Need help troubleshooting bad board on Panasonic TC-P50G20 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-20-2013, 07:47 PM - Thread Starter
pand0ra's Avatar
When I power on the TV it starts flashing 10 blinks then repeats (you can hear the relay click on but TV will not display a picture). Looked up the code and basically said it was one of the 4 boards was bad.
Action I have taken so far:
I tested all of the fuses, all good.
Replaces the A board. No change.
I unplugged the cables from the SC board and when I powered on the TV it started blinking 6 times then repeats. Plugging the cables back in causes it to go back to blinking 10 times when powered on.
Any suggestions?
pand0ra is offline
post #2 of 2 Old 05-21-2013, 11:25 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
The SC has a short on the 15V or other rails, which probably indicates a short elsewhere also on Vsus (around 200V). Replacement of the SC, SU and SD is recommended.
tom669 is offline
