Samsung PN42B450 picture problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-18-2013, 11:55 AM - Thread Starter
dsellinger's Avatar
I have this now out of the blue. No menus, no change on inputs. It is doing a lot of flickering and jumping from different "static" types.
Any ideas on repairability? Or is it time to start shopping?
dsellinger is offline
post #2 of 4 Old 04-18-2013, 01:22 PM
pioneertop's Avatar
Quoted: 28 Post(s)
Liked: 176
had this happened..with minds ..sometime ago ...i got the main power bored ..and the upper and lower y bored s changed ..i changed the av bored to did it myself ...and since then ..the tv works fine ..its in my bedroom now..
loves...home theather/music/football:)
pioneertop is offline
post #3 of 4 Old 07-24-2013, 12:01 PM
unspun01's Avatar
Did you ever get this problem sorted out? I have the same TV, and almost identical issues with the video - it loos just like your picture. No clear picture or image on any input. Unable to see the menu.
Every once in a while, the image will look absolutely perfect for a split second, and then back to ugly.
Have you repaired this TV? If yes, please tell what you did to fix it, or what board you replaced that solved the problem.
unspun01 is offline
post #4 of 4 Old 07-24-2013, 12:56 PM
XSpressure's Avatar
I'm also having the same issue and would also like to know if you solved the issue. I checked on Ebay for the boards and total is over $170 for all of them. Not sure if I should buy the boards or put the money towards another TV.
XSpressure is offline
Samsung Pn42b450 42 Inch 720p Plasma Hdtv
