Wall-Mount For Multiple TV's - AVS Forum | Home Theater Discussions And Reviews
Old 05-08-2013, 09:39 AM - Thread Starter
ousooner2's Avatar
Quoted: 259 Post(s)
Liked: 149
Hey fellas, I'm in need of some help. I'll keep it short and to the point..here's the situation
I currently have a Samsung 50a550, but I'll likely be getting the 65st60 soon. I want to wall mount both tv's (living room for 65" and bedroom for 50"), but can I use a 50" tv on the 65" mount for now? I don't know much about the hole patterns, etc so I'm not sure what would work and what wouldn't. Basically I'd like to mount both mounts in their rooms and obviously just have the mount for the 50" in the bedroom bare until I move my tv now into the bedroom.
Been looking at the Monoprice tilt/swivel mounts as it seems they can come out from the wall, kind of like an articulating mount. I don't need it to come out a ton, but the option wouldn't be a bad thing.
Panny 65st60 / Denon X1000 / EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
Selling 1 e1010i sub: http://www.avsforum.com/forum/209-au...al-10-sub.html
ousooner2 is offline
Old 05-08-2013, 10:04 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
There is something in the specs called VESA that has a number like 100X100 to 600 x 600 on the mounts from Monoprice.com with a weight limit for the set that can be mounted. Then look at the VESA spec for your TV and find a mount that has a VESA speck that that your TV will fit in. READ every thing in the mounts spec or what Monoprice calls description before you pick a mount, or mounts that work for you.
ousooner2 likes this.
Phil17108 is offline
