F8500 Recommended Settings Thread..... - Page 74 - AVS Forum | Home Theater Discussions And Reviews
 334Likes
post #2191 of 4389 Old 07-25-2014, 02:50 PM
paligap's Avatar
Quoted: 125 Post(s)
Liked: 43
Originally Posted by Ph8te View Post
Component nooooooooo
Sent from my Flip Phone using DOS
Well, I'm talking about watching news, etc.; it doesn't have to be the ultimate picture. Plus, it gives me a way to customize settings depending on inputs. I use Component in for daytime viewing, HDMI1 for nighttime TV viewing, and HDMI2 for blu-ray viewing.
One thing I'm wondering, though, after going through these settings: Why are Auto1 and Auto2 grayed out in Film Mode, even when I'm feeding a blu-ray movie signal to the TV?
paligap is offline
post #2192 of 4389 Old 07-25-2014, 03:02 PM
Ph8te's Avatar
Quoted: 4574 Post(s)
Liked: 4035
Check your Blu-ray settings to make sure it's outputting the correct signal. Film Mode will only activate when the TV receives the right one. Not sure if it's available on component either. I think most have the set with HDMI only.
Ph8te is offline
post #2193 of 4389 Old 07-25-2014, 03:27 PM
paligap's Avatar
Quoted: 125 Post(s)
Liked: 43
The only thing I have hooked up by component to the TV is a PVR. My Blu-ray player is connected via HDMI. What do you mean by "the correct signal?"
paligap is offline
post #2194 of 4389 Old 07-25-2014, 03:32 PM
Ph8te's Avatar
Liked: 4035
Your Blu-Ray player needs to have 1080p/24 enabled. If your are sending out 1080/60 FM gets disabled. Also if you are going through your AVR you need to make sure it's set to "pass-thru" and not a "set" value.
KONICA TECH likes this.
Ph8te is offline
post #2195 of 4389 Old 07-25-2014, 07:03 PM
paligap's Avatar
Quoted: 125 Post(s)
Liked: 43
I have an Oppo with dual HDMI output, and it has 1080p/24 enabled. The HDMI going to my receiver has the video disabled, and the one going to the TV outputs only video. I also have an HDMI from my receiver to the TV for the satellite signal. I might need to re-think the connections if there is some kind of "bleed-through" on the HDMI from the Oppo to the receiver. On the other hand, it looks very good as is.
paligap is offline
post #2196 of 4389 Old 07-25-2014, 09:07 PM
Stereodude's Avatar
Quoted: 3159 Post(s)
Liked: 2306
Originally Posted by leetchie69 View Post
I used most of the settings in here expect I had to pump up the brightness a bit. It was too dark in the high 40 range.
Currently set to 58.
Using what source? My HTPC sending RGB (0-255) needs a brightness setting of 48 and my cable box (YCbCr 16-235) needs a brightness setting of 47.
Stereodude is offline
post #2197 of 4389 Old 07-25-2014, 09:10 PM
Stereodude's Avatar
Liked: 2306
Those are only selectable if you're sending the TV an interlacing signal. Your blu-ray player is unlikely to output 1080i60.
post #2198 of 4389 Old 07-25-2014, 09:48 PM
Quoted: 1444 Post(s)
Liked: 600
That doesn't sound right.
What do you have contrast, cell and eco set too?
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is online now
post #2199 of 4389 Old 07-26-2014, 06:29 AM
leetchie69's Avatar
Quoted: 16 Post(s)
Liked: 5
Contrast 95
Cell Light 17
Eco off
Even using the Disney WOW disc to calibrate, 58 looks to be the ideal setting for my set.
leetchie69 is offline
post #2200 of 4389 Old 07-26-2014, 06:32 AM
leetchie69's Avatar
Quoted: 16 Post(s)
Liked: 5
Any source really....they all look great.
post #2201 of 4389 Old 07-26-2014, 07:06 AM
Stereodude's Avatar
Liked: 2306
So if you pause playback of your source on a pure black frame and go up to the F8500's screen and look at it closely you don't see any "dancing" red/green pixels instead of a constant very dark gray shade?
On my 64" F8500 the "dancing" pixels show up at 49 with a RGB (0-255) source and 48 with a YCbCr (16-235) source. Hence why I'm using 48 and 47 respectively for brightness.
I have Cell Light at 20 and Contrast at 95 in Movie / Warm2. I have not adjusted gamma from 0, made any 2 / 10 point white balance adjustments, or adjusted CMS changes (so far).
post #2202 of 4389 Old 07-26-2014, 07:42 AM
paligap's Avatar
Quoted: 125 Post(s)
Liked: 43
One reason I'm confused about this is that I gathered some recommended settings from several sources just to see if there was consensus or at least patterns of agreement. Some of those sources said to set Film Mode to Auto2. I had assumed that most people, when they think of recommended settings, are thinking of applying them to the input that feeds the blu-ray signal.
After watching a movie last night, I turned my receiver off and switched to the component input on my TV, which is how I usually watch satellite programming in the daytime. There was a program about the history of the Bond franchise on that contained clips from the movies. When the clips came on, I noticed a significant soap opera effect. I went into the picture menu, and not only were Auto1 and Auto2 not grayed out, but Auto 1 was selected. I turned it and the dejudder canceller off, and the SOE went away.
Another reason I'm confused about the Film Mode setting is that I don't know how it works or when or why it should be set to something other than Off.
I have a fairly complex set-up, and it might need some tweaking. I have the 8500, a Denon 4310 (non-3D capable), a PVR, and an Oppo 103D. The PVR is connected to the TV by component video and composite audio, and it's connected to the receiver by HDMI. The receiver is connected to the TV by HDMI. The Oppo is connected to the TV by HDMI (video only), and to the receiver by HDMI (audio only). I'm trying to set my picture settings based on which input the TV is on.
paligap is offline
post #2203 of 4389 Old 07-26-2014, 08:00 AM
Stereodude's Avatar
Liked: 2306
I guess I should have been a little more clear in my post. Commercial movies on Blu-ray are 99% (or greater) 1080p24. The player will most likely output 1080p24 or 1080p60 depending on how it's set and what it can do. 1080i60 is a valid format for a Blu-ray disc. Your player probably can output 1080i60, but it might also process it internally to 1080p60 or 1080p24 depending how you have it configured. However, short of test discs and maybe concert Blu-rays 1080i60 is on Blu-ray is quite uncommon.
Film mode (Auto 1) is intended to be set for interlaced content that originated from film to recover the original progressive frames. Specifically 24FPS film content that has had a 3:2 telecine applied to it to get i60. So, if you watch a movie on HBO from cable or satellite Auto1 should be used there. A lot of network TV shows broadcast shows in HD are also film based, shows like CSI, NCIS, Grimm, Revolution, etc. You would want to use Auto1 on these also. HD shows your local news, Saturday Night Live, The Tonight Show, etc are extremely unlikely to be film based i60 content and Auto1 shouldn't be used for them.
paligap likes this.
post #2204 of 4389 Old 07-29-2014, 04:54 AM
ParityBit's Avatar
Quoted: 113 Post(s)
Hi all,
There is a ton of information here! I am getting my 64 F8500 tonight, and I was wondering if there are some good settings for my situation. At least to start.
I have the Disney WoW disc, and my components will be through my receiver. I have a PS4 and Xbox One, both of which I could use as a BR player. I could use a dedicated system also if that will make things easier.
Are there and starting settings I should try for both the cable and game systems? I know people have mentioned using 'gaming' or 'pc' as modes, but then that would screw up the visual quality of my BR player wouldn't it?
EDIT: Oh, should I updated the firmware right away? Or soon after getting setup? Assuming it is not the latest?
EDIT 2: Do you run all your connections to a receiver and then pass a single HDMI cable to the TV? With the changing of modes, it seems this would be illogical.
ParityBit is offline
post #2205 of 4389 Old 07-29-2014, 06:37 AM
leetchie69's Avatar
Quoted: 16 Post(s)
Liked: 5
No I don't, blacks look spectacular actually.
I will try to take a pic tonight.
post #2206 of 4389 Old 07-29-2014, 07:11 AM
djsketchie's Avatar
Quoted: 52 Post(s)
Liked: 31
Quick question about this since you seem to be knowledgeable about it:
Wouldn't the Auto1 setting not engage if it doesn't detect interlaced film based material, hence the "Auto" in the name? So for example, if I leave the setting on Auto1 and I am watching a film based show like CSI and then the local news follows, will the TV detect and engage the processing for CSI, then turn off the processing when the news comes on, or would you have to go in and manually toggle to the Off setting?
djsketchie is offline
post #2207 of 4389 Old 07-29-2014, 07:38 AM
Stereodude's Avatar
Liked: 2306
I guess it all depends how picky you are about it. I've seen what I believe are artifacts introduced by the film processing with Auto1 on true 1080i60 content, so I generally change it to off manually. The artifacts seem to go away when it is turned off.
post #2208 of 4389 Old 07-29-2014, 07:45 AM
RyanHomsey's Avatar
Quoted: 113 Post(s)
Liked: 42
I noticed the dancing green pixels on my PN60F5300 and had assumed it was related to the pentile pixel arrangement. I decided to test it and threw up a full black screen and sure enough, when I toggle between 48 and 47 brightness the dancing green pixels disappear. 47 brightness it is! Now I need to go back and check my gamma - might as well recalibrate at the lower saturation points while I'm at it (it's currently calibrated @ 100% sat. points).
RyanHomsey is offline
post #2209 of 4389 Old 07-29-2014, 07:48 AM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
FWIW, I keep all of these things off (ie. film mode, motion judder control, cinema smooth). Anytime I've turned any of these on, they introduced something to the picture that I didn't like, and in every instance, I found that the TV looked better with them off. With all of these turned off, the picture looks fantastic to me. Whatever issues these features are supposed to solve . . . I'm not seeing them.
Chronic masticator.
Gear: Speakers (Paradigm Reference Studio Series): 40 v4 (front L/R), CC-690 v4 (centre), 20 v4 (surround L/R). PSA XS30 (subwoofer).
Denon AVR-X4000, Emotiva XPA-5, Samsung PN64F8500 (64" plasma), DarbeeVision Darblet DVP5000, PS4, PS3, Sony BDP-S6200,
Apple TV (3rd gen.), Harmony One, Sennheiser RS180
tboe77 is offline
post #2210 of 4389 Old 07-29-2014, 07:57 AM
leetchie69's Avatar
Quoted: 16 Post(s)
Liked: 5
I use cinema smooth when playing back Blu-Ray's that support 24p.
It gives it a nice smoothness without the "soap opera effect"
post #2211 of 4389 Old 07-29-2014, 08:36 AM
Stereodude's Avatar
Liked: 2306
Film mode (Auto1/Auto2) is intended to recover 1080p24 content from an interlaced 1080i60 (in the US) video stream instead of straight deinterlacing. That's not a processing gimmick and it does work. Unfortunately, the TV doesn't offer the ability to enable Cinema Smooth with Auto1/Auto2 so the recovered 1080p24 frames are displayed with an uneven 3:2 cadence.
Cinema Smooth displays 1080p24 at 96Hz so it has a even 4:4 cadence instead of the uneven 3:2 cadence you would otherwise get at 60Hz. Also not a gimmick, though the set doesn't do it quite perfectly and has occasional glitches/hiccups (frame drops). Not withstanding the glitches/hiccups this is replicating the 24Hz presentation of film in a theater.
Motion judder control is a feature that interpolates frames yielding the soap opera effect that many people don't like, but some people do.
If you're a purist some of the features are gimmicks and other aren't. If you like them you can use them. If you don't, you don't have to.
post #2212 of 4389 Old 07-29-2014, 01:03 PM
rickardl's Avatar
Quoted: 107 Post(s)
Liked: 91
What would you recommend (Auto1/Auto2/Off) if I set my European cable box to output:
A) 1080i50hz (box converts all to 1080i50hz) or
B) native (which means a mix of 575i, 720p and 1080i50hz depending on the channel)
rickardl is offline
post #2213 of 4389 Old 07-29-2014, 01:05 PM
wxman's Avatar
Quoted: 3705 Post(s)
Liked: 2656
Native. The less processing the better. As far as film mode, Auto1 when watching movies as they were filmed, and Auto2 for sports and regular tv which uses digital video. When set to native, 720p material will have film mode greyed out.
LG 65EF9500
LG 65E6P
wxman is offline
post #2214 of 4389 Old 07-29-2014, 01:11 PM
rickardl's Avatar
Quoted: 107 Post(s)
Liked: 91
But if I have it set to 1080i50, which setting of Auto1 / Auto 2 and Off would you recommend?
Problem with native is that it takes time for the TV to adjust when switching resolutions when zapping through channels...
rickardl is offline
post #2215 of 4389 Old 07-29-2014, 01:45 PM
wxman's Avatar
Liked: 2656
Since I don't watch many movies on cable, I set it to Auto2 all the time.
LG 65EF9500
LG 65E6P
wxman is offline
post #2216 of 4389 Old 07-29-2014, 01:46 PM
Stereodude's Avatar
Liked: 2306
Auto2 was what AVforums recommended in their review, whereas Auto1 is what US reviewers have recommended. I'm not entirely sure what the difference between them is. I haven't attempted to test them myself.
post #2217 of 4389 Old 07-29-2014, 02:10 PM
Ph8te's Avatar
Liked: 4035
If I remember correctly (and has already been mentioned) Auto1=Film Source; Auto2=Video Source when available that is. This was discussed and demoed in last years Shootout.
Ph8te is offline
post #2218 of 4389 Old 07-29-2014, 02:15 PM
Stereodude's Avatar
Liked: 2306
I'm a little skeptical that one of the film modes is the one to use for true interlaced video over "off".
post #2219 of 4389 Old 07-29-2014, 02:20 PM
Ph8te's Avatar
Liked: 4035
They showed it via the test material when switched to Auto2 the set correctly displayed the material. If I get a chance I'll try to find you the link.
Ph8te is offline
post #2220 of 4389 Old 07-29-2014, 03:09 PM
Ph8te's Avatar
Liked: 4035
http://youtu.be/w0qQMvMkqws?list=UUw...JwVmQioyXfC5Uw
Watch at ~23 Min in is where the modes are described....
Ph8te is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
