Panasonic ZT60 first review - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 257 Old 04-29-2013, 12:00 PM
chunon's Avatar
Quoted: 2444 Post(s)
Liked: 2195
Originally Posted by Slickman View Post
The numbers...
GT60:
Black ~ .002 cdm
White ~ 93
VT60:
Black ~ .006 cdm
White ~ 68
F8500:
Black ~ .014 cdm
White ~ 109
(Black optimizer off)
ZT60:
Black: ~ .002 cdm
White ~ 53
European version of the ZT60 how is that valid ? They have had brightness caps in previous years
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #92 of 257 Old 04-29-2013, 12:04 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Also, is that VT60 measure of the UK model? The only measurements I know of that have been taken were done by David McKenzie.
vinnie97 is offline
post #93 of 257 Old 04-29-2013, 12:05 PM
agkss's Avatar
Quoted: 21 Post(s)
Liked: 65
It's fixed this year...they have "Panel Brightness" low, medium and High. No more caps. But they have a more restringed energy consumption policies.
agkss is offline
post #94 of 257 Old 04-29-2013, 12:05 PM
Ph8te's Avatar
Quoted: 4697 Post(s)
Liked: 4219
The numbers...
GT60:
Black ~ .002 cdm
White ~ 93
VT60:
Black ~ .006 cdm
White ~ 68
F8500:
Black ~ .014 cdm
White ~ 109
ZT60:
Black: ~ .002 cdm
White ~ 53
Whites will still look white (yes I was the one who posted those numbers) since they are calibrated to meet a certain standard. Waht I believe the ANSi tests is the "peak" white\luminosity while also displaying blacks on teh same screen.....
Ph8te is offline
post #95 of 257 Old 04-29-2013, 12:06 PM
chunon's Avatar
Liked: 2195
Yes as far as I know those are all UK model measurements, not sure about the 8500 but thos numbers came directly from the review I think. Too early imo to make assumptions about the NA models always differences.
65C6 OLED
chunon is offline
post #96 of 257 Old 04-29-2013, 12:07 PM
chunon's Avatar
Liked: 2195
65C6 OLED
chunon is offline
post #97 of 257 Old 04-29-2013, 12:08 PM
Ph8te's Avatar
Liked: 4219
All of those numbers are from the UK versions, as it ahs been discussed those are the only numebrs we have to go on right now in regards to the VT60/5 and the ZT60/5....Until we get NA reviews we wont know how they relate, if at all.....
Yes VT65 I should ahve changed that wink.gif was jsut doing a quick and dirty list....
Ph8te is offline
post #98 of 257 Old 04-29-2013, 12:10 PM
agkss's Avatar
Quoted: 21 Post(s)
Liked: 65
Personally i trust more in David Mackenzie's numbers. AVForums has a little discrepancy between reviewers.
Stu03 likes this.
agkss is offline
post #99 of 257 Old 04-29-2013, 12:10 PM
chunon's Avatar
Liked: 2195
I appreciate the info just disagree with Slickman that whites were compromised, good point there is a diff between white and peak white too different animals
65C6 OLED
chunon is offline
post #100 of 257 Old 04-29-2013, 12:13 PM
-Hitman-'s Avatar
Quoted: 136 Post(s)
Liked: 106
The numbers...
GT60:
Black ~ .002 cdm
White ~ 93
VT60:
Black ~ .006 cdm
White ~ 68
F8500:
Black ~ .014 cdm
White ~ 109
ZT60:
Black: ~ .002 cdm
White ~ 53
Actually the white output figure shown for the ZT above isn't the true output but only when the panel was used in EBU mode, which sets it to a lower light output and crushes blacks, other THX and pro modes tested up to 92~94cd/m2 as per the review!
-Hitman- is online now
post #101 of 257 Old 04-29-2013, 12:14 PM
chunon's Avatar
Liked: 2195
Originally Posted by -Hitman- View Post
Actually the white output figure shown for the ZT above isn't the true output but only when the panel was used in EBU mode, which sets it to a lower light output, other THX and pro modes tested up to 92~94cd/m2 as per the review!
Nice catch what exactly is EBU mode? Same as NA Standard mode ?
65C6 OLED
chunon is offline
post #102 of 257 Old 04-29-2013, 12:18 PM
Ph8te's Avatar
Liked: 4219
That is correct, but if I went with that all of the numbers would be different. I only took the numbers from the posted ANSI test.
The EBU was used for its uniformity, not sure why they wouldnt use the THX or other modes if they produced better values without any ill effects.....
Ph8te is offline
post #103 of 257 Old 04-29-2013, 12:19 PM
-Hitman-'s Avatar
Quoted: 136 Post(s)
Liked: 106
Nice catch what exactly is EBU mode equilivent to NA Standard mode ?
EBU is a new standard, it's a new one on me but from the review he states...
Quote "It also includes a number of preset viewing modes, one of which is exclusive to the P60ZT65 - ‘EBU Default’. This new mode is based on the EBU’s (European Broadcasting Union) guidelines for consumer flat panel displays. These guidelines are designed to ensure that displays produce “images that adequately reflect the creative values intended by their programme director.” We couldn’t agree more. To achieve this EBU certification, the P60ZT65 had to meet certain industry standards for luminance, black level, contrast, gamma, colour and frame rate presentation."
So I would presume the pro modes (not EBU) will be the same across the board.
post #104 of 257 Old 04-29-2013, 12:21 PM
-Hitman-'s Avatar
Quoted: 136 Post(s)
Liked: 106
From the review it just looks like they tried all modes to see how each one performed.
Why they just posted the checker pattern for only EBU mode, I don't know and is misleading.
post #105 of 257 Old 04-29-2013, 12:21 PM
Ph8te's Avatar
Liked: 4219
According to the review its used for uniformity and "studio monitor standards"......
However blacks aren’t everything of course and we found that when it came to brightness the THX Cinema mode hit 94 cd/m2 and the Professional mode reached 92 cd/m2, whilst the EBU mode was only able to reach 56 cd/m2. We assume that the reason the EBU Default mode is less bright is because it uses studio monitor standards, which tend to place more emphasis on consistency rather than brightness when it comes to luminance. By comparison, the KURO measured at 97 cd/m2, which basically matches the P60ZT65, although the Professional mode could go brighter. We measured the Professional mode at 92 cd/m2 using the Mid Panel Luminance setting but if we used the High setting we could get up to 108 cd/m2. However in this setting the blacks were crushed, which again compromised shadow detail, so we would recommend using the Mid setting. Besides a brightness measurement of 94 cd/m2 is still excellent and with a black level of 0.001 cd/m2 that gives an absolutely incredible on/off contrast ratio of 94,000:1! When it came to the ANSI measurements we found that blacks remained superb, measuring between 0.002 and 0.003 cd/m2, but the brightness did drop off, measuring between 51 and 55 cd/m2. However the resulting ANSI contrast ratio was a superb 20,333:1 and this remarkable dynamic range was easy to see when watching actual content. Interestingly there was a similar drop off in brightness when measuring the ANSI numbers on the KURO and again, as a point of comparison, it produced an on/off contrast ratio of 48,500:1 and an ANSI contrast ratio of 16,676:1. It might have taken Panasonic four years but in the P60ZT65 they have finally produced a plasma that can lay to rest the ghost of KURO.
Ph8te is offline
post #106 of 257 Old 04-29-2013, 12:22 PM
chunon's Avatar
Liked: 2195
65C6 OLED
chunon is offline
post #107 of 257 Old 04-29-2013, 12:23 PM
Slickman's Avatar
Quoted: 136 Post(s)
Liked: 92
I went ahead and added the the checkerboard numbers up from the reviews and averaged them all out. I also added an adjusted F8500 measurement just based on Kevin's review which showed that the black level was 60% of what it was with black optimizer off (.005 to .003 FTL). So I multiplied their number by 60% to get a rough estimate of the Samsung with black optimizer on. I also threw in the THX Cinema mode white for the ZT60 as well.
GT60:
Black ~ .003375 cdm
White ~ 93.625 cdm
VT60:
Black ~ .007 cdm
White ~ 90.925 cdm
F8500:
Black ~ .014 cdm (Black Optimizer off)
White ~ 109.5 cdm
Adjusted Black with Optimizer on = 0.0084 cdm ANSI
ZT60:
Black: ~ .002625 cdm
White ~ 53.375 cdm
THX Cinema mode white ~ 94
agkss likes this.
Slickman is offline
post #108 of 257 Old 04-29-2013, 12:25 PM
agkss's Avatar
Quoted: 21 Post(s)
Liked: 65
i ask mark hodgkinson in another forum that (pic of ANSI Checkerboard)...Stephen Withers is come to florida...but they will update the review if they find other results.
agkss is offline
post #109 of 257 Old 04-29-2013, 12:25 PM
Ph8te's Avatar
Liked: 4219
There is a difference and they are going between ANSI and On\Off fluidly in the review:
They dont say what mode it dropped off for only that it dropped off when ANSI was taken...
Ph8te is offline
post #110 of 257 Old 04-29-2013, 12:28 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Next question would be what's the full screen black level in THX mode?
vinnie97 is offline
post #111 of 257 Old 04-29-2013, 12:31 PM
fluxo's Avatar
Quoted: 410 Post(s)
Liked: 264
Are we sure about that? Does it explicitly state in the review that EBU mode was used for the ANSI test?
I realize it does say that EBU mode is capped lower than other modes, so it's certainly worth asking whether that mode was used. But then, why use a mode with lower peak light output that crushes blacks?
Regarding EU power regs: the allowable wattage limits scale with panel size (in proportion to panel area). So a 60" panel is allowed to use 44% more power (1.44x) than a 50" panel (= (60/50)^2 ). In any case, the larger 65" VT had brighter whites in the ANSI test.
In case it helps, I will convert to fL. The ANSI whites for the ZT measured at 15.5 fL. So, 9-12 fL or so for a full field 100% stimulus white pattern?
fluxo is offline
post #112 of 257 Old 04-29-2013, 12:37 PM
Slickman's Avatar
Quoted: 136 Post(s)
Liked: 92
So the ZT60 is roughly 0.0008 fL on the checkerboard pattern.
Slickman is offline
post #113 of 257 Old 04-29-2013, 12:38 PM
-Hitman-'s Avatar
Quoted: 136 Post(s)
Liked: 106
Agree and so I have posted a question asking him to give more detail on this!
post #114 of 257 Old 04-29-2013, 12:38 PM
Ph8te's Avatar
Liked: 4219
we measured the black level on the P60ZT65 at 0.001 cd/m2 in all three primary viewing modes (THX Cinema, EBU and Professional)
Ph8te is offline
post #115 of 257 Old 04-29-2013, 12:43 PM
DavidHir's Avatar
Quoted: 1913 Post(s)
Liked: 1559
Sounds great. Now I am really curious how the ZT and VT (and F8500) look next to each other properly calibrated....cannot wait until the Shootout to get impressions.
DavidHir is online now
post #116 of 257 Old 04-29-2013, 12:45 PM
-Hitman-'s Avatar
Quoted: 136 Post(s)
Liked: 106
I have asked for clarification, all we have is
Quote
"we found that when it came to brightness the THX Cinema mode hit 94 cd/m2 and the Professional mode reached 92 cd/m2, whilst the EBU mode was only able to reach 56 cd/m2. We assume that the reason the EBU Default mode is less bright is because it uses studio monitor standards, which tend to place more emphasis on consistency rather than brightness when it comes to luminance"
they don't specifically state which mode the ANSI test was taken but does look like EBU mode as the figures match.
post #117 of 257 Old 04-29-2013, 12:46 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Thanks for weeding out the details for me. I am skimming a little *too* much (time constraints, bleh).
vinnie97 is offline
post #118 of 257 Old 04-29-2013, 12:51 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Quote
The ANSI ratio should surely increase in any other mode then.
vinnie97 is offline
post #119 of 257 Old 04-29-2013, 12:57 PM
Ph8te's Avatar
Liked: 4219
The on\off aka dynamic does yes, but the checkerboard is what people are asking about......
No oe is saying that it isnt a great contrast ratio because it is, the ANSI white peak in the ANSI checkerboard though seems "off" at least to me when compared to the other sets.......
Ph8te is offline
post #120 of 257 Old 04-29-2013, 12:58 PM
agkss's Avatar
Quoted: 21 Post(s)
Liked: 65
If it's not...like mark said to me: it's alright for some!
agkss is offline
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
