Panasonic G20/G25 flickering on static images - AVS Forum | Home Theater Discussions And Reviews
Old 05-05-2013, 05:51 PM - Thread Starter
johnnyz86's Avatar
Does anyone else have flickering on certain parts of static images?
I get very noticeable flickering on the background surrounding the items on the bottom left here at full 1:1 resolution on my computer (which doesn't show up when connecting it to another display with the same cable):
http://eruditass.minus.com/mZtrf28hY
When zooming in/out with Chrome, the effect is much less flickery and more like the plasma grainy noise. The effect is changes with screen brightness.
I tried taking a video but it looked horrible with the rolling shutter.
Does anyone else get flickering on their G20/G25 on those images/websites?
johnnyz86 is offline
Old 05-09-2013, 07:40 PM - Thread Starter
johnnyz86's Avatar
Any replies would be helpful, SquareTrade is trying to say it's my video card (Galaxy GTX 460).
Old 05-10-2013, 06:47 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
I have encountered this when selecting Cinema mode instead of Standard mode on older Panasonic plasmas such as TH-46PZ80B. In particular, the scene in "Contact" in young Ellie's bedroom, the walls with the subtle patterning strobe quite badly; I have a feeling this is a visual artefact of the dithering that our eyes are particularly sensitive to. I notice that the effect is considerably reduced on the Normal preset, but as a result, the panel dithers more (Cinema seems to drop the field rate and give it more bit depth per field.)
It is very unlikely to be the video card. A video card deals with digital signals almost entirely nowadays, presuming you are using HDMI, DVI or DisplayPort, and it cannot cause the effect you complain about.
tom669 is offline
