PNxxF5500 owners thread - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1 of 792 Old 05-04-2013, 01:51 PM - Thread Starter
bargervais's Avatar
Quoted: 1555 Post(s)
Liked: 923
i just bought a PN51F5500 and i would like feed back on what issues if any that you are having. i started this in hopes of having a thread for the F5500
when i first got my PN51F5500 I was torn didn't even know if i was going to keep it
now we just had a firmware update.
1.This firmware is for TV Model(s): LED F5500/F6300/F6350/F6400/F6800/F7050/F7010, PDP F5500
2.The version is 1102.1
3.This firmware update will improve the following:
- Improves picture quality.
- Resolves compatibility issue with Fitness Game Bike
i must say that the improvement in picture quality has solidified my choice in buying this PN51F5500 i know there will be more updates.
so here i am I have a PN60E8000 and a PN51F5500
DEN Atmos Samsung UN65KS8000 Roku Ultra Onkyo TX-NR 747 5.2.2 UHD audio. Polk Audio OWM3 Speakers / top middle on Ceiling / 300MGB Spectrum / Samsung UBD-K8500 Blu-Ray Player / 26 UHD Blu-Rays Living Room Atmos Samsung PN60E8000+SEK2000 / Onkyo TX-NR 1030 7.2.4 /Onkyo M-5010 Amplifier for top middle/ 300MGB Spectrum / Panasonic 3D blu-ray Bic Acoustech speakers, MICCA M-8S FH on wall /TM in ceiling speakers / 2 Bic F12 subs. BEDROOM Samsung 55JS8500 using tv speakers for now
bargervais is offline
post #2 of 792 Old 05-06-2013, 02:09 AM
netvlada's Avatar
How you compare black level in light room on same material side by side f5500 and e8000.
I was in shop and watch side by side e8000 and f5000 not 5500 and 5000 was gray not black.
netvlada is offline
post #3 of 792 Old 05-06-2013, 11:41 AM
pioneer 1985's Avatar
hi,
can you comment on black levels, image retention, brightness pops/hocky pops and input lag for gaming if you do on this tv. I am in the uk and their is not much info about for this tv.
last year I had many st50 TV's with banding/uniformity issues and before that had Samsung d series which had the brightness/hocky pops. I am just looking for a cheap decent performing tv without the issues mentioned above so I am looking at this tv.
pioneer 1985 is offline
post #4 of 792 Old 05-06-2013, 11:44 AM
Ph8te's Avatar
Quoted: 4543 Post(s)
Liked: 3972
Originally Posted by pioneer 1985 View Post
hi,
if you are in the Uh checkout avforums.com there is a dedicated thread for the UK version of this set there smile.gif
Ph8te is offline
post #5 of 792 Old 05-06-2013, 12:04 PM
yes I am aware of that but that is for the 60inch version and going by previous years there has been performance differences between the 51's and bigger screens ie: black levels and ir so it would be nice to hear comments from you guys on the 51inch version:)
post #6 of 792 Old 05-06-2013, 12:19 PM
Ph8te's Avatar
Liked: 3972
If you take a look in that thread although named for the 60" I believe all versions are being discussed....Not sure well get much stats on the black levels as I ahvent seen one measured, the best youll do until someone calibrates or has thier set calibrated is opinions wink.gif
Ph8te is offline
post #7 of 792 Old 05-06-2013, 12:35 PM - Thread Starter
bargervais's Avatar
Liked: 923
now this is just my opinion not gospel i did not put a meter to either one but to my eye the blacks appear nice and black on both
the blacks on my F5500 are Black and i mean black they are not Gray now if the sun is shinning right on the TV no TV can fight through that even my E8000 hates direct sun and just before sunset this happens.
the E8000 has the pro panel and the F5500 just has the real black panel if i were to move them side by side which i won't do but what i can do is put Avatar on each set and go back and forth to see which one in my opinion does better or if they are to close for me to tell the diff.
I'll have to do it at night because the viewing enviroment on room is brighter then the other
I do find that the E8000 holds up a little better in a bright room then the 5500 they are diff panels and the 5500 is more refective IMO
post #8 of 792 Old 05-06-2013, 12:49 PM - Thread Starter
bargervais's Avatar
Liked: 923
hi,
I was worried about Image retention as well i just replaced a C7000 and it was bad when i watched baseball those static images would take a while to fade away But i'm happy to say this 51F5500 is not bad i watched two game one on ESPN then on MLB both with tickers and scores and after i didn't see any signs of IR if i would have done that with my old C7000 i would have to swipe the TV for hours.
i did watch a hockey game and didn't notice anything popping but i was in Movie Mode with warm 2 which make the ice not so white maybe i'll try in standard mode with cool temp and see what happens.
i'm not a real hockey person more Baseball and Football.
post #9 of 792 Old 05-06-2013, 01:55 PM
thanks for reply,
sounds promising on the IR/BRIGHTNESS POP front do you do any gaming on the tv?
post #10 of 792 Old 05-06-2013, 03:36 PM - Thread Starter
bargervais's Avatar
Liked: 923
thanks for reply,
i don't do any gaming
post #11 of 792 Old 05-06-2013, 03:56 PM - Thread Starter
bargervais's Avatar
Liked: 923
here are a couple pictures i took with my cell phone please understand that the flash tends to affect the blacks and color and i don't have a steady hand as you can see it's a little blurry
20130505_004205.jpg 1455k .jpg file
20130506_173919.jpg 1532k .jpg file
the color is good and so are the black i'm very surprised for a mid teir TV
And this one i took last
20130505_002353.jpg 1951k .jpg file night
ID:	69191   Click image for larger version
ID:	69192   Click image for larger version
post #12 of 792 Old 05-06-2013, 05:57 PM
silvervulcan's Avatar
I have a Samsung PN60F5500 for a couple of days, ive noticed some dimming on CBCHD hockey here in Canada. I tried watching TSNHD (another hockey game) and didnt noticing anything. So maybe it is just the one channel? I find it suspicious though and very annoying as it constantly keeps dimming on its own, and all the eco and energy saving features are off. Seems to only do it on hockey (white ice)
silvervulcan is offline
post #13 of 792 Old 05-06-2013, 06:42 PM - Thread Starter
bargervais's Avatar
Liked: 923
i just changed to NHL NETWORK Boston and toronto i do see some flashing i changed to standard mode not sure if it's the tv or the feed i see camera flashes but there is some pops going on as well. PN51F5500
post #14 of 792 Old 05-06-2013, 06:47 PM
Thanks for confirming Bargervais, I have the same problem on the 60 inch model. I also cant figure out if it is the feed or the TV. Seems to only be the toronto boston game. I was watching the Washington+New York hockey game on HD and I don't see it as bad as the Boston Toronto Game, which I suspect it would be the feed.There seems to be some quick flashing on the Washington New York Game, but watching the white ice looking for it maybe my eyes are playing tricks on me. I havnt noticed this flashing/dimming on any other stations or when watching a movie.
post #15 of 792 Old 05-06-2013, 06:54 PM - Thread Starter
bargervais's Avatar
Liked: 923
HOW IS THE color and the Blacks have you updated your firmware
post #16 of 792 Old 05-06-2013, 06:58 PM
I only have Firmware 1102, It doesnt have the ".1". The TV says I have the latest firmware version when I try to update it. There wasnt an update when I took it out of the box (had it 2-days). Is there a more recent update? If so it's not showing up for me.
post #17 of 792 Old 05-06-2013, 07:02 PM - Thread Starter
bargervais's Avatar
Liked: 923
i also have not seen any flashing except that Toronto Boston game i was watching the rays and the blue jays and i have not noticed any flashing at all it just seems to be hockey????
post #18 of 792 Old 05-06-2013, 07:08 PM - Thread Starter
bargervais's Avatar
Liked: 923
i think thats the same one and your up to date if you go to the menu go to support then self diagnosis then picture test then ok then yes then you will see software version
T-MST12AKUC-1102.1
post #19 of 792 Old 05-06-2013, 07:15 PM
i think thats the same one if you go to the menu go to support then self diagnosis then picture test then ok then yes then you will see software version
T-MST12AKUC-1102.1
Seems to be only hockey, well that one hockey game anyway (Toronto and Boston). I was also watching Toronto and Rays, and didnt see anything suspicious there
Yes I have the same software version as you. I can't comment on any changes as I've always had this software version. Blacks and colours are impressive to me, especially when watching Blu-Ray. Avatar in 3D was beautiful. I am going to try the settings you posted, as I have been unable to find any others online. I find standard mode is much better than movie mode. Did you use a calibration disc to get your settings or just eye balled it?
post #20 of 792 Old 05-06-2013, 07:28 PM - Thread Starter
bargervais's Avatar
Liked: 923
i posted those after watching a baseball game on MLB i have changed a little since then but see how you like them i was just messing around i have not gotten this thing calibrated and i don't think i will spend the money on this TV the color and blacks seem to me very good right out of the box right now i have it.
Standard picture mode
cell light 16
contrast 90
brightness 47
sharpness 0
color 50
tint 50/50
dynamic contrast off
black tone darker
flesh tone 0
color spacing native
white balance all 25's
gamma 0
motion off
color tone warm 1
every thing else auto
post #21 of 792 Old 05-07-2013, 09:38 AM
jae3cpamd's Avatar
cell light 16
contrast 90
brightness 47
sharpness 0
color 50
tint 50/50
black tone darker
flesh tone 0
gamma 0
motion off
color tone warm 1
Does this Tv have the frame interpolation feature also known as motion flow? I thought that feature was only on the F8500 series!
jae3cpamd is offline
post #22 of 792 Old 05-07-2013, 11:34 AM - Thread Starter
bargervais's Avatar
Liked: 923
it does have motion lighting i don''t see motion flow but i think motion lighting may only be available i some picture modes i have mine in standard mode and it available but when i watch a movie channel i switch to movie mode and i think it's grayed out.i'm not at home so i need to check that once i get home
post #23 of 792 Old 05-07-2013, 01:21 PM
Cuda1169's Avatar
Quoted: 24 Post(s)
Liked: 73
It is probably the auto brightness limiter (ABL) kicking in. This is common to all plasmas and this type of brightness fluctuations is visble on very bright white scenes, such as hockey ice. There's a lot of info on this site and the internet about ABL. Some plasmas do better than others when handling ABL.
Cuda1169 is offline
post #24 of 792 Old 05-07-2013, 06:09 PM
jae3cpamd's Avatar
The feature im looking for is called MJC or motion judder canceller. Its under the advanced settingin in the F8500 series.
post #25 of 792 Old 05-07-2013, 07:52 PM
Jroc26's Avatar
I just bought this set last night and switching between 2 different hockey games I'm getting flickering, auto dimming and brightness pops. I've tried a bunch of different picture settings and made sure all the Eco features are off and it's still doing it, it is very VERY noticeable, it's too bad because I think it's a fantastic tv otherwise.
If this isn't something that can be resolved its going back.
Edit: mine is the pn60f5500
Jroc26 is offline
post #26 of 792 Old 05-07-2013, 08:00 PM
Hey Jroc26, I have the same thing going on with mine(PN60F5500). I've noticed it on the hockey also, with the screen dimming, then a few seconds, then dimming again, then returning. It is very distracting and annoying. I havnt noticed it on any other content or blu ray, but it would be difficult to reproduce as it seems to be with high levels of white like the ice surface.
post #27 of 792 Old 05-07-2013, 08:06 PM
Jroc26's Avatar
I agree, I as well am only getting it watching hockey, but to me it's just completely unacceptable. I just took a video with my phone and uploaded it to youtube, the link is here, http://www.youtube.com/watch?v=nJClrJ6o7TE.
It was only flickering in the video that I took not doing the bright to dark to bright thing, but I find it so distracting that I don't even want to watch it.
Jroc26 is offline
post #28 of 792 Old 05-07-2013, 08:26 PM
Ya mine does the same, not as much flickering, but mine the whole screen dims more grey/darker, and then brightens again, dims, over and over and over. I contacted Samsung chat help and that was useless, you get the runaround about there being no reported problems, well no **** Im reporting one now. Not sure if it is the video feed for the hockey or the TV. I;d like to try and test it out on blu ray and seee if it does the same but I dont own any movies with high white scenes.
post #29 of 792 Old 05-07-2013, 08:28 PM - Thread Starter
bargervais's Avatar
Liked: 923
check out the F8500 thread there was also fluctuations and pops they just had a firmware update that eliminated the pops.
lets hope samsung does the same with the F5500
post #30 of 792 Old 05-07-2013, 08:32 PM
Jroc26's Avatar
I'll see if I have anything that does and I'll try it and report back if I have the same issues. I will also be contacting Samsung about it tomorrow.
I doubt it's a source issue, I'm using the same shaw gateway box and HDMI cable I was running on my last tv with no issues what so ever, my bedroom LCD watching the same game isn't having any issues at all either.
Jroc26 is offline
Samsung Pn60f5500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Un46f6300 46 Inch Slim Smart Led Hdtv , Samsung Un46f6400 46 Inch 3d Slim Smart Led Hdtv , Samsung Un55f6800 55 Class 1080p Smart Tv 3d Slim Led Hdtv With 3d Glasses , Samsung Pn60e8000 60 Inch Ultra Slim Plasma 3d Hdtv
