Panasonic 55ST50 has stopped responding to remote controls... - AVS Forum | Home Theater Discussions And Reviews
Old 05-06-2013, 12:22 AM - Thread Starter
ystasino's Avatar
My Panasonic 55ST50 has stopped responding to remote signals from the Panasonic and the DirecTV remotes. I swapped batteries and powered on and off using the power button. The Panasonic remote's back lighting works. The DirectTV remote works with the DirecTV box, but not with the TV as it used to when turned to the TV setting.
Tell me it's something silly and/or simple?
ystasino is offline
Old 05-06-2013, 12:27 AM
Omni009's Avatar
Quoted: 130 Post(s)
Liked: 82
Anything blocking it reaching the TV sensor?
Omni009 is offline
Old 05-06-2013, 07:57 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Originally Posted by ystasino View Post
My Panasonic 55ST50 has stopped responding to remote signals from the Panasonic and the DirecTV remotes. I swapped batteries and powered on and off using the power button. The Panasonic remote's back lighting works. The DirectTV remote works with the DirecTV box, but not with the TV as it used to when turned to the TV setting. Tell me it's something silly and/or simple? Thanks!
It's possible that the IR receiver module in the TV has become defective. It's rare, but it does happen sometimes. Time to call for warranty service,
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 05-06-2013, 10:27 AM - Thread Starter
ystasino's Avatar
Hmm, both remotes worked now that I tried. Nothing was blocking the IR sensor. Very strange. eek.gif
ystasino is offline
Old 05-06-2013, 11:21 AM - Thread Starter
ystasino's Avatar
This seems to be an intermittent issue. Neither of the two remotes are working right now.
ystasino is offline
Old 05-06-2013, 11:28 AM
GregLee's Avatar
Quoted: 801 Post(s)
Liked: 259
Could be some dirt on the IR window of the TV. Well, probably not, but it's easy to fix, if so.
Greg Lee
GregLee is online now
Old 05-06-2013, 10:41 PM - Thread Starter
ystasino's Avatar
I talked to customer support for 50 minutes today. The lady had a very odd accent and their procedure for getting techs out to see the TV seems very weird. She made me remove the batteries from the remote and asked me to press every remote button twice ?! She did not appear to know what the menus on the TV were like and appeared to be following instructions out of an archaic service menu process. She asked me to "reset the TV" by pressing the remote menu button and the volume down button, after spending 40 minutes explaining that the remote is not working. She said I should have a printout of the receipt and wouldn't accept the email with the pdf file.
It was the most frustrating/bizarre customer service call I have experienced in a while.
ystasino is offline
