Pioneer KURO Experience 2008 Download - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 129 Old 05-15-2014, 04:41 PM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
Originally Posted by Mike99 View Post
I downloaded the file last night & used Firefox with the MEGA add-on. I have DSL which is not as fast as cable internet so I let it download overnight. The file is 14,256,898,048 bytes so I presume it's correct. Now I just have to find a way to play it since my PC's do not have Blu-ray drives.
you can use a virtual BR drive like Elby Cone drive, or you can use MediaPlayer Classic to play the file.
vega509 is offline
post #92 of 129 Old 05-15-2014, 05:42 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
http://www.avsforum.com/t/1473242/pioneer-kuro-experience-2008-download/30#post_23348441
sawfish is offline
post #93 of 129 Old 05-15-2014, 06:46 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I tried MPC-HC & it didn't play at all. I figured perhaps I need to update MPC-HC which I did. Now it plays about 30 seconds & freezes. Clicking Play or Pause does nothing. But if I move the scrolling indicator a bit it starts up again. However it plays the same 30 seconds. No matter where I place the scrolling indicator I always get the same 30 seconds of video & then it freezes.
Is there some setting that needs to be changed?
Mike99 is offline
post #94 of 129 Old 05-15-2014, 06:50 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I saw that. I don't have WinRAR but am guessing that's not a problem to get.
However I also do not use XBMC. Will the .m2ts files play in VLC or MPC-HC or anything else?
Mike99 is offline
post #95 of 129 Old 05-15-2014, 07:18 PM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
you may want to check the codecs you have installed, I'm using the K-Lite codec pack, it plays perfectly on my pc, and streams perfectly also. My pc is an Intel I7 3770 with 16gb ram.
vega509 is offline
post #96 of 129 Old 05-15-2014, 08:34 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
Doesn't have to be WinRAR, just any program that can extract files from .iso files.
They should play just about everywhere and do with VLC and PotPlayer. They even play off a thumb drive through my ST60's built-in media player, though the TV complains that the audio format isn't supported.
sawfish is offline
post #97 of 129 Old 05-15-2014, 11:10 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
So far I just tried playing it on my AMD quad core desktop.PC. I'll give it a try on the Intel G620 HTPC which happens to have MPC-HC on it but I never use it. I use WMC7 on the HTPC & don't have any separate codec packs installed on either PC as never needed any.
Mike99 is offline
post #98 of 129 Old 05-16-2014, 06:19 AM
Stereodude's Avatar
Quoted: 3090 Post(s)
Liked: 2238
It's MPEG-2 footage. Decoding it is trivial for any remotely recent PC.
Stereodude is offline
post #99 of 129 Old 05-16-2014, 07:26 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Don't have a BD-R burner. Anyone willing to burn one to a disc for me? I'll gladly pay for the disc and shipping.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #100 of 129 Old 05-16-2014, 09:28 AM
rcapprotti's Avatar
Quoted: 159 Post(s)
Liked: 126
dsskid my son made me want a few months ago I have an original one so I'd be glad to ship it to you just pay the shipping PM me your address
rcapprotti is offline
post #101 of 129 Old 05-16-2014, 10:22 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
You have PM.
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #102 of 129 Old 05-16-2014, 01:26 PM
rcapprotti's Avatar
Quoted: 159 Post(s)
Liked: 126
Okay I got your address I'll send it out tomorrow
post #103 of 129 Old 05-16-2014, 04:23 PM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Thanks again.
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #104 of 129 Old 05-17-2014, 01:26 AM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
Both of my PCs play MPEG-2 just fine. And .iso files also. But not this one.
I updated MPC-HC on the HTPC & it freezes just like my other PC. The Kuro .iso is the only Blu-ray .iso I've ever tried & it's obviously different than non-Bluray ones.
I haven't had time to extract the files yet but will do.
Mike99 is offline
post #105 of 129 Old 05-17-2014, 10:14 AM
Stereodude's Avatar
Liked: 2238
What version of MPC-HC are you using, and how are you trying to play the .iso?
post #106 of 129 Old 05-18-2014, 02:01 AM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I did extract the .m2ts files from the .iso & they play just fine using MPC-HC 1.7.5, 64 bit on either PC. I just drag the .m2ts or the .iso file onto the the MPC-HC desktop icon in order to play it.
The .iso plays what appears to be the first 1minute 10 seconds of the 00002.m2ts file but in only 25 seconds & then freezes. IOW it plays fast then stops short.
Mike99 is offline
post #107 of 129 Old 05-18-2014, 10:15 AM
Stereodude's Avatar
Liked: 2238
I've never tried playing an .ISO file like that. I always mount it with Virtual CloneDrive. However, I tried your method of dragging and dropping the .ISO and basically observed the same behavior. It played fast and choppy and eventually stops.
Dragging the .m2ts or .mpls files from the folders on the disc, after mounting the .iso, works fine.
post #108 of 129 Old 05-18-2014, 05:24 PM
Stereodude's Avatar
Liked: 2238
At the risk of having hoards of people chasing me with pitchforks and torches, I just want to say, that the video quality of this disc is not stellar. The content is good in terms of contrast, color and the like, but the MPEG-2 compression does it no favors (even at ~35Mbit/sec). There is some fine video noise in some of the scenes of the footage that didn't get along all that well with the compression.
post #109 of 129 Old 05-18-2014, 10:59 PM - Thread Starter
makaveddie81's Avatar
Quoted: 455 Post(s)
Liked: 273
When I ripped the disc for uploading, I performed a 1 to 1 .iso rip so all this is inherent in the oroginal.
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-141FD
Pioneer Kuro PRO-111FD x 2
Pioneer Kuro PDP-5020 x 2
makaveddie81 is offline
post #110 of 129 Old 05-19-2014, 04:42 AM
Stereodude's Avatar
Liked: 2238
I wasn't trying to suggest you altered the video quality. I was simply suggesting that it could have been mastered better with some light noise filtering before the MPEG-2 compression stage. Or, even better, been compressed with AVC / H.264.
post #111 of 129 Old 05-19-2014, 05:13 AM
rcapprotti's Avatar
Quoted: 159 Post(s)
Liked: 126
stereodude I have a question don't take this wrong If the quality of the video is not up to par then why have they used this particular video at the flat-panel shootout? I would imagine that they would want to use a Quality Blu-ray disc to do demonstrations on these high-end TVs. I guess it don't take it wrong just asking
post #112 of 129 Old 05-19-2014, 05:20 AM
rcapprotti's Avatar
Quoted: 159 Post(s)
Liked: 126
I have an original kuro blu-ray disc that I bought on eBay and I have one that i made and I can't tell the difference between the original kuro disc and the one that I made
post #113 of 129 Old 05-19-2014, 05:52 AM
Stereodude's Avatar
Liked: 2238
It depends what you're trying to show. If you want to show off black level, contrast, or color there's nothing wrong with it. If you want to show off how clean and pristine a blu-ray can look there are some MPEG-2 compression artifacts that detract from the image quality in some of the scenes. They're most obvious in the diagonal panning of the flowers against the white background in the middle of Kuro Best II. They're also fairly visible in the close up shots of the model's face at the start of the same segment.
post #114 of 129 Old 05-19-2014, 07:45 AM
rcapprotti's Avatar
Quoted: 159 Post(s)
Liked: 126
Ok i will take your word on that because you no a lot more about this stuff then I do .that way I ask they say the only dumb question is the is the one you don't ask.so thanks for the info and have a good one
post #115 of 129 Old 05-19-2014, 11:32 AM - Thread Starter
Quoted: 455 Post(s)
Liked: 273
OK I see what you're saying. It's not as pristine as a reference blu-ray. I also see this on the red rose scene in Kuro Best II.
post #116 of 129 Old 05-19-2014, 11:46 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Would've been nice if they used a more robust codec (AVC or VC1) , but I have to say the imperfections don't stand out when your jaw is dropping to the floor with a display that faithfully reproduces the high contrast. biggrin.gif
vinnie97 is offline
post #117 of 129 Old 05-21-2014, 03:28 PM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
I received the disc today, and it works flawlessly. Thanks again, I really appreciate it.
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #118 of 129 Old 05-21-2014, 07:24 PM
rcapprotti's Avatar
Quoted: 159 Post(s)
Liked: 126
Glad I could help and enjoy
post #119 of 129 Old 05-26-2014, 07:28 AM
saprano's Avatar
Quoted: 539 Post(s)
Liked: 527
Anybody have any extra copies? My computer is dated.
home theater addict
saprano is offline
post #120 of 129 Old 05-26-2014, 12:29 PM
rcapprotti's Avatar
Quoted: 159 Post(s)
Liked: 126
I have a copy but it's not Blu ray
Pioneer Elite Kuro Pro 1150hd 50 Inch Plasma Hdtv
