Official ZT60 Owners Thread - Page 106 - AVS Forum | Home Theater Discussions And Reviews
 535Likes
post #3151 of 14741 Old 09-12-2013, 04:47 PM
roadbike60035's Avatar
I'd agree with Repete - maybe. Hard to tell from the pic, but your room looks brighter behind the screen than in front of it (viewing area). My rooms pretty bright with windows on one side & glass patio doors 30 feet or so shining onto the screen. Frankly, I get reflection off the chrome trim but not the screen unless it's a really dark video image. The light filter works well.
That said, the Samsung is known to be brighter so if that's your primary driver go for the samsung. If you can somehow manage the sunlight I would highly recommend the ZT though. The pic quality is outstanding & it will play nice with BOTH IOS & Android. All our guests have commented about the picture on this set.
Good luck- tough choice ahead, but in the end it's all good.
roadbike60035 is offline
post #3152 of 14741 Old 09-12-2013, 05:12 PM
jnzz001's Avatar
I said already that Samsung is below any acceptable level of mine.
And my 10th generation 50" PF50UK (or PH whatever is full HD) has same visibility from any angle.
Now to the person who says 80 degree - JUST FYI - I am not referring to the horizontal angle as it's a OK... but vertical one.
It seems to be distracting when your picture changes before and after you seat in front of the screen. Never seen anything like this on my previous plasmas. Now these are CONSUMER TV's so I understand they are cheap and buggy - ANYBODY knows when I would be able to buy a professional business PLASMA based on the same panel?
I bet that these quirks will be non-existent and better polarity filter would be used to prevent the above banding issue...
jnzz001 is offline
post #3153 of 14741 Old 09-12-2013, 05:20 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 603
Screw it. I'm getting the ZT60.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is online now
post #3154 of 14741 Old 09-12-2013, 05:21 PM
chunon's Avatar
Quoted: 2186 Post(s)
Liked: 1895
Consumer panels are miles ahead of professional panels these days
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3155 of 14741 Old 09-12-2013, 06:00 PM
jnzz001's Avatar
Yes - they are in a sense that they do not put "unfinished" tech in them, and consumer TV's are "miles" ahead since they had appz, internet, netflix, tuner etc and all other CRAP which no high-end users need whatsoever...
If you have EVER seen a sony trimaster BVM monitor you would probably apologize for your post above. Tey even a decent PVM...
You will be surprised.
jnzz001 is offline
post #3156 of 14741 Old 09-12-2013, 06:03 PM
chunon's Avatar
Liked: 1895
I am talking about Panasonic plasmas only and I don't have to apologize for anything
I think your a little out of touch with current plasma technology but I wish you the best
65C6 OLED
post #3157 of 14741 Old 09-12-2013, 06:05 PM
repete66211's Avatar
Quoted: 131 Post(s)
Liked: 288
Even with the vertical viewing angle you're getting a good 60 degrees. You'd have to be sitting very low or really close in order for that to be a problem. Where do you have it, over a fireplace?
The light filter is what's limiting the angle by the way. It's an effective trade-off for most applications.
repete66211 is offline
post #3158 of 14741 Old 09-12-2013, 06:12 PM
Quoted: 131 Post(s)
Liked: 288
Are you referring to the $17,500 17" model or the $26,000 25" model?
post #3159 of 14741 Old 09-12-2013, 09:56 PM
Jason626's Avatar
Quoted: 157 Post(s)
Liked: 152
Maybe think about trying st60. No fans and less aggressive AR filter.
Jason626 is offline
post #3160 of 14741 Old 09-12-2013, 10:16 PM
jnzz001's Avatar
will take a look or do some more research - thanks!
jnzz001 is offline
post #3161 of 14741 Old 09-12-2013, 11:06 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
As it's already been stated, this has everything to do with the aggressive anti-reflective filter they've applied to the panel this year and nothing with QC.
vinnie97 is offline
post #3162 of 14741 Old 09-12-2013, 11:38 PM
Phil1975m's Avatar
Quoted: 34 Post(s)
Liked: 87
Originally Posted by Lost! View Post
[quote name="Phil1975m" url="/t/1474480/official-zt60-owners-thread/3120#post_23728667"]The Engineers wall mounted the TV for me ...[/quote]Just curious, was the TV wall mounted prior to the fan fix? In other words, who/how did they demount the TV?
Yes the TV was wall mounted.
Then applied the foam fix.
Phil1975m is online now
post #3163 of 14741 Old 09-13-2013, 02:41 AM
jnzz001's Avatar
happens sporadically - you need to change the picture mode back and again...
jnzz001 is offline
post #3164 of 14741 Old 09-13-2013, 03:44 AM
chunon's Avatar
Liked: 1895
Originally Posted by keilalajlb View Post
Got new ZT 65" inch this week and have been watching when suddenly it auto-dimmed from a good level brightness to something dark/hard to see. Does the TV have an auto dimming feature? Has anyone else seen this?0LiUl
Yes Eco settings should be set to standard I believe, also make sure "CATS" is off
65C6 OLED
post #3165 of 14741 Old 09-13-2013, 07:10 AM
Quoted: 131 Post(s)
Liked: 288
If I were a betting man I'd say the frame was bent in the process.
post #3166 of 14741 Old 09-13-2013, 07:12 AM
buzzcock's Avatar
Originally Posted by Jonathan Rosche View Post
Just got my 65ZT a week or so ago. Ran it up just over 200 with the slides. The one thing that seems odd compared to my pioneer is the motion. It looks kinda like LEDs in spots with the soap opera effect and sometimes the motion looks jerky. I have set it to 96 hz and tried with motion smoother off and weak. In general it's hard to explain but the motion just doesn't look right and So far I find that it bothers me. Not sure why my pioneer would have delt with that better because reviews haven't mentioned a motion problem. Any of you guys experience the same?
I'm experiencing the same problem as well. I suspect that it's a combination of the source material and my cabling...currently using 1.3 HDMI cables and I'm switching those out this weekend for high speed cables...could that be your issue?
buzzcock is offline
post #3167 of 14741 Old 09-13-2013, 07:21 AM
Quoted: 131 Post(s)
Liked: 288
Do you have "Motion Smoothing" engaged? HDMI 1.4 added Ethernet & Audio Return Channel so your 1.3 spec shouldn't have an impact in motion rendering.
post #3168 of 14741 Old 09-13-2013, 07:49 AM
buzzcock's Avatar
^Yes, motion smoothing are set to weak by default (my choice), the first thing I did try was turning that completely off...it seemed to improve it somewhat, can't really be sure since it was still there...
buzzcock is offline
post #3169 of 14741 Old 09-13-2013, 07:56 AM
Quoted: 131 Post(s)
Liked: 288
If motion looks artificially smoothed the primary suspect is going to be motion smoothing video processing. I can't duplicate what you're describing so that's all I can suggest. Good luck.
post #3170 of 14741 Old 09-13-2013, 08:21 AM
Lost!'s Avatar
Liked: 33
These TVs are very sensitive. The only one I had with a broken/chipped glass, was the one that they rotated it roughly to attach the pedestal. I guess you have to be very careful. Also, I think I read somewhere that putting the TV face down is a big no-no.
Lost! is offline
post #3171 of 14741 Old 09-13-2013, 11:24 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Read it where? I did it when attaching the stand with no untoward effects. smile.gif The rule of thumb of course is to always handle with care.
vinnie97 is offline
post #3172 of 14741 Old 09-13-2013, 12:24 PM
Lost!'s Avatar
Liked: 33
I am pretty sure I read it on AVS. Something about Phosphors and screen uniformity problems. Not to mention the weight of components on the glass from behind.
Lost! is offline
post #3173 of 14741 Old 09-13-2013, 12:54 PM
Quoted: 131 Post(s)
Liked: 288
In the early days of plasma I remember hearing from a salesman that you should never lay them flat.
post #3174 of 14741 Old 09-13-2013, 01:01 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Uh oh, maybe that's why I have slight DSE tongue.gif (probably not in actuality, as it also appeared on all the Kuros I owned, which I don't believe I ever laid down on their glass surfaces).
vinnie97 is offline
post #3175 of 14741 Old 09-13-2013, 08:22 PM
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
I had a bluray film on repeat to play on the TV while I'm at work but now that I am home the TV is off. I didn't set the timer or nothing. Could it be that it shuts off after a few hours if it gets too hot??
Bardia is offline
post #3176 of 14741 Old 09-13-2013, 08:32 PM
rx74ray's Avatar
Quoted: 91 Post(s)
Liked: 42
Tv times out and shuts off on "no signal". Probably something went wrong with the player.
Display: LG 65E6P, Speakers: 7.1, Polk Monitor 70 Biamped (R,L), Polk CS20 (Center), QPD (Rears), Yamaha (Woofer) Previous Displays: LG 65EF9500, VIZIO P702ui-B3, Panasonic TC-P65ZT60, Sharp Elite PRO-70X5FD, Sony XBR-65HX950, Toshiba 55SV670U, Mitsubishi WD-65734, Panasonic PT-47WX49
rx74ray is offline
post #3177 of 14741 Old 09-13-2013, 08:50 PM
Quoted: 131 Post(s)
Liked: 288
Settings/Eco navigation/No activity for 4 hours-->
You have the option of staying on but the default is "Power TV off".
post #3178 of 14741 Old 09-13-2013, 09:44 PM
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
That's what
That was it
The movie was still playing
Bardia is offline
post #3179 of 14741 Old 09-14-2013, 06:56 AM
Quoted: 131 Post(s)
Liked: 288
Sometimes I get a notice that the TV will be powering off in X minutes even when it's playing content. 'm not really sure how it's determining "no activity".
post #3180 of 14741 Old 09-14-2013, 08:41 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2140 Post(s)
Liked: 2290
You are correct. They used to be equal, not even close any more........
Cleveland Plasma is offline
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
