Official ZT60 Owners Thread - Page 151 - AVS Forum
post #4501 of 12664 Old 11-27-2013, 10:58 AM
repete66211's Avatar
Quoted: 49 Post(s)
Liked: 205
Originally Posted by vahighland View Post
At this point, I'll have to deal with Panasonic directly. I'll get the board replaced for the buzzing issue and go from there. The thing is, even if I got Paul's TV to exchange, there's no guarantee I would get a August 2013 build or later. And even if I did, would that really resolve the fan noise and buzzing. Also, there's a chance that I have other issues like dead pixels and banding.
A later build date doesn't mean much. It seems the foam fix was added to the manufacturing process at some point but, as some will attest, the foam fix doesn't solve the noise problem, it just mitigates it slightly. To date I recall seeing vinnie and maybe one or two other people reporting dead/stuck pixels, so that is rarely an issue. The buzzing is also a rare issue. As for the banding, nearly everyone who has looked for it has seen it along the right side while running slides but it fades with time and is rarely (if ever) noticeable during standard (i.e. non-slide) content.
repete66211 is offline
post #4502 of 12664 Old 11-27-2013, 11:26 AM
vahighland's Avatar
Has is actually been verified that the factory fix is exactly the same as the foam kit fix? Agreed that dead/stuck pixels is rare, but it could happen (and with my luck eek.gif). Some have reporting the buzzing, but it's hard to get a sense on whether some people are just more sensitive to the sound/frequency. As I understand it, most plasmas buzz to some degree. I just don't know if my set is buzzing more or am I just more sensitive to that sound. I wish there was a way to measure the degree of buzzing, so I could compare it to other sets.
vahighland is online now
post #4503 of 12664 Old 11-27-2013, 11:33 AM
Quoted: 49 Post(s)
Liked: 205
All I've seen--which I admit isn't much--seems to indicate the factory fix is the same as the foam fix. Others, please correct me if I'm wrong here. All plasmas buzz to some degree but, as with the fan noise, it seems some ZTs may be worse than others. Otherwise I can't account for ANYONE being upset with the level of buzzing from my set (even when listening for it), just as the fan noise I'm hearing does not resemble how I've seen it described on other sets.
post #4504 of 12664 Old 11-27-2013, 11:50 AM
vahighland's Avatar
There are a couple of other things I should mention. I have tried to plug the tv into a UPS and two other non-UPS wall sockets for two different circuits. No changes in the buzzing. The other thing I should say and maybe this is the big thing...this tv buzzes about the same level as my older P65V10. I'm curious if anyone else has owned a V10 and can comment on the level of buzz between the two sets.
post #4505 of 12664 Old 11-27-2013, 12:29 PM
elbobo19's Avatar
Not sure how much buzz you are getting but I can tell you the buzz I am getting is not normal, during bright scenes it can be heard over dialogue at my normal volume(-33db on my receiver).
I went to a local best buy that had this tv and the buzz was maybe 1/4 what I am experiencing, I could barely hear it with my head right next to the tv.
elbobo19 is offline
post #4506 of 12664 Old 11-27-2013, 12:46 PM
changboy's Avatar
Liked: 53
deleted
changboy is offline
post #4507 of 12664 Old 11-27-2013, 01:29 PM
rjih's Avatar
Just took delivery on a 60ZT60 with an August build date. I am currently running D-Nice's slides and cannot find any bad pixels. I am sitting approximately eight feet from the set and cannot hear any fan noise unless I get behind the panel. biggrin.gif Nothing will be watched until I have completed the 100 hour slide show.
rjih is offline
post #4508 of 12664 Old 11-27-2013, 01:35 PM
changboy's Avatar
Liked: 53
deleted
changboy is offline
post #4509 of 12664 Old 11-27-2013, 01:37 PM
Spidergames's Avatar
IMO I think you should do full month and a half, just to be safe. that's what I did...with my older 2010 set, I did nothing but a 100 hour slides, but after that I still got IR and burn in....
Spidergames is offline
post #4510 of 12664 Old 11-27-2013, 01:40 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1010
What does that mean, a full month and a half? 1080 hours?eek.gif That won't lessen the susceptibility to IR/burn-in anymore than 300 hours will (the maximum you should bother breaking in).
vinnie97 is offline
post #4511 of 12664 Old 11-27-2013, 01:50 PM
rjih's Avatar
My sequential number is A111XX. Based on the A07777 number mine must have been manufactured toward the end of the August.
I have a 55VT30 that had the 100 hour slide prep before being calibrated by D-Nice. I was careful what I watched for the first few months and image retention does not appear to be an issue.
rjih is offline
post #4512 of 12664 Old 11-27-2013, 01:53 PM
rightintel's Avatar
Quoted: 24 Post(s)
Liked: 39
Originally Posted by Axxion View Post
Originally Posted by rightintel View Post
Thanks. I was thinking along the lines of fast motion scenes and/or gaming consoles if anyone has any experiences they'd like to share...
Gaming on it right now, im a heavy gamer, own a ps4, ps3, xbox one, wiiu, gaming pc. No blur. No judder. Smooth as can be. Good input lag in game mode. Nothing to worry about.
Thanks, two for two so far...
Xbox Live: General PATT0N
rightintel is offline
post #4513 of 12664 Old 11-27-2013, 02:02 PM
Terebi's Avatar
My sequential number is A11164. Based on the A07777 number mine must have been manufactured toward the end of the August.
Mine is 8000-something but built in July. The TV folder # has little correlation with build date.
Terebi is offline
post #4514 of 12664 Old 11-27-2013, 02:32 PM
changboy's Avatar
Liked: 53
deleted
changboy is offline
post #4515 of 12664 Old 11-27-2013, 03:05 PM
denaliman's Avatar
Liked: 24
65" Zt60- A10912- Build August here in Canada. Just arrived not hooked up yet.
denaliman is offline
post #4516 of 12664 Old 11-27-2013, 04:19 PM
olyteddy's Avatar
Quoted: 92 Post(s)
Liked: 209
Originally Posted by changboy View Post
Originally Posted by vinnie97 View Post
Changboy, those look good. You should post in the Panasonic photo thread: www.avsforum.com/t/1475972/official-panasonic-st-gt-vt-zt60-pictures-thread (where there is a noticeable lack of ZT photos).
I post some pic at this place but my pic are small and i saw many peop have big pic so can you tell me how i can udate my pic.
Here example of the sizte i post,
You can edit your post to make the picture just about any size you want. You currently have it set to '/width/500/height/1000'. see:
or even:
PS: Click on 'Quote' to see how to do it...tongue.gif
olyteddy is online now
post #4517 of 12664 Old 11-27-2013, 04:34 PM
changboy's Avatar
Liked: 53
deleted
changboy is offline
post #4518 of 12664 Old 11-27-2013, 04:36 PM
changboy's Avatar
Liked: 53
deleted
changboy is offline
post #4519 of 12664 Old 11-27-2013, 05:03 PM
changboy's Avatar
Liked: 53
deleted
changboy is offline
post #4520 of 12664 Old 11-27-2013, 05:11 PM
Edllguy's Avatar
"65" Zt60- A10912- Build August here in Canada. Just arrived not hooked up yet."
denaliman,
Can you let us know how the fan noise is. Congrats on your August ZT build unit. Cherish it.
Edllguy is online now
post #4521 of 12664 Old 11-27-2013, 05:22 PM
Edllguy's Avatar
Hey guys, as most of you know I'm taking delivery of my ZT on Saturday. Couple questions.
Its been cold lately and of course my ZT will be exposed to the frigid temperatures. How long will I have to let my ZT adjust to normal room temperatures before turning it on.
Also, I downloaded D-Nices break in slides for 2013 Panasonics. I'm questioning whether I downloaded the correct ones. There are only 15 slides: Red, Blue, Green and the rest of various shades of gray/white. Is this correct?
post #4522 of 12664 Old 11-27-2013, 05:35 PM
SwiftSweeper's Avatar
Liked: 35
I am surprised to hear that nearly all ZTs have banding. o.o After all, ZT is Panasonic's flagship plasma. FWIW, I can see the banding on many commercials since many of them use uniform bright/white backgrounds. I am not sure if the banding on mine is getting better, but it is definitely not getting worse.
SwiftSweeper is offline
post #4523 of 12664 Old 11-27-2013, 05:41 PM
Terebi's Avatar
Oh i was wrong, my number its A07777 and build in JULY, i just check the back and i wash it in the same time and blow air on fan, they were dirty lil.
OK, maybe there IS a correlation.
Terebi is offline
post #4524 of 12664 Old 11-27-2013, 05:59 PM
Liked: 35
I downloaded D-Nice slides from Panasonic ZT/VT/ST settings thread on this forum. I have 12 slides in total. Three slides are primary colors. The rest of the slides are shades of gray/white/black. I am surprised that you have 15 slides... I also saw slides on the web(not D-Nice slides) that have various shades of primary colors in addition to various shades of gray/black/white.
Can anybody chime in on this?
I am planning to use D-Nice slides on my ZT replacement because this time, I want to get over break in quickly and want to try D-Nice settings. I would hate to run wrong set of slides and mess up the PQ somehow.
post #4525 of 12664 Old 11-27-2013, 06:09 PM
changboy's Avatar
Liked: 53
deleted
changboy is offline
post #4526 of 12664 Old 11-27-2013, 06:21 PM
Edllguy's Avatar
^^^^^^^^^Sorry guys about my incorrect information. As stated here it is only 12 slides with the 3 primary colours and the rest various white/gray/black shades etc. I just rechecked and saw my error.
post #4527 of 12664 Old 11-27-2013, 08:01 PM
Liked: 35
Yes its 12 pic and to be sure you can find it on this link under the name of ; Panel Prep Slides:
http://www.controlcal.com/forum/showthread.php?t=939
Thanks! I will just get the slides from the Controlcal thread to ensure that I have the latest version of the slides. smile.gif
post #4528 of 12664 Old 11-27-2013, 08:04 PM
Quoted: 49 Post(s)
Liked: 205
Considering any 16:9 content will accomplish (effectively) the same thing as D-Nice's slides, I don't think the number of slides or even the color or hue of the slides is particularly relevant as long as there's some variety.
The "Fridge Noise" thread created and maintained by Lost! early on has a list of some production numbers and their corresponding build months.
post #4529 of 12664 Old 11-27-2013, 08:06 PM
mjodotcom's Avatar
Anyone else notice that the very last pixel line to the left on the screen has a slight purple tint to it? I caught it while running the break in slides. Thanks!
mjodotcom is offline
post #4530 of 12664 Old 11-27-2013, 08:10 PM
@TOMMY@'s Avatar
Just ordered mine. Can't wait. Will check for fan noise and dead pixel upon arrival.
@TOMMY@ is offline
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
