Official ZT60 Owners Thread - Page 169 - AVS Forum | Home Theater Discussions And Reviews
 551Likes
post #5041 of 14817 Old 12-16-2013, 04:06 AM
changboy's Avatar
Liked: 53
deleted
changboy is offline
post #5042 of 14817 Old 12-16-2013, 07:40 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2938 Post(s)
Liked: 3104
Originally Posted by @TOMMY@ View Post
It didn't even occur to me I should check the hours on my brand new TV from a reputable company.
Don't sweet it, some units are tested at the factory. Spot checked. You would know if your TV is used. Everything would have been opened.
Cleveland Plasma is offline
post #5043 of 14817 Old 12-16-2013, 08:48 AM
Nerdful1's Avatar
Location: Maine, grew up mostly in NH. hope to move back.
Buying a 65zt as we speak, awaiting salesman call to buy one now.
Anything I should be careful of from Paulstv.com?
Update: On its way, getting in a few days.
Does this have a perfect color decoder? Even with ISF, my Samsung DLP had incurable red push..
Nerdful1 is offline
post #5044 of 14817 Old 12-16-2013, 09:14 AM
Axxion's Avatar
Liked: 89
no worries at all. Just make sure you inspect everything and turn on before singing.
Axxion is offline
post #5045 of 14817 Old 12-16-2013, 09:23 AM
repete66211's Avatar
Quoted: 131 Post(s)
Liked: 288
Paul's seems to have a higher rate of damage during shipment--VERY small sample size here--so make sure you inspect the unit thoroughly. If it's been in a cold truck for a while you may want to wait before you turn it on.
repete66211 is offline
post #5046 of 14817 Old 12-16-2013, 09:41 AM
Axxion's Avatar
Liked: 89
he is correct, i live in texas and it doesnt get very cold, and it was like 80 degrees when i got my tv about a month ago, i overlooked the fact it will most likely be freezing wherever your at, let the tv warm up and dry out before turning on. Just check the screen with a strong led flashlight for cracks, on corners mainly. Dents on tv and box as well. Watch them unload it.
Axxion is offline
post #5047 of 14817 Old 12-16-2013, 10:04 AM
Mike Adri's Avatar
2.  I would like to try D-NICE's settings, but the settings: suggest using
Picture Mode: Professional 1 / 2
  I can't get access to that Picture mode with HDMI input from my laptop/apple TV/ or while using apps like Netflix.    In fact, I     was surprised that THX was not available when streaming from one  of the built in apps like Netflix.
UPDATE I FIGURED THIS OUT -In main menu - go to SETUP then scroll down to PROFESSIONAL MODE (isfccc) and turn on.
When you go back to Picture menu the two new picture modes appear.
I still haven't figured out how to get it to look good with  computer text.  THE LG OLED looked amazing with this laptop.  I was hopping the difference was partially due to  settings.
Mike Adri is offline
post #5048 of 14817 Old 12-16-2013, 10:06 AM
KanosWRX's Avatar
Quoted: 178 Post(s)
Liked: 59
Has anyone noticed a few small dents on the back of their TV's, looks like where the foam may have been pressed up against the TV??
The TV itself looks good otherwise, the screen looks great, no cracks from what I could tell running a led light around it. Its a May 2013 build date, just got it a couple days ago 12/13/2013 from BestBuy.
KanosWRX is offline
post #5049 of 14817 Old 12-16-2013, 10:53 AM
Jarmel's Avatar
So breaking in the plasma and I'm on roughly the 90 somethingish hour and I noticed on both sides of the screeen, there is a color edge. The leftmost edge going up is slightly purple and the rightmost edge is slightly green. This extends all the way down on both sides and is like this during all the slides other than the blue,green, and red slides where the pixels look normal. Is this normal? Is it IR or burn in?
Jarmel is offline
post #5050 of 14817 Old 12-16-2013, 11:08 AM
changboy's Avatar
Liked: 53
deleted
changboy is offline
post #5051 of 14817 Old 12-16-2013, 11:10 AM
KanosWRX's Avatar
Quoted: 178 Post(s)
Liked: 59
Can you take any pictures and post what you see?
KanosWRX is offline
post #5052 of 14817 Old 12-16-2013, 11:27 AM
Quoted: 131 Post(s)
Liked: 288
I remember seeing posts in this thread relating to both of these so you're not along. I'm sorry but I can't recall the solution or explanation to either.
post #5053 of 14817 Old 12-16-2013, 11:28 AM
Jarmel's Avatar
Sure.
On the leftmost edge, there is a vertical series of slightly purple pixel and on the rightmost edge, there is a vertical series of slightly green pixels.
Jarmel is offline
post #5054 of 14817 Old 12-16-2013, 11:57 AM
Bond 007's Avatar
Quoted: 2625 Post(s)
Liked: 2088
Normal. Make sure picture size is set to Full.
Licence to Kill
Bond 007 is offline
post #5055 of 14817 Old 12-16-2013, 11:59 AM
Bond 007's Avatar
Liked: 2088
Probably something done at the factory. I wouldnt worry about it.
Licence to Kill
Bond 007 is offline
post #5056 of 14817 Old 12-16-2013, 12:06 PM
Mike Adri's Avatar
Me i increase the size of the letter with windows 7 from 100% to 145% and its a lot better coz yes its small and the screen is big, your lg have 55 inch so the pixel are smaller.
I have tried this.  It still doesn't look great.  I am wondering if it has something to do with this: http://www.avsforum.com/t/1381724/official-4-4-4-chroma-subsampling-thread/200_100#post_23286175
have 3 questions :
How do you like your LG OLED picture quality versus the ZT ?
I didn't buy the OLED.  I just saw it in the store.  I thought it was better overall than the ZT, but too expensive.
And the motion handling from OLED it is the same thing of a LED ?
When I shut motion enhancement off, the I didn't notice any motion issues.  Not sure I am an expert on this though.  I hate the way things look with motion enhancement on (i.e. soap opera effect).
Do you compare the OLED samsung with the LG before buy it ?
I did look at both.  The computer text looked much better with the LG, but I didn't try to play with the settings.
post #5057 of 14817 Old 12-16-2013, 12:35 PM
Jarmel's Avatar
Shouldn't the picture size already be set to full?
I was planning on running the slides for another 100 hours but now I'm thinking maybe I should play regular content to get rid of the lines.
Jarmel is offline
post #5058 of 14817 Old 12-16-2013, 12:55 PM
Quoted: 131 Post(s)
Liked: 288
Bond may have meant to turn on overscan. See if changing that setting makes a difference.
post #5059 of 14817 Old 12-16-2013, 12:57 PM
changboy's Avatar
Liked: 53
deleted
changboy is offline
post #5060 of 14817 Old 12-16-2013, 12:58 PM
Axxion's Avatar
Liked: 89
Lol. All the plasmas have those colored lines on the side. Both mine have it. Everyone does, this has been covered. Its normal. Nothing you can do to change it.
Axxion is offline
post #5061 of 14817 Old 12-16-2013, 01:00 PM
Axxion's Avatar
Liked: 89
have 3 questions :
I complained about the text awhile back too. Ive discovered a fix just now. Go to advanced picture. Go to hdmi content type. Go to auto detail setting. Turn graphics off. It makes the text less sharp and artifacty looking. I knew it had something to do with processing.
Axxion is offline
post #5062 of 14817 Old 12-16-2013, 01:10 PM
sooke's Avatar
Quoted: 100 Post(s)
Liked: 69
... I still haven't figured out how to get it to look good with  computer text.  ...
Maybe make sure overscan is off. You don't want to scale the image at all. You want the computer to output 1920x1080 to match the panel rez with no scaling in between.
Panasonic TC-P60ZT60 plasma panel
Sony BDP-S5500 Blu-ray player
Arris DCX3600-M DVR
Yamaha RX-V650 AVR
XBox One
URC MX-780 remote control
sooke is offline
post #5063 of 14817 Old 12-16-2013, 01:16 PM
Axxion's Avatar
Liked: 89
This too if you havnt already checked your settings for your graphics driver.
Axxion is offline
post #5064 of 14817 Old 12-16-2013, 01:33 PM
Mike Adri's Avatar
My computer (macbook pro retina) is outputting 1080p over HDMI.
Thanks Axxion,
I selected off but it is not great.
Overscan was off.  This biggest difference i see is when I turn 1080p pure direct on.   (in the Advanced picture  setting).   But it still doesn't look great.
post #5065 of 14817 Old 12-16-2013, 01:36 PM
Mike Adri's Avatar
It is a bit hard to tell.
I take 2 picture with my handphone of this tread but they are both bad quality but you can see the letter from my ZT, it is more bad then this or the same thing ?
post #5066 of 14817 Old 12-16-2013, 01:56 PM
changboy's Avatar
Liked: 53
deleted
changboy is offline
post #5067 of 14817 Old 12-16-2013, 02:31 PM
Mike Adri's Avatar
Can you take a picture of your panel while showing this tread like i do ?
Are you on pro-mode isf ?
I found if the sharpness is set too high can have a detrimental effect on pro-mode max around +35-+42
On custom mode its +15
higher then this some color can be found around the letter
post #5068 of 14817 Old 12-16-2013, 02:37 PM
UniversalGC's Avatar
Originally Posted by music_to_my_ear View Post
Just bought the 65ZT60 for 3999.99 with free delivery from Telecity Electronics. Its getting delivered in 1-2 weeks. Cant wait!
Maybe you don't mind, but you WAY overpaid. Like over $1000 too high.
If you do mind, I would strongly consider canceling that order and looking around, Or try to get them to match a better price.
My components:
Panasonic TC-P65ZT60 TV
Yamaha RX-V673 Receiver
Sony BDP-S590 Blu-ray
Definitive Tech Speakers 7.1
UniversalGC is offline
post #5069 of 14817 Old 12-16-2013, 02:42 PM
Quoted: 131 Post(s)
Liked: 288
He's from the Great White North where everything is friendlier, but also more expensive.
post #5070 of 14817 Old 12-16-2013, 02:46 PM
Axxion's Avatar
Liked: 89
Thats what i thought too when i saw that price, canada.
Axxion is offline
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
