Soundbar Recommendations Please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-03-2013, 06:44 AM - Thread Starter
AuralSex's Avatar
Quoted: 28 Post(s)
Liked: 24
I'm looking for a soundbar that will fit in my TV stand under the TV. It will sit under the Fios DVR and blu ray player so it has to be reasonably deep (at least 10" I would think) to support these two pieces of equipment. I'm hoping that there's a way to disable the TV's built-in speakers and use the TV remote to adjust the volume of the soundbar so I don't have to fiddle with another dedicated remote. Oh, also I'm assuming that the soundbar is self powered and doesn't need its own receiver or amplifier to power it. Anything up to 24"-28" wide will be OK.
I have the VT60 so if anyone can walk me through how to hook this up I'd appreciate it.
Any thoughts/recommendations?
I feel strongly both ways!
AuralSex is offline
post #2 of 2 Old 05-03-2013, 07:50 AM
crn3371's Avatar
Quoted: 241 Post(s)
Liked: 193
You're probably better off posting in the soundbar forum. The only one that comes to mind is the ZVOX, which is designed to have the tv sit on top of it. I suggest you rethink your positioning as you're going to have a hard time finding soundbars meeting your size requirements, and more importantly, your positioning is putting it WAY too low.
crn3371 is offline
