PNxxF5500 owners thread - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #781 of 795 Old 03-08-2015, 10:29 AM
ambesolman's Avatar
Quoted: 1100 Post(s)
Liked: 921
Originally Posted by direwolf2009 View Post
Thanks very much for your reply.
Quick question. The retailer is offering extended coverage, beyond the first year. The first year is with Samsung, the others with the retailer. Do you think it's worth the extra expense?
In terms of wallmounting brackets, is there a brand you recommend? Something that articulates isn't really necessary, but if you have any suggestions. Our wall would need to support the bracket + the panel, so I'm guessing the mount has to be fairly robust.
I haven't had any issues with the 5500 (fingers crossed), but I had the notorious pink banding issue with my c7000. We got an extended warranty and very glad we did so since the panel was replaced twice before they finally gave us the 5500. Out of warranty, the panel is about $1k for a replacement so a few hundred dollars for the warranty was worth it.
As far as mounts go, I did a live online chat with monoprice. Gave them the model # of my tv and they recommended a mount. Worked out great!
Sent using Tapatalk since the mobile version is still
ambesolman is online now
post #782 of 795 Old 03-09-2015, 04:43 AM
direwolf2009's Avatar
Thanks for the advice.
Thinking about picking this up today, but had a few more questions:
1.Other than size, purely from a PQ perspective, how does this set differ from the PN42C450 or B450?
2. I've read a lot about this pentile display matrix. Is this actually a big deal and does it impact image quality? It's not clear if this is actually an issue or not.
3. What is the latest firmware for the panel? According to Samsung Canada it is: VERSION : 2206.3 / 2015.02.04
4. For gaming, how does this set perform?
I think the concern is while it may be bigger, we may be losing something.
Thanks in advance.
DW
direwolf2009 is offline
post #783 of 795 Old 03-09-2015, 11:52 AM
ambesolman's Avatar
Liked: 921
Thanks in advance.
DW
1. I had a c550 briefly and the c7000 I traded it for was much better. The 5500 is as good if not better than the c7000 IMO
2. I don't notice it unless I'm within a couple of feet of it, great pic from normal viewing distance.
3. Don't know
4. Works great with my PS3
post #784 of 795 Old 03-10-2015, 05:40 AM
Many thanks.
Picked up the set. Took a bit of setting up. Used SuperLeo's settings, but lowered Contrast to 70 and Cell Light to 12 to start.
Very impressed. Don't notice the pentile issue, but there is a slight buzz from the set, but with the volume up, it's hardly noticeable. The stand is annoying and a silly design, compared to previous Samsung panels. Thought there would be enough depth on the shelf (at 15"), but the legs in the rear stick out ever so slightly, resting only on the shelf's support structure. Will get a board that is longer than the shelf and sit the the TV on that.
Had to disable most SMART features, but there is one I can't figure out. Periodically, a notification pops up that some Samsung feature is ending. Very annoying.
Is there any way to disable notifications entirely?
post #785 of 795 Old 03-30-2015, 10:11 AM
Liked: 0
Originally Posted by VidfreekCD View Post
I picked up this TV at the end of August last year, its been great so far, I have this placed in my basement family room so glare really isnt an issue for me. But I've noticed that the set has some issues turning off or on sometimes. Has anyone else had this problem? I didnt want to come through 25 pages of stuff, but sometimes when I turn it on it just sits black for quite some time, pushing the power button again just makes the red dot on the TV flicker a bunch and eventually it will turn on after that, takes a bit sometimes 3-5 minutes but it doesnt happen all the time. Sometimes it does the same thing when shutting off as well. No idea what the problem is there but wanted to see if anyone else has seen this before.
Were you able to fix this issue? This happened to my set the first year I have my TV and warranty covered the repair. After another year, it happened again and of course, it is now out of warranty. Hoping to be able to fix the TV with minimal/no cost. Please help.
mykesy@msn.com is offline
post #786 of 795 Old 03-30-2015, 11:32 AM
VidfreekCD's Avatar
For a while now since I posted it's stopped doing that, there has been a couple of firmware updates I believe and it hasn't happened in quite some time, so let's hope it's been fixed :blush:
VidfreekCD is offline
post #787 of 795 Old 03-31-2015, 02:18 PM
Liked: 0
Glad it worked out for you. Unfortunately for me, the screen stopped working altogether so it is impossible to get the firmware updated. I sent it to the shop but it has been a week and Samsung is still scratching their heads on this one. Wish me luck that they can still get it fixed and can still get a couple of years out of it.
post #788 of 795 Old 05-24-2015, 09:21 AM
azcatsfan15's Avatar
Quoted: 43 Post(s)
Hey everyone. I just bought this TV and have a couple of questions:
#1 I need to know how one can check the hours on the TV?
#2 What settings to get the best possible picture while on Movie mode?
Thank you
azcatsfan15 is offline
post #789 of 795 Old 11-06-2015, 04:39 PM
Quoted: 17 Post(s)
Liked: 2
On early posts in this tread people were having brightness variations (flickers) wile watching hockey. As this issue been resolved with a firmware since then? Also, how is image retention with this set? Is it super sensitive like a Panasonic VT60 or really good like the f8500? How loud is the buzzing, similar to VT60 or like the "laser" buzz of he f8500?
I tried the F8500 but the buzz was just too loud. Got it exchanged for a VT60 (store demo) but it's so sensitive to IR that just a few second of a still menu is enough to leave trace for a few minutes. I have the possibility to buy a new 55" but wont be allowed another exchange it if I do not like it. Its either the last plasma model they have or I take a chance with a LCD and hope for good uniformity.
Thormind is offline
post #790 of 795 Old 11-06-2015, 07:04 PM
ambesolman's Avatar
Liked: 921
No IR or buzz from mine
post #791 of 795 Old 11-06-2015, 09:09 PM
Quoted: 17 Post(s)
Liked: 2
Also forgot ask, in the store the blacks look grey compared to other tvs on display. What can I expect in this room during daytime:
Walls are painted dark gray. There is one big window located on one side of the tv. The window is on the side of the house where there is no direct sunlight. I can close the vertical blinds halfway (the half closest to the tv) but i do like to have the half close to my viewpoint opened. I do not care that much about reflection. My computer screen is reflective and it does not bother me. I do not mind the blacks being darker during nighttime but i would like them look somewhat... black... during daytime..
I also discovere with the VT60 that i am sensitive to phosphor lag (or trail?). On the VT it's the worst on yellow colors and on whites, where i clearly see traces of red if my eyes move around a still object or a high contrast object move on a darker screen. Did not notice anything like that with the F8500. Is it the same with the F5500? Is that problem unique to Panasonic plasmas?
Thormind is offline
post #792 of 795 Old 05-11-2016, 10:17 AM
Liked: 0
Originally Posted by silencer51 View Post
Here's a shot of a fully white screen taken in the dark, the upper right corner has a visible pink tint to it.
Can someone else post a photo of their f5500 showing a fullscreen white image?
Long time lurker, finally made an account. I purchased this TV yesterday and after in-depth calibration, I noticed this as well. I could not for the life of me get rid of that pink banding around the entire screen.
iflookzkill is offline
post #793 of 795 Old 09-29-2017, 10:07 PM
dirk1843's Avatar
Quoted: 22 Post(s)
Forgive the revival of an old thread, but I have some questions that maybe a member is just waiting to answer!
A few of the settings for the model 64" specifically I would like to know more about what they actually do. Way back when in the bad old RPTV days I knew my Toshiba settings forwards and backwards. I have had this set for several years and for one reason or another never spent much time in the picture settings.
1. Do the preset modes change anything other than just a preset curve? In the aforementioned RPTV days selecting MOVIE turned off a setting (SVM) that was not accessible from any other menu.
2. Dynamic Contrast, what does it actually do?? I have read the Samsung propaganda but would like to know what it actually does.
3. Black Tone, same request as #2 .
4. RGB Only mode, I see it limits the color to the base colors, for calibration I assume?
5. Color Space has two choices: native and auto. What effect does each have?
6. Digital Clean View. I was able to find some info on this while searching, seems to be designed to reduce digital noise in native digital sources. Is this correct? Any downsides?
7. MPEG noise filter. Another I was able to find info on if it is correct. Was designed to reduce artifacts that show up in analog sources. Probably almost irrelevant for most people.
8. Film Mode, I would imagine has to do with the way interlaced sources are converted to progressive. If so which settings are geared toward which sources?
9. Black Optimizer, I would think this is similar to a preset mode that makes changes to Contrast and Brightness (and others?). Any benefits or downsides?
Thanks to all,
dirk1843 is offline
post #794 of 795 Old 09-30-2017, 09:31 AM
Quoted: 269 Post(s)
Liked: 115
Thanks to all,
I'll try. I have a PNC63C7000 so have some familiarity with Samsung Plasma.
I'm not aware of any presets that turn anything on that can't be turned off. When calibrating, find the most accurate mode in it's default mode and calibrate that mode.
Automatically makes darks areas darker and lighter scenes lighter. Crushes blacks and whites. Should be left off.
Attempts to make darks look blacker. Crushes blacks. Leave off.
Yes for calibration. It is better to calibrate a 10pt white balance with a 10 point pattern. 0%, 10%, 20% etc.
Native is untouched. No artificial processing. Use native.
A noise filter. Just leave it off.
Just leave it off.
Used for smoothing 480i or 1080i material that use 3:2 pull down. Leave off.
Stretches the brightest whites to make more pop. Dark room setting is best.
ambesolman likes this.
Test Ickles is offline
post #795 of 795 Old 10-04-2017, 06:00 AM
ambesolman's Avatar
Liked: 921
Originally Posted by Test Ickles View Post
I'll try. I have a PNC63C7000 so have some familiarity with Samsung Plasma.[/COLOR]
Best. Screen name. Ever.
Sent using Tapatalk cuz the mobile version is still
Samsung Pn60f5500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Un46f6300 46 Inch Slim Smart Led Hdtv , Samsung Un46f6400 46 Inch 3d Slim Smart Led Hdtv , Samsung Un55f6800 55 Class 1080p Smart Tv 3d Slim Led Hdtv With 3d Glasses , Samsung Pn60e8000 60 Inch Ultra Slim Plasma 3d Hdtv
