Panasonic ZT60 first review - Page 9 - AVS Forum | Home Theater Discussions And Reviews
post #241 of 257 Old 06-19-2013, 09:09 AM
Stu03's Avatar
Quoted: 69 Post(s)
Liked: 169
What's the worst that can happen using slides ?
Stu03 is offline
post #242 of 257 Old 06-19-2013, 10:03 AM
repete66211's Avatar
Quoted: 131 Post(s)
Liked: 288
*shrug*
repete66211 is offline
post #243 of 257 Old 06-19-2013, 10:29 AM
Dust Bubble's Avatar
Well I can tell you in the case of my Panasonic V10 using the break-in slides was a mistake because we all found out later the more usage of the set the more the black level faded!!
Dust Bubble is offline
post #244 of 257 Old 06-19-2013, 02:05 PM
chunon's Avatar
Quoted: 2464 Post(s)
Liked: 2208
That's relevant how ?
65C6 OLED/65 A1E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #245 of 257 Old 06-19-2013, 03:13 PM
Ilovetightbass's Avatar
Ugh. Just watching the tv black levels with fade. What's your point?
Ilovetightbass is offline
post #246 of 257 Old 06-19-2013, 03:22 PM
chunon's Avatar
Liked: 2208
My point is how is some comment about a 2009 set relevant to a 2013 model ?
65C6 OLED/65 A1E
chunon is offline
post #247 of 257 Old 06-19-2013, 05:08 PM
Quoted: 131 Post(s)
Liked: 288
It is worth noting that running slides has a measurable reduction in the life of a TV. The benefits, if there are any besides killing time, are less measurable.
post #248 of 257 Old 06-19-2013, 05:28 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
300 hours sapped from a 100,000 hour predicted life? Tempest in a teacup, that. biggrin.gif One benefit I can think of is stress testing. If the TV has problematic components, you are more likely to make them fail within the warranty period by running said slides.
vinnie97 is offline
post #249 of 257 Old 06-19-2013, 05:37 PM
Quoted: 131 Post(s)
Liked: 288
100,000 estimated. And it doesn't just blow up after hour 100,000, it dims over time. Half life and all that. A plasma stars to decay the second you turn it on. Breaking in the tv probably won't have a negative impact but it is wear & tear. Every hour you run slides is one less hour you'll be able to watch it. Again, not a big deal, but what's the benefit of slides exactly?
post #250 of 257 Old 06-19-2013, 05:42 PM
chunon's Avatar
Liked: 2208
IMO there isn't one outside prepping for dnice s settings maybe to accumulate hours unattended that's the extent of it
65C6 OLED/65 A1E
chunon is offline
post #251 of 257 Old 06-19-2013, 07:36 PM
Blacks r gonna fade regardless. Wish it wasn't so but it's gonna happen. 2008 or 2013. Doesn't matter. Nature of the beast.
post #252 of 257 Old 06-19-2013, 07:51 PM
Quoted: 131 Post(s)
Liked: 288
But you don't have to prep for D-Nice's settings. You can set your tv to those settings right out of the box and let it grow into them. The only time you should use slides is if you're prepping for an actual calibration.
post #253 of 257 Old 06-19-2013, 07:58 PM
chunon's Avatar
Liked: 2208
To follow his procedure exactly you need to run the slides
Slides are not required to prep for a calibration you can run them to age the panel faster but there is no requirement
65C6 OLED/65 A1E
chunon is offline
post #254 of 257 Old 06-19-2013, 08:42 PM
chunon's Avatar
Liked: 2208
And your proof of this ?
65C6 OLED/65 A1E
chunon is offline
post #255 of 257 Old 06-19-2013, 09:11 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
I believe the half-life of the modern panel is actually 100,000 hours. I already mentioned at least one benefit in my last post. Anything prone to failure will be given a useful stress test.
vinnie97 is offline
post #256 of 257 Old 06-20-2013, 07:59 AM
The Panasonic V10 that I am talking about had excessive fading that occurred over a short period of time that was in fact easily visible to the naked eye. It was even posted and document on multiple sites including C-net not to mention a dedicated thread right here on AVS. And Panasonic themselves released statements regarding a process or some type of software that made changes to the panel at certain increments of time. So basically all I was saying is I wished I never ran any break-in slides due to that fact I was making my panel visibly worse in an extraordinarily sped up fashion.
post #257 of 257 Old 06-20-2013, 09:43 AM
Stu03's Avatar
Quoted: 69 Post(s)
Liked: 169
Fading... Is that the same from the European Panasonics of that time - the MLL started to rise after X amount of hours. There was a huge uproar - no wonder. Voltage/ageing algorithms must have gone screwy eek.gif
Stu03 is offline
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
