Viera link app "feature not available" on ST60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-02-2013, 06:03 AM - Thread Starter
ldhiii's Avatar
I have been trying to go to this app so that I can turn my st60's speakers off. How do I get this feature turned on?
ldhiii is offline
post #2 of 5 Old 05-02-2013, 06:43 AM
chunon's Avatar
Quoted: 2444 Post(s)
Liked: 2195
Is your TV connected thru HDMI ?
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #3 of 5 Old 05-02-2013, 03:12 PM
smeg36's Avatar
Quoted: 109 Post(s)
Liked: 49
Viera Link is Panasonic's branding for HDMI-CEC. I can't access this setting either because I have HDMI-CEC turned off on my receiver (a Denon, it's called HDMI Control). When I turn that on, I can then access the settings for Viera Link, and set it to change the receiver volume instead of the TV volume when I press the volume button. So you need to have a receiver that supports HDMI-CEC, and have it turned on, in order to access Viera Link.
smeg36 is offline
post #4 of 5 Old 05-03-2013, 12:53 PM - Thread Starter
ldhiii's Avatar
My tv is connect to my Directv box via HDMI. I then have my tv connected to my sound bar via the digital audio out port on the back of the tv. I also have my Panasonic blue ray player connected via HDMI. When I click on the viera link app, all I see is "viera link control" with "player beside it. When I click on this it controls my blue ray player.
ldhiii is offline
post #5 of 5 Old 09-07-2013, 06:20 PM
Jp Kalman's Avatar
After purchasing a pans 50 st 60 I also purchased a sonos play bar to accompany it. Sadly it is impossible to disable the internal speakers on any panasonic tv via viera link UNLESS you have a panasonic HTS.
I am a panasonic retailer and a sonos retailer and have been in contact with both companies direct and there is no work around. Sorry guys. Blame Panasonic
Jp Kalman is offline
Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv
