F8500.. OR .. ZT60 ????? - Page 103 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
Old 04-06-2014, 08:53 AM
Stu03's Avatar
Quoted: 69 Post(s)
Liked: 169
I would like to hear about the similarities/issues between the VT30 and this generation in a calibration sense.
If wether it affects all displays or just some
Stu03 is offline
Old 04-06-2014, 10:46 AM
Chad B's Avatar
Quoted: 496 Post(s)
Liked: 1194
Originally Posted by lovingdvd View Post
Has anyone used CalMAN to measure the gamut and see how the color saturations, lumanance and sweeps measure? I would love to see the output from that. Not just where the primaries lay on the gamut but how well it tracks across all saturation levels. At a minimum I would like to confirm that the primaries at their widest setting are greater than the Rec709 targets and that there is sufficient brightness in each of the primaries at these targets to provide the headroom for a fully accurate color calibration. Thanks.
See my second to last post above. What you're looking for is in the calibration reports.
Chad B is offline
Old 04-06-2014, 10:57 AM
-Hitman-'s Avatar
Quoted: 134 Post(s)
Liked: 106
Originally Posted by Chad B View Post
The PWM noise did seem to be more distracting on some Kuros than others. I did keep power save off unless the customer wanted it on for some reason.
Did you see this on any of the KRP monitors, Pioneer did say that the monitors were the cleanest image displays they had produced even though they were internally similar to the other G9's, they couldn't explain why the monitors were cleaner.
I have a 600M and don't have any PWM noise, just a clean image.
-Hitman- is offline
Old 04-06-2014, 11:01 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
NO PWM noise aka dithering? I'd like to see this on a plasma.
vinnie97 is offline
Old 04-06-2014, 11:31 AM
lovingdvd's Avatar
Quoted: 2214 Post(s)
Liked: 360
Thank you Chad. I wasn't sure however what post you were referring to? I did not see a Calibration Reports section, tho it is probably right under my nose? Can you please provide a link?
I did find some extremely useful information from your review of the 8500, linked to in your review. I commend you for the outstanding attention to detail with regards to calibration and technical information in your review! Truly outstanding. There are very few people out there I would ever let touch my displays or projector, but I can tell from your write-ups that you are certainly one of those I would be very comfortable with! smile.gif
Yes with the software tools available these days I like to make sure that a display has excellent color accuracy and tracking across all saturation levels and not just fixed at an end point. To do this as you know the native gamut must plot wider than its Rec709 points AND have enough lumanance in each of R,G,B so it can be adjusted properly. Do you know if the 8500 meets that criteria? If so I can use a Radiance with Auto-cal and 5x5x5 3D LUT to dial it in with extreme accuracy. Yet to do this it has to meet the above mentioned criteria.
Thank you!
lovingdvd is offline
Old 04-06-2014, 01:30 PM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
Chad B. or D-Nice (or any calibrator),
Do you know if there is a way in the service menu to defeat the slight amount of artificial edge enhancement that exists in the 'Mid' and 'High' modes for the 2013 Panasonics? I notice running it in 'Low' Panel Brightness mode, any trace of edge enhancement is gone, but I miss the increased brightness running it in 'Mid'. For the record, I have my Sharpness set at 0 and all other artificial enhancements turned off. I'm sending primarily 1080p/24fps from my Blu-ray player directly, i.e. with no enhancements. I have the TV set -- with the latest firmware -- to 1080p direct mode, though I notice the same amount of artificial EE with 1080p direct turned off. Mind you, it's only a slight amount of EE, but it's none the less there and none the less irks me. I strongly desire to defeat it if possible, and I would think others would as well.
RWetmore is online now
Old 04-06-2014, 01:43 PM
chunon's Avatar
Quoted: 2029 Post(s)
Liked: 1781
^^^^^ Not only are you losing light output you are compromising black level. Degraded contrast ratio for sure .
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
Old 04-06-2014, 01:54 PM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
I did not find that to be the case. In fact, the blacks after slight re-adjustment/re-calibration, seemed to go a little deeper. Overall, 'Low' seems to be the most accurate mode, though a little too dim, unfortunately.
Old 04-06-2014, 01:55 PM
chunon's Avatar
Liked: 1781
It has been documented with a meter on the zt ,vt and st
It also does not calibrate well
65C6 OLED
Old 04-06-2014, 02:20 PM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
I have the S60, so maybe it's different, though I wouldn't think it would be for this.
Edit: I realize I initially posted this in the wrong thread. It belongs in the 2013 setting/issues thread.
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
Originally Posted by mailiang View Post
And David Katzmaier, also a certified calibrator who heads up the CNET team, prefers the ZT. This is a very subjective topic and we can debate this subject all day long and we will continue to get different opinions from different experts. Maybe it's time to just call it a draw and move on guys. wink.gif
Ian
I agree with you after awhile you wont be able to buy none of them,thats mean the Kuro too if you have one be thankful.
Chise is offline
Old 04-06-2014, 02:37 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
My S60 seems to perform better with the mid setting. I haven't noticed any additional noise or ringing and there is less posterization when watching overly compressed content on DTV.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
Old 04-06-2014, 03:47 PM
Chad B's Avatar
Quoted: 496 Post(s)
Liked: 1194
I haven't noticed any edge enhancement or ringing with sharpness settings of 0-16 in full screen mode and overscan off.
Chad B is offline
Old 04-06-2014, 03:55 PM
Chad B's Avatar
Quoted: 496 Post(s)
Liked: 1194
Thank you!
Thanks for the kind words! Here is the post:
http://www.avsforum.com/t/1469541/f8500-or-zt60/3030#post_24574589
Chad B is offline
Old 04-06-2014, 09:43 PM
Chad B's Avatar
Quoted: 496 Post(s)
Liked: 1194
Thank you!
Here's a recent calibration report on an F8500. It does fulfill your criteria. The 100% saturation points can be oversaturated a bit if desired, but the lower saturation levels tend to be undersaturated. Gamut luminance is not an issue. I would think a LUT cal would do very well on it.
Samsung_F8500_Movie-bright_-_Copy.pdf 1531k .pdf file
EDIT: Looking at some of my other F8500 cal reports, it appears blue is not always able to reach the rec 709 target, but it's not very serious. Here is an example, and it's my older style report.
Samsung_F8500_moviecopy.pdf 1040k .pdf file
Keep in mind all these reports use the Custom color space... Using Native or auto might give you more saturated primaries at the expense of some luminance irregularities.
Chad B is offline
Old 04-07-2014, 01:01 AM
sillysally's Avatar
Quoted: 828 Post(s)
Liked: 848
Once you get below about 0.001 fL. with blacks, which the ZT/VT60 does, the deeper blacks provided by the KURO aren't overtly noticeable except in a dark viewing environment.
In case you missed my post about the blacks, here is a link to that post showing the repeatable black level of .0009 on my VT60. However those test's where done using a 9300 color point patch set. Also keep in mind the only adjustments I did on in my VT60 for this LUT was using Red and Blue mainly for 30% and 100%, never Green or detail Gamma adjustments.
http://www.avsforum.com/t/1467563/official-panasonic-vt60-vt65-series-discussion-thread-no-street-price-talk/13830#post_24563192
Here is a link to a LUT I did on a VT60, this shows what you are looking for.
The two ClolorChecker chats, the top one is for flesh tones and the lower CC is just a normal CC chart.
http://www.avsforum.com/t/1517849/a-comparison-of-3dlut-solutions-for-the-eecolor-box/30#post_24367983
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
Old 04-07-2014, 07:40 PM
jrhunkler's Avatar
UPDATE: I couldn't wrap my head around getting the F8500 with the hideous bezel, so I kept my 65" ZT60, bought a Darbee Darblet DVP 5000, sold my 60" 6020, and bought a KRP-500M calibrated by D-Nice for my bedroom. The 500M is VERY nice, but still not as clear as the ZT. Shadow detail is better on the ZT as well. Splitting hairs, but they are both amazing sets.
Here's a couple pics from both sets: (ZT is on the top / mounted to the wall in back of the 500M)
skidawgz and ChadThunder like this.
jrhunkler is offline
Old 04-07-2014, 07:50 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
^Fantastic collection. Yea, that's another common contention I've seen concerning shadow detail, though someone (not me) will probably say your 500M needs a D-Nice tuneup (or that your ZT60 is using edge enhancement or the Darby is connected to the ZT60 giving it an unfair advantage). tongue.gif
Meh, all that hair-splitting aside, a 500M plus a ZT60 is the best way to ride out the apocalypse (with an LG OLED on the side).
vinnie97 is offline
Old 04-07-2014, 08:29 PM
jrhunkler's Avatar
For the record, the Darbee hasn't arrived yet, and the 500M IS calibrated by D-Nice already. S0 HAAA!
PS - I'm waiting for a 75" OLED to become available at a reasonable price before a change anything else! lol
Old 04-07-2014, 08:51 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Yea, I saw, but the next question to discredit your honest opinion will be how many hours ago was it last calibrated. I'm just heading off the inevitable barrage of questions that are sure to come since you dared to paint the ZT60 in a favorable light.
vinnie97 is offline
Old 04-07-2014, 10:18 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
Low end detail will appear to be more on the ZT due to a built in curve in its software (not to mention its edge dither drive scheme).. It is dynamic and adjusts on the fly. Attempting to do a BT.1886 gamma on these displays only exaggerates what the display's software is already doing. A properly setup ZT will show exactly the same shadow detail as any other display that does not have this type of dynamic software.... Including the 500M.
D-Nice is offline
Old 04-07-2014, 10:42 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
In case there was any doubt (to others), I thumbed you up. That's the type of no-nonsense post that cuts through the noise and explains the above-reported phenomenon I've seen reported on multiple occasions.
vinnie97 is offline
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
I hate to admit to being confused!
AVR: Marantz 7008 Phono: Pro-Ject Debut III Speakers: BW CMC2 + 2xCM9 (front) + 2xCM5 (rear)
TV: Panasonic 65ZT60, Samsung 60F5300
skidawgz is offline
Old 04-08-2014, 05:03 AM
tbird8450's Avatar
Quoted: 44 Post(s)
Liked: 55
Well, I have not found that to be the case in my personal viewing experiences. Anything significantly above about 0.001 fL. leaves something fairly overtly noticeable to be desired except in a relatively bright viewing environment. Below about 0.001 fL, the 'returns' provided by deeper blacks start to diminish substantially. I would think below about 0.0001 fL., there would no longer be any perceivable advantage even in a pitch black viewing environment.
I've had displays that measured .001, .0005 and .0001, and not only were there very noticeable differences in black levels between them, even at .0001 the blacks are still a ways off from truly black. In a dark environment, with low APL content this is very clearly discernible. I also have a display that according to reports should measure around .0017 -.002, and the .0001 display absolutely trounces it in a dark room. I actually think once you get down that low, small differences in MLL can make quite a large difference.
tbird8450 is offline
Old 04-08-2014, 08:50 AM
hhaller's Avatar
Quoted: 72 Post(s)
Liked: 51
Totally agree with this. Hard to convince people until they see it in person, however.
hhaller is offline
Old 04-08-2014, 09:25 AM
DavidHir's Avatar
Quoted: 1706 Post(s)
Liked: 1329
Agreed because the percentage difference between those numbers is large. Most people don't seem to look at that way.
DavidHir is online now
Old 04-08-2014, 11:10 AM
Stu03's Avatar
Quoted: 69 Post(s)
Liked: 169
No
Yea, I saw, but the next question to discredit your honest opinion will be how many hours ago was it last librated. I'm just heading off the inevitable barrage of questions that are sure to come since you dared to paint the ZT60 in a favorable light.
I don't see what the big deal is tbh.
Wouldn't a 141 or 600M have been more apt if going in a size for same size situation.
But for what it's worth - the saturation on the 500M looks to be better - on the weird purple pattern stuff if i was being picky and more detailed/sharper.
It's a 50" and a 60".
:EDIT:
The only closer in size (side by side) comparison was the one image posted in direct daylighting of a 151 (60") Elite and a 65" ZT in recent times by a new ZT owner last year.
It's still bigger by five the zt, including the stand is a bit taller- but nevertheless it's closer in size regardless
Stu03 is offline
Old 04-08-2014, 12:01 PM
lovingdvd's Avatar
Liked: 360
What useful calibration adjustments are in the service menu?
I have a Samsung PN63C8000 and have calibrated decent results without going into the service menu - mainly because I didn't think to look in there for anything useful. Curious what may be of use in there and/or in the F8500 service menus. Thanks!
Old 04-08-2014, 12:53 PM
Chad B's Avatar
Quoted: 496 Post(s)
Liked: 1194
I have not found anything useful except engaging the Cal day and Cal night modes.
Chad B is offline
Old 04-08-2014, 05:54 PM
venus933's Avatar
Quoted: 1331 Post(s)
Liked: 959
Not taking any sides in the arguement but the because in your agreement is not sound. The percentage difference between .00001 and .0001 is huge but I would think the difference between these measurements would be difficult to discern.
LG 55EG9100 (Bedroom TV but temporarily being used as my main TV)
OPPO BDP-103 Universal Disc Player
Vizio SB4051-C0 Soundbar w/wireless Subwoofer
venus933 is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P65vt50 65 Inch Plasma Tv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
