$1,200 credit To Spend at Fry's. Looking at 60" Models - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-09-2013, 11:59 AM - Thread Starter
freemeat's Avatar
Quoted: 391 Post(s)
Liked: 764
So I have $1,200 in credit at Fry's due to Warranty replacement on a tv that is too expensive to fix. I could spend a little more if needed. Maybe up to $1,500.00 max.
It looks like they mostly have LG's in that price range and some Panasonic's.
I don't care about 3D or Smart (my PS3 does Netflix, etc).
My priority is picture quality. I do also play PS3 games so if one tv inherently has a ton of latency/lag then I need to avoid it.
They do have LED-LCD's as well, though I'd rather go Plasma. Still open to the LED's though.
According to the website, this is the selection. Though perhaps the store has different choices:
Easier to just read at the link. I filtered out some of the choices below $1,000.00 but I'm open to those as well.
http://www.frys.com/search?query_string=&cat=-68520&pType=pDisplay&fq=100033%20Plasma-100029%2012-p10099997%201000.01*1500&sort=price%20asc&start=0&cat=-68520&from=0&to=24
LG 60PM6700 60" Class (59.8" Actual Diagonal Size) 1080p 600Hz 3D & WiFi Ready Plasma Smart TV
$1,099.00
Frys#7062601 LG 60PM9700 60" Class 1080p 600Hz Smart 3D Plasma TV with WiFi
1,099.00
While supplies last
1080p 600Hz Plasma TV - Viera Panasonic VIERA TC-P60U50 60" Class (60.1" Actual Diagonal Size) 1080p 600Hz Plasma TV
Frys # 7326984 Mfr: Panasonic
$1,199.00
While supplies last
59.8 1080P 3D CAPABLE PLASMA LG 60PZ550
59.8" 1080P 3D CAPABLE PLASMA HDTV
Frys # 6523373 Mfr: Lg
$1,299.90
While supplies last
Frys#7572416 LG 60PN6500 60" Class (59.8" Actual Diagonal Size) 1080p Plasma TV
Frys # 7572416 Mfr: Lg
$1,299.99
1080P 3D PLASMA HDTV, VIERA CO PANASONIC TC-P60ST30
1080P 3D PLASMA HDTV,VIERA CONNECT,WIFI READY,INFINITE BLACK 2 PANEL
Frys # 6926817 Mfr: Panasonic
$1,499.00
freemeat is offline
post #2 of 7 Old 05-09-2013, 12:07 PM
Ph8te's Avatar
Quoted: 4750 Post(s)
Liked: 4297
Panasonic ST60 or S60 would be my top choices in in that price range...
Ph8te is online now
post #3 of 7 Old 05-09-2013, 12:13 PM
headlesschickens's Avatar
Quoted: 22 Post(s)
Liked: 47
I couldn't realistically recommend any of those choices. Basically wouldn't recommend any LG plasma, and the Panasonic models you have listed there are either really old (ST30 for $1500 is not a good deal) or not great to begin with (U50). How long do you have before you have to use the credit? If you can wait, I expect the 60" ST60 will be available there and within your price range fairly soon. The 60" ST60 is currently listed for $1500 on Amazon and Best Buy.
headlesschickens is offline
post #4 of 7 Old 05-09-2013, 12:14 PM - Thread Starter
freemeat's Avatar
Quoted: 391 Post(s)
Liked: 764
Thanks, I'll have to see if they have those in the store as I don't see them on their website.
freemeat is offline
post #5 of 7 Old 05-09-2013, 12:16 PM - Thread Starter
freemeat's Avatar
Quoted: 391 Post(s)
Liked: 764
Thank you. I don't know if there is a set time frame. I have to bring in my broken set soon.
They basically told me the "buyers" are giving me a Sharp LC60LE650u model but then said I should be able to return in the system and use the credit for another tv if I wanted.
freemeat is offline
post #6 of 7 Old 05-09-2013, 11:37 PM
BriscoCountyJr's Avatar
Quoted: 34 Post(s)
Liked: 43
Last year I recall Frys seemed to not stock the new Panasonic plasma models for months after they were available from amazon and best buy.
Might be the same this year, so they might not have them in stock for a month or two?
BriscoCountyJr is offline
post #7 of 7 Old 05-10-2013, 08:53 AM - Thread Starter
freemeat's Avatar
Quoted: 391 Post(s)
Liked: 764
Yup, seems to be the case still. I went in last night and the selection isn't all that good unless I wan to go with an LG. Even with the LG they have a ton of the new models available to purchase but not on display as they are trying to push out the older models first.
edit: Pulling trigger on open box 65" Pannasonic GT30 model for $1200 including 2 year warranty.
freemeat is offline
