Which display wins the shootout? Let's have some fun. Make your predictions here. - Page 50 - AVS Forum | Home Theater Discussions And Reviews
post #1471 of 1489 Old 05-30-2013, 02:14 PM
Ilovetightbass's Avatar
Hahahaha
Ilovetightbass is offline
post #1472 of 1489 Old 05-30-2013, 02:17 PM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 6088 Post(s)
Liked: 10655
Originally Posted by Ph8te View Post
I think the question would be do you plan to get your set calibrated and if so then if brightness is a concern you may want to choose less acurate, but brighter for day viewing and then the "darker" for night....If you dont plan on watching of keeping the TV until it reaches that half life though, then its all moot as youll never really see the "change";..
That's true, unless a TV can barely make it to the appropriate brightness when brand-new. If one were to believe the VE shootout calibrators's results, the ZT60 is going to start at 30fL when fully calibrated in ISF mode, and will only drop from there. From day one, the ZT60 is getting dimmer, if properly calibrated for gamma and color. That's the only logical conclusion, if the 30 fL number cited at the shootout is in fact accurate.
Mark Henninger (aka Imagic)
imagic is online now
post #1473 of 1489 Old 05-30-2013, 02:36 PM - Thread Starter
Glashub's Avatar
Quoted: 60 Post(s)
Liked: 168
Lets say it takes 50k hours for the dimming to be noticeable -- if one watched tv 24 hours a day -- it would take 2083 days to get to 1/2 life or 5.7 years. Even if I leave the tv on non-stop I have 5.7 years before I hit the dimming point and by then OLED or 3d brain implants will be all the rage and cheap too.
Glashub is offline
post #1474 of 1489 Old 05-30-2013, 02:37 PM
Ph8te's Avatar
Quoted: 4697 Post(s)
Liked: 4219
I would agree with you, if you want the most accurate picture and use the ISF modes then you will be limited and it will only get "worse". Im thinking many will choose a less accurate mode to attain a brigher picture when needed and choose the "calibrated" for "night" viewing......It will be intereting to see how everything turns out in the months and years to come with these sets. I dont ahve any doubt that the numebrs in the shootout are accurate though. As it was said there it all depends on the mode you have your set in wink.gif
Ph8te is online now
post #1475 of 1489 Old 05-30-2013, 02:37 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Concurred that It's definitely a nonissue.
I noticed you recently came around to the ZT60 also after originally shunning it. What changed your mind?
vinnie97 is offline
post #1476 of 1489 Old 05-30-2013, 02:50 PM
imagic's Avatar
Liked: 10655
The difference between 30 fL and 15fL is more than noticeable to me, it's super-duper obvious. A ZT60 that's calibrated but running at half brightness will look quite dim, but again that assumes 30fL is as good as it gets in ISF mode, and I've seen several instances people have reported achieving 40+ fL in ISF mode. Fortunately, Panasonic says the half-bright point comes at 100,000 hours, or 11 years of continuous use. Like you said, it's basically a non-issue.
"The ZT60 Series display panel is free of mercury and lead. A newly designed phosphor process and rear panel process give the Plasma panel longevity of up to 100,000 hours before the brightness of the panel decreases to half. This is more than 30 years of viewing when watched 8 hours a day." - Panasonic
post #1477 of 1489 Old 05-30-2013, 02:52 PM - Thread Starter
Glashub's Avatar
Quoted: 60 Post(s)
Liked: 168
Yep. Sad but true. It's coming between 4 &5 on Saturday. May hold on to the VT50 for a while to make sure I like it.
Glashub is offline
post #1478 of 1489 Old 05-30-2013, 02:59 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
vinnie97 is offline
post #1479 of 1489 Old 05-30-2013, 03:05 PM - Thread Starter
Glashub's Avatar
Quoted: 60 Post(s)
Liked: 168
I suppose any of us could come up with a dozen reasons not to buy any plasma other than a Kuro -- maybe that's why people end up buying disposable LEDs? But the glory of a plasma before it starts dimming or screwing up in all the different ways it could screw up, huh? You only live once.
Glashub is offline
post #1480 of 1489 Old 05-30-2013, 03:17 PM
imagic's Avatar
Liked: 10655
If I had $3,000 to spend on a display device tomorrow—I would spend it on a projector, not on a plasma. biggrin.gif
post #1481 of 1489 Old 05-30-2013, 03:25 PM - Thread Starter
Glashub's Avatar
Quoted: 60 Post(s)
Liked: 168
Lucky you to have a place to set up a projector Mark. Here in Cali 500K gets you about 920 square feet in a not prime but not bad by any means neighborhood.
Glashub is offline
post #1482 of 1489 Old 05-30-2013, 03:30 PM
myoda's Avatar
Liked: 57
Back in 2004, I sold this Panasonic Enhanced Definition TV to a friend of mine. $1799.99 at BBY for a 42 inch plasma.
http://www.crutchfield.com/S-PIx556Qzw2s/p_13342PD50U/Panasonic-TH-42PD50U.html
Have not talked to him in years, but he recently popped up on FB - asked if the ED TV was still operational. Told me it's still crankin 9 years later. Back then, the average time to 1/2 brightness was 60,000 hours.
myoda is offline
post #1483 of 1489 Old 05-30-2013, 03:44 PM
imagic's Avatar
Liked: 10655
I live in Philly, in a rowhouse so I know what having limited space is like. That said, I'm more than willing to deal with the cramped installation and watch an 84" image. 96" diagonal is the very maximum I could get away, with and still be within THX viewing parameters for 1080p/2K. I used a projector up until about 18 months ago, with a 720p Bravia that was getting a bit long-in-tooth; 3D got me into a 55" panel, but I do miss the larger presentation and the very deep blacks I could get with projection.
post #1484 of 1489 Old 05-31-2013, 06:25 AM
sanramon94582's Avatar
^I think the Samsung will be superior with video processing, especially when it comes to lower resolutions.
Does Samsung's smart Revolution Kit upgrade only the smart features or will it improve video processing (i.e. picture quality) too?
sanramon94582 is offline
post #1485 of 1489 Old 05-31-2013, 06:41 AM
Ph8te's Avatar
Liked: 4219
It upgrades smart features CPU and memory if I remember correctly (at least it did this year)........So could video processing be improved, yes, will it be "readily" noticeable, that is an unknown. at some point you start to reach the limits of the Panel itself...
Ph8te is online now
post #1486 of 1489 Old 05-31-2013, 06:55 AM
DavidHir's Avatar
Quoted: 1913 Post(s)
Liked: 1559
RIght, if any kind of internal change is put forth (phosphor enhancement, new internal part, etc.) nothing can be done about it.
DavidHir is offline
post #1487 of 1489 Old 06-02-2013, 12:43 PM
saprano's Avatar
Quoted: 551 Post(s)
Liked: 544
Are all the videos of the shootout on youtube? There's seem to be some presentations and test missing.
home theater addict
saprano is offline
post #1488 of 1489 Old 06-02-2013, 04:19 PM
Quoted: 1631 Post(s)
Liked: 693
I'd sure hope it more than firmware but you really don't know.
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is offline
post #1489 of 1489 Old 06-03-2013, 12:19 AM
imagic's Avatar
Liked: 10655
The TV's CPU and GPU are inside the kit. There has never been any ambiguity on this topic. I have personally asked the question to Samsung's reps—the answer is always the same:
"The Evolution Kit upgrades the Smart TV's CPU, memory, and GPU to the level of the latest Smart TVs."
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv
