so the link I posted is the i1d3 which isn't a spectro? (It just says display pro so I' confused by the abbreviation)
I looked up the i1Basic Pro 2 which I take it is the l1pro2 you mentioned and it retails for a whopping $1300. How good of a calibration will the one I linked to provide given, I can't afford a $1000+ spectro? I'm hesitant to spend anymore if it's not nearly as accurate the calibration I paid for.
EDIT - Do you also need to buy a pattern generator or can you just use the patterns included in the Calman software?
LNT-4665F
PS3
XBOX 360
post #2164 of 2171 Old 05-19-2014, 04:29 PM
chunon's Avatar
Quoted: 55 Post(s)
Liked: 447
You can pick up a used i1pro revd spectro for 300 to 400. The i1d3 is in par with the c6 your calibrator used.
65VT60
55ST60
Calman Enthusiast
chunon is offline
post #2165 of 2171 Old 05-19-2014, 06:07 PM
nipalikewalnuts's Avatar
You can calibrate the colors to spectros for easier/quicker calibrations.
TBH, there is a very small margin of difference between a system calibrated with a colorimeter or a spectrometer. Only trained eyes can see the difference as they know what to look for, but that's not always.
You don't look to have anything 'bad' at all on your calibration:
Post Calibration DeltaE2000 of 1.52 measured with a colorimeter, greyscale is perfectly acceptable. the human eye can't tell the difference at that level.
You're good to go.
nipalikewalnuts is offline
post #2166 of 2171 Old 05-19-2014, 06:59 PM
JimP's Avatar
Quoted: 34 Post(s)
Liked: 172
For a 6 point CMS, you can use one of the many calibration disk that are available.....provided your bluray player is outputting a reference signal. Which bluray player are you using?????
Some do try to use their laptop as a signal generator but from what I gather, its a real pain and often times doesn't work right. So you may find yourself spending many hours doing calibrations to an incorrect signal.
Signal generators do make life much easier and if you go the 3D cube calibration route, you'll probably want to get one. I really like the Accupel 5000 and its well support on the entheusiast licenced version of Calman and on the plus version of Chromapure.
Samsung 64F8500, Panasonic 65VT50, Oppo 95, Tivo Roamio for OTA, Dish VIP722, Marantz AV8801 preamp, Rotel Amps, Atlantic Tech 8200 speakers, Seaton Submersive HP, Calman 5, Chromapure, Accupel DVG-5000, i1Display3pro, i1pro2, eecolor colorbox.
JimP is online now
post #2167 of 2171 Old 05-20-2014, 04:56 PM
I just use my PS3 as a bluray player. But if you have the Calman software it has all it's patterns built into it, right? I don't remember him hooking up anything else to my TV. It looked like it was just the Colorimeter via HDMI into my receiver.
LNT-4665F
PS3
XBOX 360
post #2168 of 2171 Old 05-21-2014, 10:12 AM
cyberized's Avatar
I setup Standard, Relaxed, and Motion with "DARK Room" and then I read a suggestion to set Standard and Relax at AUTO and Movie only at DARK Room..............so I went to do this and I find that for some unknown reason that setting is in SYNCH with the others.......whatever I set Movie at the others do the same.....so IF I set Movie to Dark Room, all three will be DR!
PLEASE advise................
TKS;)
cyberized is offline
post #2169 of 2171 Old 07-08-2014, 07:10 AM
Bobby244's Avatar
Quoted: 14 Post(s)
Bought this TV a week ago and am using the WoW bluray to set everything up. A couple of questions;
1) For the motion judder setting, I've changed it from standard to "smooth". I've noticed when watching TV shows such as 24 and suits that the smooth setting seems to improve the motion to my eyes compared to when it was on standard when there are scenes such as fast walking through a room for example. Are there any negative effects to changing this setting to smooth?
2) What darkness level should I have the TV set to? I believe the choices were low, dark, darker, or darkest (I could be wrong on this). I've changed this setting to dark, and everything looks good but is this the setting I want it on to get he best blacks? Just curious what everyone else sets it to.
Bobby244 is online now
post #2170 of 2171 Old 07-08-2014, 08:27 AM
wxman's Avatar
Quoted: 35 Post(s)
Liked: 182
Turn off dynamic contrast and black tone. Set Black Optimizer to dark room or auto.
"The only reason people get lost in thought is because it's unfamiliar territory"
wxman is offline
post #2171 of 2171 Old 07-08-2014, 09:12 AM
Bobby244's Avatar
Quoted: 14 Post(s)
Thanks I'll try that tonight
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
